    Terrain rendering
    renderpluginsextensions
    14 Posts 5 Posters 2.5k Views 5 Watching
      koenvdw
      use smooth : eraser tool and hold down ctrl
      Is the hidden geometry visible?
      • array81A Offline
        array81
        On SketchUp I don't see these lines:
        https://s21.postimg.org/gbqz7zefb/render.jpg
        I don't understand because I see them on render
        • panixiaP Offline
          panixia
          looks like you are using displacement without the "keep continuity" option (or whatever that's called in sketchup vray i don't remember) turned off, is that?!?
          • array81A Offline
            array81
            "keep continuity" is active on VRAY.
            In any case the problem is the displacement. With material without "displacement" I don't have this problem.
              rspierenburg
              Is the terrain grouped by itself?
              • array81A Offline
                array81
                Yes
                • panixiaP Offline
                  panixia
                  ok, then i suppose it's adding triangles to fill the gap and probably assignin them the default material, try to assign the grass material also to the group itself and not only to the mesh.
                  as a side note, i would not suggest to use displacement at all for such a large area..
                  • array81A Offline
                    array81
                    I have assign material to group and all group items but I get the same result.
                    This is the model: https://1drv.ms/u/s!AsM-9m6nUHA9qTnr9qFgnsQdk4LD
                    This is the grass v-ray material: https://1drv.ms/u/s!AsM-9m6nUHA9qTpQIcNlENyawbhQ
                    • panixiaP Offline
                      panixia
                      i can't test the material because i don't have vray on sketchup, but i gave a quick look at the model..
                      as a good modeling practice, i STRONGLY reccommend to drop all of you geometry to layer 0 (ALWAYS)
                      in your model the displaced geometry is assigned to different layes (some geometry is on layer 0, other is on terrain layer) use group and soubgroups (or components) to manage layers and leave edges and faces assigned to layer 0..
                      not sure this is causing this specific problem (can't test) but it may cause all sort of problems and odd bugs within sketchup.
                      another thing you can try, is to smooth the geometry (the mesh is actually hard edged) and see if it helps.
                      i think the main problem however, is the missing of a proper uv-map (causing discontinuity in texture, see screenshot of your model below) and the fact that the material is not applyed to the back face too..
                      i really suggest to fix both problems at once using the tru paint plugin (apply "natural" mapping with the "front&back" opttion ticked). that should clean your displacement.
                      perรฒ non ho capito chi te la fa fare a usare il displacement, usa i proxy di vray con qualche plugin come ad esempio skatter ($$) o raytracer (free) o component spray (free) per spargere l'erba e le piante in vario modo.. viene meglio, piรน veloce e consumi tonnellate di RAM di meno ๐Ÿ˜›
                      edit - missing screenshot
                        Why not use the free and more easy Visualizer? ๐Ÿ’š
                        http://getvisualizer.com/images/woody_airstream_sheet2.jpg
                        • array81A Offline
                          array81
                          Thanks for "skatter ($$) o raytracer (free) o component spray (free)" suggestion.
                          Visualizer doesn't work on SketchUp 2016.
                            This Visualizer + That: works for SU 2016!
                            And see here how make your paths for input files! ๐Ÿค“
                            See all the page!
                            (sorry in French but paths are multilanguages ! ๐Ÿ˜„
                            Careful there are different Folders "Plugins" !
                              For trees , grass & flowers you have this free one! ๐Ÿ˜‰
                              (Press "Download" button )
                              By TreeMaker
                              http://www.3darcstudio.com/images/master/verdure09.jpg
