    Animator: Parametric Animation plugin - Discussion
    223 Posts 55 Posters 103.2k Views 55 Watching
    • F Offline
      faust07
      This is so great and pushes SketchUp to an high level similar to Sketchy- and MSPhysics. The videos and tutorials show that impressive. Is there somewhere a link to download and to test the plugin?
        It's in beta test Period! Ask Fredo or Rich O Brien...
        • ntxdaveN Offline
          ntxdave
          If you are meaning the Animator plugin, see this thread If you are meaning the Twilight Render software, they have stated that they will be posting a link to their software sometime today. You will have to have the Pro version though (at least that is my understanding).
          Press F1...thank me later
          • elfredE Offline
            elfred
            @thomthom said:
            New round of donations for Fredo - anyone?
            Could You send me info how to do that?
            This many is treasure who earned our support.
            • W Offline
              wagoneer
              I'm eagerly awaiting your newest plug-in Fredo. Having been tasked with creating some animations, SketchUp is where I wish to do it so your excellent tools help enormously.
              One question, will Animate have a path tool so I could make my shapes/groups follow paths other than straight lines?
              Kelly
              • cottyC Offline
                cotty
                One fast way...
                my SketchUp gallery
                • Bob JamesB Offline
                  Bob James
                  I get:
                  "You are not authorised to read this forum." 😞
                    JohnDurnan
                    @thomthom said:
                    @fredo6 said:
                    But I don't know how to reach the others
                    PM me who you are looking for - I'll see what I can do. I have the ChaosGroup contacts for sure - but I should be able to obtain other as well.
                    Oh, that would be ideal. If this could work with Shaderlight renderer, my world would be complete. I'm currently using "Keyframe Animation", however, it will not work with Shaderlight. Therefore, I cannot complete my animations by rendering them. The still only look like cartoons. Thank you for all of your efforts with this!
                    • fredo6F Offline
                      I need to find a contact there (which I don't have at the moment), in case they would be interested.
                      • W Offline
                        whiterabbit
                        is there a newer version of the animator plugin, I was trying it out (great) but since upgrading to 2017 it says it has expired. I tried it back in 2016, same message. How might it be possible to get the latest version. Is it available for purchase?
                        • fredo6F Offline
                          The latest version is now on the PluginStore
                          The discussion forum on Animator is also public.
                          Latest version is Animator v1.2h, which requires LibFredo6 7.2h.
                          • MALAISEM Offline
                            MALAISE
                            Hello Fredo
                            Small enhancement (if possible): could you replace red crosses against green slash
                            inside Maintenance of Animator Objects ?
                            The Help comment is confusing ( you delete a red cross !)
                            Pierre
                            • fredo6F Offline
                              These are ACTION buttons, not STATUS buttons.
                              So the red cross is to delete, the green check mark is to undelete, and the red color for the whole row indicates the status.
                              If you are better icons however, I am interested.
                              • MALAISEM Offline
                                MALAISE
                                Could such a picture fit the function ?
                                • fredo6F Offline
                                  Very nice icons, but I would (and maybe will when appropriate) use them for MERGE and SPLIT.
                                  However, if the single rectangle is replaced by a red bin, that would be perfect
                                  • MALAISEM Offline
                                    MALAISE
                                    Like that ?
                                    Cheers
                                    Pierre
                                    • fredo6F Offline
                                      That's the idea. But then
                                      • could you replace the 3 parallelograms by one
                                      • could you make the arrow a little bit bigger and contrasted so that they are visible when the icons are of reduced size (i.e. fitting in the table).
                                      • MALAISEM Offline
                                        MALAISE
                                        Here, you'll find some material.
                                        Cheers
                                        Pierre
                                          kostas_designer
                                          Fredo, this is absolutely marvellous, the best plugin after Fredoscale imho.
                                          Just got my hands on, i'll definitely dig more on the next days.
                                          Here's a first attempt on a project I'm currently working on:
                                          Very, very promising 👍 👍 👍
                                          Again, my best congrats to you.
                                            kostas_designer
                                            This is getting even more interesting... ☀
                                            • 11
                                            • 12
                                            • 7 / 12
