    Animator: Parametric Animation plugin - Discussion
    229 Posts 56 Posters 130.7k Views 55 Watching
    • duanekempD
      duanekemp
      "I publish here video tutorials showing some features from Animator"
      Excellent tutorial help videos. Thank you so very much for taking the time to do these.
      Duane Kemp
      Kemp Productions
      Puidoux, Switzerland
      Gallery:
      https://duanekemp.artstation.com/
      • F
        faust07
        This is so great and pushes SketchUp to an high level similar to Sketchy- and MSPhysics. The videos and tutorials show that impressive. Is there somewhere a link to download and to test the plugin?
          It's in beta test Period! Ask Fredo or Rich O Brien...
          • ntxdaveN
            ntxdave
            If you are meaning the Animator plugin, see this thread If you are meaning the Twilight Render software, they have stated that they will be posting a link to their software sometime today. You will have to have the Pro version though (at least that is my understanding).
            Press F1...thank me later
            • elfredE
              elfred
              @thomthom said:
              New round of donations for Fredo - anyone?
              Could You send me info how to do that?
              This many is treasure who earned our support.
              • W
                wagoneer
                I'm eagerly awaiting your newest plug-in Fredo. Having been tasked with creating some animations, SketchUp is where I wish to do it so your excellent tools help enormously.
                One question, will Animate have a path tool so I could make my shapes/groups follow paths other than straight lines?
                Kelly
                • cottyC
                  cotty
                  One fast way...
                  my SketchUp gallery
                  • Bob JamesB
                    Bob James
                    I get:
                    "You are not authorised to read this forum." 😞
                      JohnDurnan
                      @thomthom said:
                      @fredo6 said:
                      But I don't know how to reach the others
                      PM me who you are looking for - I'll see what I can do. I have the ChaosGroup contacts for sure - but I should be able to obtain other as well.
                      Oh, that would be ideal. If this could work with Shaderlight renderer, my world would be complete. I'm currently using "Keyframe Animation", however, it will not work with Shaderlight. Therefore, I cannot complete my animations by rendering them. The still only look like cartoons. Thank you for all of your efforts with this!
                      • fredo6F
                        I need to find a contact there (which I don't have at the moment), in case they would be interested.
                        • W
                          whiterabbit
                          is there a newer version of the animator plugin, I was trying it out (great) but since upgrading to 2017 it says it has expired. I tried it back in 2016, same message. How might it be possible to get the latest version. Is it available for purchase?
                          • fredo6F
                            The latest version is now on the PluginStore
                            The discussion forum on Animator is also public.
                            Latest version is Animator v1.2h, which requires LibFredo6 7.2h.
                            • MALAISEM
                              MALAISE
                              Hello Fredo
                              Small enhancement (if possible): could you replace red crosses against green slash
                              inside Maintenance of Animator Objects ?
                              The Help comment is confusing ( you delete a red cross !)
                              Pierre
                              • fredo6F
                                These are ACTION buttons, not STATUS buttons.
                                So the red cross is to delete, the green check mark is to undelete, and the red color for the whole row indicates the status.
                                If you are better icons however, I am interested.
                                • MALAISEM
                                  MALAISE
                                  Could such a picture fit the function ?
                                  • fredo6F
                                    Very nice icons, but I would (and maybe will when appropriate) use them for MERGE and SPLIT.
                                    However, if the single rectangle is replaced by a red bin, that would be perfect
                                    • MALAISEM
                                      MALAISE
                                      Like that ?
                                      Cheers
                                      Pierre
                                      • fredo6F
                                        That's the idea. But then
                                        • could you replace the 3 parallelograms by one
                                        • could you make the arrow a little bit bigger and contrasted so that they are visible when the icons are of reduced size (i.e. fitting in the table).
                                        • MALAISEM
                                          MALAISE
                                          Here, you'll find some material.
                                          Cheers
                                          Pierre
                                          • K
                                            kostas_designer
                                            Fredo, this is absolutely marvellous, the best plugin after Fredoscale imho.
                                            Just got my hands on, i'll definitely dig more on the next days.
                                            Here's a first attempt on a project I'm currently working on:
                                            Very, very promising 👍 👍 👍
                                            Again, my best congrats to you.
                                            • 11
                                            • 12
                                            • 7 / 12
