    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 630.3k Views 155 Watching
    • JQLJ Offline
      JQL
      Fredo,
      Would it be easy to have normal push pull Taper with an angle or a offset distance instead of exclusivelly by ratio? It would be a nice feature to have for chanfering faces outside their plane with a double click. (I love this double click through groups/components)
      www.casca.pt
      Visit us on facebook!
        bapito
        Where do i download it!!!???!!!
          See the first post of this thread. It is clearly spelled out with bold type and links.
            Arctura
            Hi I'm having a small issue that I can't for the life of me understand.
            I'm extruding the wall of a truncated cone, or more like a rounded plate that along with 11 other identical plates will make up the cone. I'm trying to make flanges around the sides of one plate to then instance it, but the sides keep intersecting and I can't seem to control them! 😞
            I did manage to get it right at first, but there were some other issues with the model so I have restarted and this time around I can't get it to work.
            I'm using Joint Push Pull and Round Push Pull.
            Description of intersection problem
            • PixeroP Offline
              Pixero
              I'm getting this error message when trying to Joint Push pull:
              ` [/Date: 21-Sep-16 09:11:28
              An error occurred in Joint Push Pull
              Error in generation of the geometry
              undefined method `smooth?' for nil:NilClass
              JointPushPullGeometry.rb: 1107 -- block in geometry_coplanar_edges_overhang
              JointPushPullGeometry.rb: 1105 -- each
              JointPushPullGeometry.rb: 1105 -- each_with_index
              JointPushPullGeometry.rb: 1105 -- geometry_coplanar_edges_overhang
              JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges
              JointPushPullGeometry.rb: 352 -- each
              JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges
              JointPushPullGeometry.rb: 214 -- robot_call_action
              JointPushPullGeometry.rb: 177 -- geometry_robot_exec
              JointPushPullGeometry.rb: 160 -- geometry_robot
              JointPushPullGeometry.rb: 75 -- block in geometry_execute
              Lib6Operation.rb: 332 -- call
              Lib6Operation.rb: 332 -- step_geometry
              Lib6Operation.rb: 374 -- start_execution
              JointPushPullGeometry.rb: 75 -- geometry_execute
              JointPushPullTool.rb: 892 -- go_preview_or_geom
              JointPushPullTool.rb: 698 -- dragging_stop
              JointPushPullTool.rb: 1320 -- onLButtonUp`
              • fredo6F Offline
                @pixero
                Thanks for signaling. This seems to be an unusual case.
                Anyway, I have fixed the problem and will re-release soon.
                  surfmike
                  Hi. I'm having a problem with the plugin gui showing up really small in SU. See attached picture.
                  I'm on SU2016, OS X 10.9.5.
                  How can I make it bigger?
                  //Mike
                  it's small...
                  • fredo6F Offline
                    //Mike
                    [attachment=0:26p179xb]<!-- ia0 -->Screen Shot 2016-11-26 at 11.35.17.png<!-- ia0 -->[/attachment:26p179xb]
                    Mike,
                    If you go to Windows > libFredo6 Settings... > Default Parameters..., you will find an option "Retina Screen" in the section "Palette Configuration".
                    If you check the option, you should get the palette buttons bigger (x 2). However, the text may remain small.
                    If you are OK, and since you are on SU2016, you can help me to see if we can resolve the issue, if you are OK to test some changes in the LibFredo6 library. I was hoping that it would be solved by Sketchup 2017, but that's not the case!
                    Otherwise, other high-dpi screen users have discussed some ways to avoid the issue by system set up. See discussion here.
                    Fredo6
                    • pbacotP Offline
                      What may I be doing wrong. Trying to pull up three surfaces sharing three edges.
                      ate: 30-Nov-16 08:55:30
                      Could not compute valid matrix from points
                      JointPushPullGeometry.rb:: 1169 -- position_material
                      JointPushPullGeometry.rb:: 1169 -- block in geometry_transfer_material_top
                      JointPushPullGeometry.rb:: 1145 -- each
                      JointPushPullGeometry.rb:: 1145 -- geometry_transfer_material_top
                      JointPushPullGeometry.rb:: 337 -- block in geometry_robot_transfer_material
                      JointPushPullGeometry.rb:: 337 -- each
                      JointPushPullGeometry.rb:: 337 -- geometry_robot_transfer_material
                      JointPushPullGeometry.rb:: 212 -- robot_call_action
                      JointPushPullGeometry.rb:: 177 -- geometry_robot_exec
                      JointPushPullGeometry.rb:: 160 -- geometry_robot
                      JointPushPullGeometry.rb:: 75 -- block in geometry_execute
                      Lib6Operation.rb:: 332 -- call
                      Lib6Operation.rb:: 332 -- step_geometry
                      Lib6Operation.rb:: 374 -- start_execution
                      JointPushPullGeometry.rb:: 75 -- geometry_execute
                      JointPushPullTool.rb:: 890 -- go_preview_or_geom
                      JointPushPullTool.rb:: 696 -- dragging_stop
                      JointPushPullTool.rb:: 1318 -- onLButtonUp
                      • pbacotP Offline
                        I guessed that although it looked simple, there might be some errant geometry from making the faces. I grouped the faces and ran TT Cleanup3 and that fixed it.
                          surfmike
                          //Mike
                          [attachment=0:leehgwfs]<!-- ia0 -->Screen Shot 2016-11-26 at 11.35.17.png<!-- ia0 -->[/attachment:leehgwfs]
                          Mike,
                          Fredo6
                          Hi Fredo,
                          Sorry for late response.
                          Tried it.
                          The field/icons becme bigger.
                          Still small text size.
                          /Mike
                            Kawet
                            Hi Fredo,
                            I am a beginner in the use of Sketchup so maybe I did a bad manipulation, but for me, the installation of plugins JoinPushPull and Tools on Surface doesn't work (signature obsolete).
                            Do you have an explanation?
                            My version of SU is 17.1.173 and I'm on Mac.
                            Thank you for your help.
                            Kawet
                            • jujuJ Offline
                              juju
                              The plugin vetting process put in place with SU2017 calls for signatures. Just because a plugin / extension shows "outdated signature" or "unsigned" doesn't mean it won't work, it only controls what is to be loaded. If you're super paranoid and have set up SU2017 to only load signed plugins / extenstions then trying to load an unsigned / out of dated signature plugin / extenstion won't work. However if your plugin / extension loading setup is unrestricted then these will load.
                                Kawet
                                Hi Juju,
                                Thank you, i'm not ''super paranoid'', but i like to understand ... and its my first day on SU !
                                Now i understand.
                                ty
                                • fredo6F Offline
                                  @kawet said:
                                  Hi Fredo,
                                  Kawet
                                  I will republish JPP with SU2017 certification.
                                  • jujuJ Offline
                                    juju
                                    @kawet said:
                                    Hi Juju,
                                    Now i understand.
                                    ty
                                    There is nothing wrong with asking questions to understand. Anyhows, welcome to SketchUp! I must warn you, it is addictive!
                                    As long as you get your plugins from reputable sources you should not have problems with rogue plugins and, as such, be able to leave the plugin/extension loading settings to unrestricted.
                                    Happy Sketch(Up)ing!
                                    • shukritobiS Offline
                                      shukritobi
                                      Hey Fredo,
                                      great tool! I've been using this plugin since 2 years ago. However, I've encountered a bug when trying to use JointPushPull.
                                      I was trying to extrude this plane:
                                      Date: 02-Feb-17 16:36:14
                                      JointPushPullTool.rb: 931 -- modify_execute
                                      JointPushPullTool.rb: 944 -- modify_offset
                                      JointPushPullTool.rb: 2081 -- action_from_VCB
                                      JointPushPullTool.rb: 2058 -- onUserText
                                      Here's the file: jpp error.skp
                                      I've encountered quite a number of errors, but today I decided want to learn more what's going on.
                                      • fredo6F Offline
                                        @shukritobi
                                        Can you attach the model which has the bugs.
                                        The one you attached does not provoke errors, and is different from what you show on the picture.
                                        • fredo6F Offline
                                          NEW RELEASE: JointPushPull Interactive v3.6a - 02 Feb 17
                                          JointPushPull Interactive 3.6a is certified for SU2017 and includes a few bug fixing in the generation of geometry.
                                          See main post of this thread for Download of JointPushPull.
                                            Rafal76
                                            I've just download the JointPushPull and LibFredo 6 but I don"t see the JointPushPull anywhere. I have Mac and I'm working with Sketchup 2017. Can somebody help me with that?
                                            • 11
                                            • 12
                                            • 30
                                            • 31
                                            • 10 / 31
