    Teenager's room
    28 Posts 6 Posters 4.1k Views 6 Watching
    • Bryan KB Offline
      Excellent work as always!
        Than you will get an equirectangular panorama, which you can use for any panoviewer
        Ok thanks! So what is the name of your panoviewer? πŸ˜„
        Does it free ?
          Maybe this can interest you! (Minute 2.05)
            Found this πŸ˜„ move the mouse!
            • pbacotP Offline
              That's pretty nice. I'd like to try that. Since you can look around, it feels like you're being swept along helplessly. It'd be fun to end it going down a drain.
                In the other side I don't know if it's the same thing ?
                We’re sad to announce that Vrideo is shutting down as of today
                • jo-keJ Offline
                  jo-ke
                  really interessting, but my Photoshop (CC2017) looks differnt. I don't have this layer mode
                  My Panoviewer to publish is Pano2VR
                  http://www.zz7.de
                    It's not Photoshop, it's Affinity Photo! (Free beta for PC! πŸ˜‰
                    • jo-keJ Offline
                      jo-ke
                      ah OK 😎 that makes sense.
                      http://www.zz7.de
                        measuredmove
                        Didn't want to lose this thread-it has a lot of great info to save.
                        Just wondering if all of your renderings posted are created with Twilight Render?
                        My 3D Catalogue
                        https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
                        SU8/Brighter3D/Gimp/SimLab Composer
                        • jo-keJ Offline
                          jo-ke
                          Yes I am using twilighttender for many years now. Most of them are prepared with twilight render and rendered with Kerkythea. I have a couple of old PCs. they do the render work with KT, while I am preparing the new renderings with SU/TWL
                          http://www.zz7.de
                            measuredmove
                            So modeled in SU and material/lighting setup in Twilight Render then exported to KT to render?
                            Any reason not to complete the render in TW?
                            When I tried it (briefly) many years ago I found the output to be 'harsh' looking but it may have been a lack of time/commitment to properly learn the program. KT was a finer output but when clients wanted animations the time required to process a project was way too daunting.
                            My 3D Catalogue
                            • jo-keJ Offline
                              jo-ke
                              I am doing a couple of projects at the same time.
                              I can work on with SU while the other workstations do the renderings with KT
                              So I am free to work on my other projects.
                              http://www.zz7.de
                                measuredmove
                                This is a great idea.
                                Thank you passing this on - to use the best tools for the job.
                                My 3D Catalogue
                                  measuredmove
                                  Sorry..thought I was all done..but have 2 more questions.
                                  Do you re-import the KT rendered image back into TW to create the pano and are hotspots created in TW or in Pano2VR?
                                  I'll say Thanks in advance.
                                  My 3D Catalogue
                                  • jo-keJ Offline
                                    jo-ke
                                    No no, it is very simple.
                                    I do all settings in Twilight, then I make a special folder "kerky", to put the xml file and all the rest (pics, ies,...) inside. this is a one way folder. after Export everything with SU and TWL is done.
                                    Then I open KT, open the xml. Then I render each scene, one after another. The output is allready equirectangular, because I have choosen "spherical" in twilght.
                                    Be carful with layers. The xml stores the locations of the scenes but only the layers of the current scene.
                                    http://www.zz7.de
                                      In term of minutes time's render : Twillight is more /less than KT ?
                                        measuredmove
                                        Again, Thanks
                                        It's been a while since I used KT but I will try it out on a small project.
                                        My 3D Catalogue
                                        • jo-keJ Offline
                                          jo-ke
                                          rendertime should be the same. But the advantage is the independent renderengine. It can still render all night long at a seperate workstation and I can continue modelling in SU.
                                          http://www.zz7.de
                                            Thx for the infos!
