    Teenager's room
    28 Posts 6 Posters 4.1k Views 6 Watching
    • jo-keJ Offline
      jo-ke
      Twilight Render
      http://www.zz7.de
      • pbacotP Offline
        too neat!
          Twilight Render
          Have you a link for a tutorial for this special animation rendering images?
          • jo-keJ Offline
            jo-ke
            yes of course.
            choose aspect ratio 1:2 for example 6000:3000 and spherical as render mode
            Than you will get an equirectangular panorama, which you can use for any panoviewer.
            http://www.zz7.de
            • Bryan KB Offline
              Excellent work as always!
                Ok thanks! So what is the name of your panoviewer? ๐Ÿ˜„
                Does it free ?
                  Maybe this can interest you! (Minute 2.05)
                    Found this ๐Ÿ˜„ move the mouse!
                    • pbacotP Offline
                      That's pretty nice. I'd like to try that. Since you can look around, it feels like you're being swept along helplessly. It'd be fun to end it going down a drain.
                        In the other side I don't know if it's the same thing ?
                        Weโ€™re sad to announce that Vrideo is shutting down as of today
                        • jo-keJ Offline
                          jo-ke
                          really interessting, but my Photoshop (CC2017) looks differnt. I don't have this layer mode
                          My Panoviewer to publish is Pano2VR
                          http://www.zz7.de
                            It's not Photoshop, it's Affinity Photo! (Free beta for PC! ๐Ÿ˜‰
                            • jo-keJ Offline
                              jo-ke
                              ah OK ๐Ÿ˜Ž that makes sense.
                              http://www.zz7.de
                                measuredmove
                                Didn't want to lose this thread-it has a lot of great info to save.
                                Just wondering if all of your renderings posted are created with Twilight Render?
                                My 3D Catalogue
                                https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
                                SU8/Brighter3D/Gimp/SimLab Composer
                                • jo-keJ Offline
                                  jo-ke
                                  Yes I am using twilighttender for many years now. Most of them are prepared with twilight render and rendered with Kerkythea. I have a couple of old PCs. they do the render work with KT, while I am preparing the new renderings with SU/TWL
                                  http://www.zz7.de
                                    measuredmove
                                    So modeled in SU and material/lighting setup in Twilight Render then exported to KT to render?
                                    Any reason not to complete the render in TW?
                                    When I tried it (briefly) many years ago I found the output to be 'harsh' looking but it may have been a lack of time/commitment to properly learn the program. KT was a finer output but when clients wanted animations the time required to process a project was way too daunting.
                                    My 3D Catalogue
                                    • jo-keJ Offline
                                      jo-ke
                                      I am doing a couple of projects at the same time.
                                      I can work on with SU while the other workstations do the renderings with KT
                                      So I am free to work on my other projects.
                                      http://www.zz7.de
                                        measuredmove
                                        This is a great idea.
                                        Thank you passing this on - to use the best tools for the job.
                                        My 3D Catalogue
                                          measuredmove
                                          Sorry..thought I was all done..but have 2 more questions.
                                          Do you re-import the KT rendered image back into TW to create the pano and are hotspots created in TW or in Pano2VR?
                                          I'll say Thanks in advance.
                                          My 3D Catalogue
                                          • jo-keJ Offline
                                            jo-ke
                                            No no, it is very simple.
                                            I do all settings in Twilight, then I make a special folder "kerky", to put the xml file and all the rest (pics, ies,...) inside. this is a one way folder. after Export everything with SU and TWL is done.
                                            Then I open KT, open the xml. Then I render each scene, one after another. The output is allready equirectangular, because I have choosen "spherical" in twilght.
                                            Be carful with layers. The xml stores the locations of the scenes but only the layers of the current scene.
                                            http://www.zz7.de
