    Teenager's room
    28 Posts 6 Posters 4.1k Views 6 Watching
      Maybe this can interest you! (Minute 2.05)
        Found this πŸ˜„ move the mouse!
        • pbacotP
          That's pretty nice. I'd like to try that. Since you can look around, it feels like you're being swept along helplessly. It'd be fun to end it going down a drain.
            In the other side I don't know if it's the same thing ?
            We’re sad to announce that Vrideo is shutting down as of today
            • jo-keJ
              jo-ke
              really interessting, but my Photoshop (CC2017) looks differnt. I don't have this layer mode
              My Panoviewer to publish is Pano2VR
              http://www.zz7.de
                It's not Photoshop, it's Affinity Photo! (Free beta for PC! πŸ˜‰
                • jo-keJ
                  jo-ke
                  ah OK 😎 that makes sense.
                  http://www.zz7.de
                    measuredmove
                    Didn't want to lose this thread-it has a lot of great info to save.
                    Just wondering if all of your renderings posted are created with Twilight Render?
                    My 3D Catalogue
                    https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
                    SU8/Brighter3D/Gimp/SimLab Composer
                    • jo-keJ
                      jo-ke
                      Yes I am using twilighttender for many years now. Most of them are prepared with twilight render and rendered with Kerkythea. I have a couple of old PCs. they do the render work with KT, while I am preparing the new renderings with SU/TWL
                      http://www.zz7.de
                        measuredmove
                        So modeled in SU and material/lighting setup in Twilight Render then exported to KT to render?
                        Any reason not to complete the render in TW?
                        When I tried it (briefly) many years ago I found the output to be 'harsh' looking but it may have been a lack of time/commitment to properly learn the program. KT was a finer output but when clients wanted animations the time required to process a project was way too daunting.
                        My 3D Catalogue
                        • jo-keJ
                          jo-ke
                          I am doing a couple of projects at the same time.
                          I can work on with SU while the other workstations do the renderings with KT
                          So I am free to work on my other projects.
                          http://www.zz7.de
                            measuredmove
                            This is a great idea.
                            Thank you passing this on - to use the best tools for the job.
                            My 3D Catalogue
                              measuredmove
                              Sorry..thought I was all done..but have 2 more questions.
                              Do you re-import the KT rendered image back into TW to create the pano and are hotspots created in TW or in Pano2VR?
                              I'll say Thanks in advance.
                              My 3D Catalogue
                              • jo-keJ
                                jo-ke
                                No no, it is very simple.
                                I do all settings in Twilight, then I make a special folder "kerky", to put the xml file and all the rest (pics, ies,...) inside. this is a one way folder. after Export everything with SU and TWL is done.
                                Then I open KT, open the xml. Then I render each scene, one after another. The output is allready equirectangular, because I have choosen "spherical" in twilght.
                                Be carful with layers. The xml stores the locations of the scenes but only the layers of the current scene.
                                http://www.zz7.de
                                  In term of minutes time's render : Twillight is more /less than KT ?
                                    measuredmove
                                    Again, Thanks
                                    It's been a while since I used KT but I will try it out on a small project.
                                    My 3D Catalogue
                                    • jo-keJ
                                      jo-ke
                                      rendertime should be the same. But the advantage is the independent renderengine. It can still render all night long at a seperate workstation and I can continue modelling in SU.
                                      http://www.zz7.de
                                        Thx for the infos!
                                        • P
                                          psylo
                                          Nobody noticed the pop up screen ! πŸ˜›
                                          • jo-keJ
                                            jo-ke
                                            I was also confused. No idea what happend to that notebook. I will never use it again.
                                            http://www.zz7.de
