    Teenager's room
    28 Posts 6 Posters 3.5k Views 6 Watching
    • jo-keJ Offline
      jo-ke
      @pilou said:
      Maybe this can interest you! (Minute 2.05)
      really interessting, but my Photoshop (CC2017) looks differnt. I don't have this layer mode
      My Panoviewer to publish is Pano2VR
      http://www.zz7.de
        It's not Photoshop, it's Affinity Photo! (Free beta for PC! πŸ˜‰
        • jo-keJ Offline
          jo-ke
          ah OK 😎 that makes sense.
          http://www.zz7.de
            measuredmove
            Didn't want to lose this thread-it has a lot of great info to save.
            Just wondering if all of your renderings posted are created with Twilight Render?
            My 3D Catalogue
            https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
            SU8/Brighter3D/Gimp/SimLab Composer
            • jo-keJ Offline
              jo-ke
              Yes I am using twilighttender for many years now. Most of them are prepared with twilight render and rendered with Kerkythea. I have a couple of old PCs. they do the render work with KT, while I am preparing the new renderings with SU/TWL
              http://www.zz7.de
                measuredmove
                So modeled in SU and material/lighting setup in Twilight Render then exported to KT to render?
                Any reason not to complete the render in TW?
                When I tried it (briefly) many years ago I found the output to be 'harsh' looking but it may have been a lack of time/commitment to properly learn the program. KT was a finer output but when clients wanted animations the time required to process a project was way too daunting.
                My 3D Catalogue
                • jo-keJ Offline
                  jo-ke
                  I am doing a couple of projects at the same time.
                  I can work on with SU while the other workstations do the renderings with KT
                  So I am free to work on my other projects.
                  http://www.zz7.de
                    measuredmove
                    This is a great idea.
                    Thank you passing this on - to use the best tools for the job.
                    My 3D Catalogue
                      measuredmove
                      Sorry..thought I was all done..but have 2 more questions.
                      Do you re-import the KT rendered image back into TW to create the pano and are hotspots created in TW or in Pano2VR?
                      I'll say Thanks in advance.
                      My 3D Catalogue
                      • jo-keJ Offline
                        jo-ke
                        No no, it is very simple.
                        I do all settings in Twilight, then I make a special folder "kerky", to put the xml file and all the rest (pics, ies,...) inside. this is a one way folder. after Export everything with SU and TWL is done.
                        Then I open KT, open the xml. Then I render each scene, one after another. The output is allready equirectangular, because I have choosen "spherical" in twilght.
                        Be carful with layers. The xml stores the locations of the scenes but only the layers of the current scene.
                        http://www.zz7.de
                          In term of minutes time's render : Twillight is more /less than KT ?
                            measuredmove
                            Again, Thanks
                            It's been a while since I used KT but I will try it out on a small project.
                            My 3D Catalogue
                            • jo-keJ Offline
                              jo-ke
                              rendertime should be the same. But the advantage is the independent renderengine. It can still render all night long at a seperate workstation and I can continue modelling in SU.
                              http://www.zz7.de
                                Thx for the infos!
                                  psylo
                                  Nobody noticed the pop up screen ! πŸ˜›
                                  • jo-keJ Offline
                                    jo-ke
                                    I was also confused. No idea what happend to that notebook. I will never use it again.
                                    http://www.zz7.de
                                    • 2 / 2
