    Foundation Plugin
    439 Posts 15 Posters 415.1k Views 15 Watching
      MtnArch
      What I've done in the past (and seems to work the best) is simply frame it as a door opening (36" or 48") with a 4x4 (or 4x6) with the top flush with the double top plate.
      Highest Regards,
      Alan T. Hendry, RA
      Architect
      • medeekM Offline
        medeek
        Something like this?
        http://biotoxinjourney.com/wp-content/uploads/2016/02/Sealed-Crawl-Space.jpg
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • facerF Offline
          facer
          Medeek,
          I am curious about the "white" membrane, is there to be a concrete slab poured?
          If so what was the construction sequence?
          If it is a moisture barrier how is it protected?
            MtnArch
            Nathaniel -
            Yep, that's basically it (though I've also see the top plates lapped into the header as well).
            Highest Regards,
            Alan T. Hendry, RA
            Architect
            • medeekM Offline
              medeek
              Version 1.0.3 - 08.28.2016
              • Enabled interior bearing wall(s) with strip footing.
              http://design.medeek.com/resources/images/foundation_su10_800.jpg
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              I still need to enable the ability to add framed openings into the interior stud walls. Interior stud/bearing walls can be created with single or double top plates and can be full span or partial spanning as shown in the image above.
              Also note that the studs are aligned from the right side of the stemwall foundation edge so that they line up directly under the floor joists.
              design.medeek.com
              • medeekM Offline
                medeek
                My new job has kept me away for the last few weeks so that getting anything done on the plugins has been a real challenge. Even so I've been giving some thought to stepped footings/foundations and would like some input from the designers and architects out there on what is common practice and what they would like to see available for this sort of feature within the plugin.
                http://design.medeek.com/resources/images/foundation_su11_800.jpg
                View mode here:
                3D Warehouse
                Note that I messed up on this model the exterior cripple/pony walls should have only had one top plate so that the combined top plate from the shallow sections and the single top plate would have created the typical double top plate.
                design.medeek.com
                • medeekM Offline
                  medeek
                  One question I've had is how much should the stemwall overshoot the step in the footing before stepping down itself? I've seen different ratios used (ie. rise/run) but I'm trying to find a consensus on what is common practice.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    A typical step in the footing might look something like this:
                    http://design.medeek.com/images/misc2/STEPPED_FOOTING1.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      I've repackaged the .rbz file this evening so that when it installs into SU 2017 the extension will have the appropriate hash file and appear as "signed". The foundation plugin may have the same issue with hashed file as the truss plugin, however it does not in any way affect the functionality of the plugin.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.0.4 - 11.27.2016
                        • Enabled rebar and mesh reinforcement for slab on grade foundations.
                        http://design.medeek.com/resources/images/foundation_su13_800.jpg
                        http://design.medeek.com/resources/images/foundation_su12_800.jpg
                        Footing reinforcement is #3 - #8 bar.
                        Slab reinforcement is welded wire mesh or #3 - #5 bar.
                        European metric sizes are available in the metric mode.
                        View model here:
                        3D Warehouse
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          There are quite a few options to play with, rebar size and quantity. Notice in this example I've used #3 bar for the slab reinforcement rather than the mesh and I've doubled up bars on top and bottom of the footing (#5 bars):
                          On a related note does anyone have a good texture for rebar that they would be willing to share.
                          design.medeek.com
                          • pbacotP Offline
                            You asked about the piers. A common design is 16"-24" square piers with top at grade. with a smaller block eg. 8x8 to raise the post above grade. the girders are often 4x6 so the spacing is about 6'-7' o.c. Larger spans mean larger beams & pads. And of course soils, as you mention may mean larger pads. I notice on your grade beam design the posts are sitting on top of the grade beam with no blocks or pedestals. The way you've drawn it, this would also be the subgrade height and posts are generally raised above the subgrade, even if they are pressure treated.
                            I wonder how many contractors actually do monolithic garage slabs as opposed to T-footings and "floating" slabs? They're both used in California.
                            • pbacotP Offline
                              Good question but I'd pose it the other way around. The top of the stemwall is based on grade and building design, then the footing step would be placed accordingly.
                              • medeekM Offline
                                medeek
                                With regards to Posts and their footings I usually see this sort of configuraton:
                                Post, pedestal and square footing
                                I will make the post, pedestal, reinforcement and post base bracket optional. The actual footing will not be optional.
                                I would like to use pre-drawn post base components (ie. Simpson Strong-Tie) but I have to figure out how to import those into the model with the API
                                design.medeek.com
                                • pbacotP Offline
                                  That looks good, but for a round pedestal they usually leave the Sonotube on. 😉
                                    Garry K
                                    You should be consistent with your post.skp files
                                    Probably have the center at the bottom of the post sitting on the ORIGIN
                                    def get_post_def(post_name)
                                      model = Sketchup.active_model()
                                      definitions = model.definitions
                                      definitions.each{ |my_def| return my_def if (my_def.name == post_name && my_def.valid?)}
                                      filename = File.join(path_to_your_plugin, "posts", "#{post_name}.skp")
                                      definitions.load(filename)
                                    Then you need to place the post
                                    # get the post definition
                                    post_def = get_post_def(post_name)
                                    # where pt is where you want to place it
                                    tr = Geom;;Transformation.new(pt)
                                    instance = group.entities.add_instance(post_def, tr)
                                    • medeekM Offline
                                      medeek
                                      Version 1.0.5 - 12.01.2016
                                      • Enabled reinforcement for stemwall foundations.
                                      http://design.medeek.com/resources/images/foundation_su14_800.jpg
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I've been thinking about adding in a retaining wall feature that auto sizes the rebar and qty. based on my typical retaining wall details:
                                        http://res.cloudinary.com/engineering-com/image/upload/v1470879435/tips/RETAINING_WALL_DETAILS_loycxe.jpg
                                        For stemwall foundations I typically check the footing width (bearing pressure) and min. rebar for shrink (ACI 318-11), see engineering calcs per this PDF:
                                        http://design.medeek.com/resources/footing/STEMWALL_FOOTING_CALCULATOR.pdf
                                        I could easily incorporate this type of engineering calculations into the plugin, however I'm still trying to figure out how to have the plugin output PDF reports, or Excel spreadsheets, which would be necessary if engineering reports become part of this plugin.
                                        Same sort of thing with square or rectangular footings can be done:
                                        http://design.medeek.com/resources/footing/SQUAREFOOTING_CALCULATOR.pdf
                                        With stemwalls or pony walls (not necessarily retaining walls) that exceed 24" in height (but not in excess of 48") I like to add #4 bars cont. horizontal at 18" o/c. Logic could be incorporated that adds in additional stemwall and foundation wall rebar per a number of prescriptive criteria, IRC tables etc...
                                        Currently it is entirely up to the users to specify rebar size and qty. with both stemwall and slab on grade foundations.
                                        Stemwall foundations allow you to place rebar at the top of the wall (5" below top, qty. 1,2, or 3 bars) and rebar at the bottom of the wall (3" above bottom, qty, 1,2, or 3 bars). It also allows placement of bar in perimeter footing and interior footings (qty 1,2 or 3 bars). Bar sizes range from #3 to #8 and similar sized metric equivalents for the metric templates, I can always add more sizes if requested.
                                        design.medeek.com
                                        • pbacotP Offline
                                          Nice. I hope the number of sides on the rebar and bends is not so large as to slow down SU! Might be helpful to have on a separate component and layer.
                                          • medeekM Offline
                                            medeek
                                            Some good points pbacot:
                                            1.) I currently have the number of sides on the bends set at default value but I can easily change this to a lesser value if its determined that the file size or speed of SketchUp is becoming impacted.
                                            2.) Layers is something I have been meaning to add into both plugins, or at least the option for layers. It would be nice to have a separate rebar layer.
                                            3.) Currently the rebar is not grouped in any special grouping or component except for the rebar inside of interior stemwall strip footings. For those footings I have setup a component that encompassses the footing, rebar and any post/beam or studwall framing. The reason for this is the ability to copy and paste additional interior footings based on the original one. I could group all of the other rebar and mesh into its own group or component if this seems like a good idea.
                                            design.medeek.com
                                            • 21
                                            • 22
                                            • 5 / 22
