    Foundation Plugin
    451 Posts 15 Posters 580.3k Views 15 Watching
    • medeekM Offline
      medeek
      The current home designer I am working for likes to use 2x4 bearing walls versus a post and beam system in their crawl spaces:
      http://www.callhomeinspector.com/s/cc_images/cache_2922621504.jpg?t=1336939826
      I am wondering how common this method is and if it is something I should add into the foundation plugin as another variant.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • facerF Offline
        facer
        Crawl Space - Access
        Suggest an "access opening" in the stud spacing for any future inspection or maintenance.
        Centre location would be logical, miss one stud and design support for floor joist.
        • medeekM Offline
          medeek
          For a stud wall your right you need access doors or openings. I will make another function that lets one place the opening after the fact, that way they can be located by the user.
          design.medeek.com
          • medeekM Offline
            medeek
            Does anyone have any details showing the access door through a strip footing and bearing stud wall. I have one here but I would be interested in seeing what others use so I can determine the most popular way of framing this up and then implement it.
            design.medeek.com
              MtnArch
              What I've done in the past (and seems to work the best) is simply frame it as a door opening (36" or 48") with a 4x4 (or 4x6) with the top flush with the double top plate.
              Highest Regards,
              Alan T. Hendry, RA
              Architect
              • medeekM Offline
                medeek
                Something like this?
                http://biotoxinjourney.com/wp-content/uploads/2016/02/Sealed-Crawl-Space.jpg
                design.medeek.com
                • facerF Offline
                  facer
                  Medeek,
                  I am curious about the "white" membrane, is there to be a concrete slab poured?
                  If so what was the construction sequence?
                  If it is a moisture barrier how is it protected?
                    MtnArch
                    Nathaniel -
                    Yep, that's basically it (though I've also see the top plates lapped into the header as well).
                    Highest Regards,
                    Alan T. Hendry, RA
                    Architect
                    • medeekM Offline
                      medeek
                      Version 1.0.3 - 08.28.2016
                      • Enabled interior bearing wall(s) with strip footing.
                      http://design.medeek.com/resources/images/foundation_su10_800.jpg
                      View model here:
                      3D Warehouse
                      (3dwarehouse.sketchup.com)
                      I still need to enable the ability to add framed openings into the interior stud walls. Interior stud/bearing walls can be created with single or double top plates and can be full span or partial spanning as shown in the image above.
                      Also note that the studs are aligned from the right side of the stemwall foundation edge so that they line up directly under the floor joists.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        My new job has kept me away for the last few weeks so that getting anything done on the plugins has been a real challenge. Even so I've been giving some thought to stepped footings/foundations and would like some input from the designers and architects out there on what is common practice and what they would like to see available for this sort of feature within the plugin.
                        http://design.medeek.com/resources/images/foundation_su11_800.jpg
                        View mode here:
                        3D Warehouse
                        Note that I messed up on this model the exterior cripple/pony walls should have only had one top plate so that the combined top plate from the shallow sections and the single top plate would have created the typical double top plate.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          One question I've had is how much should the stemwall overshoot the step in the footing before stepping down itself? I've seen different ratios used (ie. rise/run) but I'm trying to find a consensus on what is common practice.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            A typical step in the footing might look something like this:
                            http://design.medeek.com/images/misc2/STEPPED_FOOTING1.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I've repackaged the .rbz file this evening so that when it installs into SU 2017 the extension will have the appropriate hash file and appear as "signed". The foundation plugin may have the same issue with hashed file as the truss plugin, however it does not in any way affect the functionality of the plugin.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.0.4 - 11.27.2016
                                • Enabled rebar and mesh reinforcement for slab on grade foundations.
                                http://design.medeek.com/resources/images/foundation_su13_800.jpg
                                http://design.medeek.com/resources/images/foundation_su12_800.jpg
                                Footing reinforcement is #3 - #8 bar.
                                Slab reinforcement is welded wire mesh or #3 - #5 bar.
                                European metric sizes are available in the metric mode.
                                View model here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  There are quite a few options to play with, rebar size and quantity. Notice in this example I've used #3 bar for the slab reinforcement rather than the mesh and I've doubled up bars on top and bottom of the footing (#5 bars):
                                  On a related note does anyone have a good texture for rebar that they would be willing to share.
                                  design.medeek.com
                                  • pbacotP Offline
                                    You asked about the piers. A common design is 16"-24" square piers with top at grade. with a smaller block eg. 8x8 to raise the post above grade. the girders are often 4x6 so the spacing is about 6'-7' o.c. Larger spans mean larger beams & pads. And of course soils, as you mention may mean larger pads. I notice on your grade beam design the posts are sitting on top of the grade beam with no blocks or pedestals. The way you've drawn it, this would also be the subgrade height and posts are generally raised above the subgrade, even if they are pressure treated.
                                    I wonder how many contractors actually do monolithic garage slabs as opposed to T-footings and "floating" slabs? They're both used in California.
                                    • pbacotP Offline
                                      Good question but I'd pose it the other way around. The top of the stemwall is based on grade and building design, then the footing step would be placed accordingly.
                                      • medeekM Offline
                                        medeek
                                        With regards to Posts and their footings I usually see this sort of configuraton:
                                        Post, pedestal and square footing
                                        I will make the post, pedestal, reinforcement and post base bracket optional. The actual footing will not be optional.
                                        I would like to use pre-drawn post base components (ie. Simpson Strong-Tie) but I have to figure out how to import those into the model with the API
                                        design.medeek.com
                                        • pbacotP Offline
                                          That looks good, but for a round pedestal they usually leave the Sonotube on. 😉
                                            Garry K
                                            You should be consistent with your post.skp files
                                            Probably have the center at the bottom of the post sitting on the ORIGIN
                                            def get_post_def(post_name)
                                              model = Sketchup.active_model()
                                              definitions = model.definitions
                                              definitions.each{ |my_def| return my_def if (my_def.name == post_name && my_def.valid?)}
                                              filename = File.join(path_to_your_plugin, "posts", "#{post_name}.skp")
                                              definitions.load(filename)
                                            Then you need to place the post
                                            # get the post definition
                                            post_def = get_post_def(post_name)
                                            # where pt is where you want to place it
                                            tr = Geom;;Transformation.new(pt)
                                            instance = group.entities.add_instance(post_def, tr)
                                            • 22
                                            • 23
                                            • 2 / 23
