    Sketchup 2017 extensions:
    13 Posts 7 Posters 3.2k Views 7 Watching
      andysvision
      Hello, i just installed Sketchup 2017 and im thinking if i can install all this magnificent extensions and plugin this site offers..
      • PixeroP
        Pixero
        You should start with this: http://sketchucation.com/resources/plugin-store-download
          andysvision
          Thank you, i figured it out πŸ˜„
          • jo-keJ
            jo-ke
            Every year with each new version of SU I'm struggeling with the installation of plugins (This is the reason that I am still using SU2015pro)
            Installing sketchucation plugin is the first problem. At preferences I can't find the extention tab.
            How can I intall plugins?
            Where is the plugin Folder?
            I am feeling like a beginner (after 10 years using SU)...
            http://www.zz7.de
              @jo-ke
              In v2017 Extensions are now separated into a separate dialog -
              this is accessed from the menu item:
              Window > 'Extension Manager'
              To Install an RBZ archive use the red-button bottom-left of that dialog, entitled 'Install Extension'...
              Thereafter the installation process is the same as in the earlier versions...
                andysvision
                Hello got to >>> WINDOW ---> Extension Manager ---> down below you will see the Install button .
                Done πŸ˜„
                • jo-keJ
                  jo-ke
                  Ahh! Thank you so much!
                  http://www.zz7.de
                  • jo-keJ
                    jo-ke
                    another question:
                    where is the materialsfolder?
                    http://www.zz7.de
                      @jo-ke said:
                      another question:
                      C:\Users[NAME]\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Materials\
                      Or make your own under Window > Preferences > Files
                      • jo-keJ
                        jo-ke
                        Thank you. I found it!
                        a lot of work. Many plugins doesn't work.
                        Maybe I stay at SU2015 as last year. It took to long to get SU2016 to work. SU2017 seems to be the same problem
                        http://www.zz7.de
                        • jo-keJ
                          jo-ke
                          another question:
                          I am using SU on three places: at home, at work and at my notebook.
                          Is it possible to install the pluginfiles at a special dropbox path, to install all plugins for all desktops at one Folder?
                          It really makes me mad so search 3 times after different plugins...
                          http://www.zz7.de
                          • H
                            harnstein
                            Except for some specific plugins in most cases you can probably just copy the "master" plugins folder over to the two "slaves" folders which will at least save extra searching time.
                            Won't work for some plugins related to third folders data though.
                            And some plugins store local information (settings, custom data) you wouldn't have access to from the two "slaves" computers.
                            still sketchin'
                            • jujuJ
                              juju
                              never copy extensions any longer, that's asking for trouble
                              Rather use the extension warehouse features, or the sketchUcation plugin manager, or Smustard's "My Plugins" or a combination of these.
                              Also take a look at Rich O'Brien's CloudUp... πŸ˜‰
