    Extension Signing
    30 Posts 5 Posters 5.7k Views 5 Watching
    • medeekM
      medeek
      I always get this error(s):
      The specified file temporary://p1b1dccmcu1u8o111b1rul38r1rmp7.tmp could not be copied, because no file by that name exists. Please check that you supplied the correct filename.
      Failed to move new rbz to public folder to download.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        What app are you using to make the RBZ ?
        I assume you are making a ZIP and renaming it RBZ.
        Also is that RBZ on the same drive as the applications you are using - like your web-browser ?
        PS: What is your web-browser ?
        • medeekM
          medeek
          .zip file converted to .rbz by renaming the extension. I'm using Google Chrome as the browser.
          design.medeek.com
            What are you using to make the ZIP files ?
            The PC's native ZIP making and 7zip are both know to work well.
            When this signing regime kicked off I remember that there were problems with one or two other compression tools which made the ZIP files slightly differently and caused issues with the server-side RBZ creation failing.
            I successfully use 7zip 64 bit...
              I've forwarded this internally and we are looking into it.
              Can you try something for me: log out and in again. Does that help?
              • medeekM
                medeek
                I've got it to work a couple of times now. Strange. If I wait a few extra seconds after uploading the .rbz then it seems to help. I also switched to Firefox from Chrome, but I don't think that is the problem.
                design.medeek.com
                • medeekM
                  medeek
                  On a related note I am testing my plugin within SU 2017 using the new Extension Manager. I notice that to get a logo to load from EW one needs to have extension_info.txt in your root folder. I understand where to get the extension ID from but how does one determine the VERSION_ID? If I just enter in the extension ID it does not work it appears to need the VERSION_ID in this file. However, the VERSION_ID is not given in the EW control panel or anywhere that I can see it.
                  design.medeek.com
                  • Dan RathbunD
                    Dan Rathbun
                    You do not create nor edit the "extension_info.txt" file.
                    It is generated by the EW. When you get the signed RBZ package back, the file should have been inserted.
                    .. and it goes in the extension sub-folder not in the root folder of the RBZ archive (which is actually the "Plugins" root folder.)
                    I'm not here much anymore.
                    • medeekM
                      medeek
                      Your right it goes in the sub-folder not the root. However it would be really nice if I could just include this file with the appropriate ID and VERSION_ID since I have not set up my plugin to be downloaded through the Extension Warehouse. This file should only need to be hardcoded in just once and never change.
                      The only reason I would like this file to be present is so that my plugin/extension logo is properly displayed in the Extension Manager.
                      design.medeek.com
                        The extension_info is auto-generated by Extension Warehouse. You should not be modifying this yourself.
                        We have a feature request logged to allow Extension Manager to display an icon which is bundled with the extension. If you don't want your extension hosted on Extension Warehouse I'd just leave the extension_info.txt alone. Wait for official support for icons from other sources. The icon was added because we had easy access to that info when we query for updates. But it's clear that people want to present their extensions in the manager with icons/logos. It's noted.
                        • medeekM
                          medeek
                          Well at least I have the signing thing finally working, but it does seem a bit flaky I have to keep trying sometimes to get it to work.
                          I am wondering if my plugin creates or writes new files or folders within its plugin subfolder will this invalidate the signature/hash? I don't intend to create new .rb .rbs or .rbe files just .txt or log files.
                          design.medeek.com
                          • medeekM
                            medeek
                            I think I will probably go to a fully hosted setup on EW with my extension once I change up how I am controlling the licensing, this will probably increase my user base and is better in the long run.
                            The problem I am having right now is that when I go to edit any of my extensions the "agree to terms of use" checkbox does not seem to appear so I cannot click it and then preview my changes. I noticed this started happening about 2 months ago so I have not been able to update my listings for a while now.
                            So the interface keeps prompting me to click on agree to terms but I can't, has anyone else had this problem?
                            design.medeek.com
                            • Dan RathbunD
                              Dan Rathbun
                              Questions about the operation (correct or incorrect) of the Extension Warehouse are best asked in the official forum:
                              http://forums.sketchup.com/c/extension-warehouse
                              Those responsible are more likely to see the post there.
                              That said, The "agree to terms" checkbox issue seems to have come last month, but I thought it was fixed.
                              • medeekM
                                medeek
                                I just found an interesting issue this morning as I am further testing my plugin (Medeek Truss Plugin) with SU 2017. I have a sub folder called "logs" that I have placed some log files into (within my extension subfolder). These are updated when the plugin is used to create truss or rafter roofs, essentially keeping count of how many times the plugin is used to generate certain roof types.
                                When the plugin/extension is installed new these log files agree with hash and the plugin signature is valid however as soon as I write to these logfiles and change them in any way this causes the signature to appear as invalid in the extension manager.
                                These two files are named:
                                ROOF_TRUSS_LOG.txt
                                ROOF_RAFTERS_LOG.txt
                                What would be the appropriate work around for this issue? Should I be storing these text log files in a different location?
                                design.medeek.com
                                  Unless they haven't told us developers ??
                                  The signing process is meant to 'hash' the contents of the following [initial] file-types:
                                  rb
                                  rbs
                                  rbe
                                  js
                                  htm
                                  html
                                  css
                                  [Until representations were made at the outset of v2016, only rb* files were being hashed and other potentially malicious file-types could slip through...]
                                  Other file-types in the subfolder should be ignored.
                                  Also any new file-types [including those like the initially-hashed ones] which are added into the subfolder 'post-signing' should be ignored ??
                                  Someone at Trimble like to comment...
                                  Any more onerous changes have not been well explained 😲
                                  PS: Of course you can also write files into a Temp folder...
                                  • medeekM
                                    medeek
                                    The signing process appears to be hashing my log files (.txt)
                                    design.medeek.com
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Well, then do not put them into the package until after signing ?
                                      Or save your logs in a version independent folder like:
                                      "%APPDATA%/Medeek/SketchUp/TrussPlugin"
                                        The signing shouldn't be including your .txt files. Can you send me an example?
                                        In general I'd recommend you thread the Plugins folder like Windows' Program Files folder. If you have configuration files etc save them to the user's AppData. The extension update mechanism remove the old extension before copying over the new files. So that would also be an issue for you.
                                        • medeekM
                                          medeek
                                          The plugin in question right now is my Medeek Truss Plugin. You can download it here:
                                          404 - File or directory not found.
                                          (design.medeek.com)
                                          design.medeek.com
                                            I heard from one of my coworkers that there appear to be an issue there the signing/uploading can fail at times when there are higher volume of traffic. I experienced this myself today when I tried to upload. At first I was getting just errors, but when I tried later with the same RBZ it worked fine.
                                            A fix is being worked on.
