Extension Signing
30 Posts 5 Posters 3.7k Views 5 Watching
    medeek
    I am trying to figure out how to get my extension signed.
    When I upload it at this link:
    SketchUp Extension Warehouse
    Your library of custom third-party extensions created to optimize your SketchUp workflow.
    (extensions.sketchup.com)
    It always come back with an error. Is any one else have this same problem?
    Nathaniel P. Wilkerson PE
    Medeek Engineering Inc
    design.medeek.com
      I can get things signed if they are correctly formatted...
      What is your error ?
      Can you log-in ?
      Your submitted RBZ can only contain one RB file and a subfolder of the same name.
      That subfolder can only contain RB files - no RBS or RBE files [you can select to encrypt the RB files during the signing process]
      Obviously the subfolder can also contain several other file-types, including those inside sub-subfolders...
      Like HTM/HTML/JS/CSS etc...
        medeek
        I always get this error(s):
        The specified file temporary://p1b1dccmcu1u8o111b1rul38r1rmp7.tmp could not be copied, because no file by that name exists. Please check that you supplied the correct filename.
        Failed to move new rbz to public folder to download.
        design.medeek.com
          What app are you using to make the RBZ ?
          I assume you are making a ZIP and renaming it RBZ.
          Also is that RBZ on the same drive as the applications you are using - like your web-browser ?
          PS: What is your web-browser ?
            medeek
            .zip file converted to .rbz by renaming the extension. I'm using Google Chrome as the browser.
            design.medeek.com
              What are you using to make the ZIP files ?
              The PC's native ZIP making and 7zip are both know to work well.
              When this signing regime kicked off I remember that there were problems with one or two other compression tools which made the ZIP files slightly differently and caused issues with the server-side RBZ creation failing.
              I successfully use 7zip 64 bit...
                I've forwarded this internally and we are looking into it.
                Can you try something for me: log out and in again. Does that help?
                  medeek
                  I've got it to work a couple of times now. Strange. If I wait a few extra seconds after uploading the .rbz then it seems to help. I also switched to Firefox from Chrome, but I don't think that is the problem.
                  design.medeek.com
                    medeek
                    On a related note I am testing my plugin within SU 2017 using the new Extension Manager. I notice that to get a logo to load from EW one needs to have extension_info.txt in your root folder. I understand where to get the extension ID from but how does one determine the VERSION_ID? If I just enter in the extension ID it does not work it appears to need the VERSION_ID in this file. However, the VERSION_ID is not given in the EW control panel or anywhere that I can see it.
                    design.medeek.com
                      Dan Rathbun
                      You do not create nor edit the "extension_info.txt" file.
                      It is generated by the EW. When you get the signed RBZ package back, the file should have been inserted.
                      .. and it goes in the extension sub-folder not in the root folder of the RBZ archive (which is actually the "Plugins" root folder.)
                      I'm not here much anymore.
                        medeek
                        Your right it goes in the sub-folder not the root. However it would be really nice if I could just include this file with the appropriate ID and VERSION_ID since I have not set up my plugin to be downloaded through the Extension Warehouse. This file should only need to be hardcoded in just once and never change.
                        The only reason I would like this file to be present is so that my plugin/extension logo is properly displayed in the Extension Manager.
                        design.medeek.com
                          The extension_info is auto-generated by Extension Warehouse. You should not be modifying this yourself.
                          We have a feature request logged to allow Extension Manager to display an icon which is bundled with the extension. If you don't want your extension hosted on Extension Warehouse I'd just leave the extension_info.txt alone. Wait for official support for icons from other sources. The icon was added because we had easy access to that info when we query for updates. But it's clear that people want to present their extensions in the manager with icons/logos. It's noted.
                            medeek
                            Well at least I have the signing thing finally working, but it does seem a bit flaky I have to keep trying sometimes to get it to work.
                            I am wondering if my plugin creates or writes new files or folders within its plugin subfolder will this invalidate the signature/hash? I don't intend to create new .rb .rbs or .rbe files just .txt or log files.
                            design.medeek.com
                              medeek
                              I think I will probably go to a fully hosted setup on EW with my extension once I change up how I am controlling the licensing, this will probably increase my user base and is better in the long run.
                              The problem I am having right now is that when I go to edit any of my extensions the "agree to terms of use" checkbox does not seem to appear so I cannot click it and then preview my changes. I noticed this started happening about 2 months ago so I have not been able to update my listings for a while now.
                              So the interface keeps prompting me to click on agree to terms but I can't, has anyone else had this problem?
                              design.medeek.com
                                Dan Rathbun
                                Questions about the operation (correct or incorrect) of the Extension Warehouse are best asked in the official forum:
                                http://forums.sketchup.com/c/extension-warehouse
                                Those responsible are more likely to see the post there.
                                That said, The "agree to terms" checkbox issue seems to have come last month, but I thought it was fixed.
                                  medeek
                                  I just found an interesting issue this morning as I am further testing my plugin (Medeek Truss Plugin) with SU 2017. I have a sub folder called "logs" that I have placed some log files into (within my extension subfolder). These are updated when the plugin is used to create truss or rafter roofs, essentially keeping count of how many times the plugin is used to generate certain roof types.
                                  When the plugin/extension is installed new these log files agree with hash and the plugin signature is valid however as soon as I write to these logfiles and change them in any way this causes the signature to appear as invalid in the extension manager.
                                  These two files are named:
                                  ROOF_TRUSS_LOG.txt
                                  ROOF_RAFTERS_LOG.txt
                                  What would be the appropriate work around for this issue? Should I be storing these text log files in a different location?
                                  design.medeek.com
                                    Unless they haven't told us developers ??
                                    The signing process is meant to 'hash' the contents of the following [initial] file-types:
                                    rb
                                    rbs
                                    rbe
                                    js
                                    htm
                                    html
                                    css
                                    [Until representations were made at the outset of v2016, only rb* files were being hashed and other potentially malicious file-types could slip through...]
                                    Other file-types in the subfolder should be ignored.
                                    Also any new file-types [including those like the initially-hashed ones] which are added into the subfolder 'post-signing' should be ignored ??
                                    Someone at Trimble like to comment...
                                    Any more onerous changes have not been well explained 😲
                                    PS: Of course you can also write files into a Temp folder...
                                      medeek
                                      The signing process appears to be hashing my log files (.txt)
                                      design.medeek.com
                                        Dan Rathbun
                                        Well, then do not put them into the package until after signing ?
                                        Or save your logs in a version independent folder like:
                                        "%APPDATA%/Medeek/SketchUp/TrussPlugin"
                                          The signing shouldn't be including your .txt files. Can you send me an example?
                                          In general I'd recommend you thread the Plugins folder like Windows' Program Files folder. If you have configuration files etc save them to the user's AppData. The extension update mechanism remove the old extension before copying over the new files. So that would also be an issue for you.
                                          1 / 2
