    SketchUcation Tools in 2017
    113 Posts 17 Posters 14.8k Views 17 Watching
      Have you tried the old trick of deleting the IE cache ?
      Then restarting SketchUp and dialog ?
      • ntxdaveN Offline
        ntxdave
        Just tried that and that did not solve the problem either. Still same result 😞
        Press F1...thank me later
        • ntxdaveN Offline
          ntxdave
          A silly question: Could this be an OpenGL problem and how do I check to see that my laptop configuration support OpenGL 3.0?
          • N Offline
            NickW
            In SU
            Window>Preferences>OpenGL>Graphics Card Details
            mine is 4.5.0.
            I too am an IE user.
            • FrederikF Offline
              Frederik
              @rich o brien said:
              3.0.2 available to download
              Can you try this?
              Sorry for my ignorance, but how do I install the RBZ on SU2017...??
              I don't have the "Install extension" options available in SU2017...
              The installation video doesn't help me in any way...
              Cheers
              Kim Frederik
              • BoxB Offline
                Go to Window/Extension Manager and the Install button is on the bottom left.
                • FrederikF Offline
                  Frederik
                  Cheers, Box... 👍
                  Any way... Like others, it's still the same for me...
                  I see the Extension Store bar and nothing else...
                  Can resize it and clicking the maximize just makes the top bar wider...
                  Similar to JQL I've tried everything Tig has suggested to no avail...
                  Cheers
                  Kim Frederik
                  • FrederikF Offline
                    Frederik
                    Could it be because I have Firefox set up as my default browser...?
                    Cheers
                    Kim Frederik
                    • FrederikF Offline
                      Frederik
                      Changing it to Edge or Chrome doesn't seem to do anything...
                      (Yes, I have restarted SU after switching to another browser...)
                      Cheers
                      Kim Frederik
                      • FrederikF Offline
                        Frederik
                        Even restarting Windows doesn't help...
                        Feel I've tried everything possible...
                        Cheers
                        Kim Frederik
                          Just for the avoidance of doubt...
                          SketchUp 2017 introduces its own built-in browser [Chromium], which is used for the v2017 only HtmlDialogs.
                          The WedDialogs used by many extensions - like ExtensionStore³ - use Internet Explorer [Safari on MAC].
                          What you use for day-to-day browsing is unimportant - SketchUp always uses IE.
                          Clearing the IE cache can sometimes fix display issues...
                          It will be a major undertaking for authors to recast the hundreds of WebDialog dialogs into the new HtmlDialog format, and of course they would not be compatible with <v2017 anyway, so for now the new dialog format is not likely to become very common. The old format still works in v2017 - or at least it does for many of us... The reports here are weird and may stem from a number of unrelated issues - that's why I suggested various approaches...
                          Personally the dialog performs in v2017 exactly as v2016 😲
                          One further point can you look at the Registry entry as outlined here.
                          http://sketchucation.com/forums/viewtopic.php?p=606859#p606859
                          HKEY_CURRENT_USER\SOFTWARE\SketchUp\SketchUp 2017\WebDialog_SketchUcation ExtensionStore
                          Do not delete the entry, but note the the Height and Width values, and reset them to something like the example [869 & 817] - remembering to change the values to decimal input [unless you are a hex wiz].
                          Restart SketchUp and report back [with original H & W values too]...
                          • JQLJ Offline
                            JQL
                            You might have nailed it Tig...
                            Taking a look at the registry I get this:
                            I'll try changing the height and report back
                            www.casca.pt
                            Visit us on facebook!
                            • JQLJ Offline
                              JQL
                              Damn,
                              I quit sketchup, change the registry value Height for a decimal value of 512, then open sketchup 2017, open Sketchucation Extension Store and only see a bar as usual.
                              I close sketchup again, an go to the registry and I see that the decimal value is back at 37...
                              This is very strange as it seems eithe Sketchup or Sketchucation Extension Store is forcing that value.
                              www.casca.pt
                              • N Offline
                                NickW
                                As JQL indicates you can reset the values for the dialog in the registry but this has no effect on the height of the dialog in SU. If you quit SU without attempting to resize the dialog the registry values remain unaltered. Changing the size of the dialog in SU resets the height value in the registry to Decimal 37. It looks like the width value is responding correctly to resizes.
                                Clearing the IE cache has no effect.
                                  This weird, it works OK for many of us...
                                  Please copy+paste+enter these in the Ruby Console.
                                  SCF_Dialog::MINWIDTH
                                  350 ???
                                  SCF_Dialog::MAXWIDTH
                                  900 ???
                                  What do you get ?
                                  These are used to set the default sizes, BUT any customized H/W are then remembered in the Registry as SketchUp closes.
                                  Note that the MAXWIDTH is actually re-used for the initial default dialog height, thereafter it should be remembered as what was set by the user.
                                  Something is resetting that dialog's height for some of you...
                                    Can someone with this problem please try a slightly different approach...
                                    Close SketchUp 2017.
                                    Use Regedit again to reset the dialog's height to a reasonable number [say 500] in the Registry and then close.
                                    Now select the SketchUp 2017 exe icon [or the equivalent desktop-shortcut] and...
                                    right-click > context-menu > Run as administrator
                                    this will launch SketchUp slightly differently with some subtle side-effects like diabling image drag-n-drop !
                                    Any improvement on the SCF dialog front ?
                                    • FrederikF Offline
                                      Frederik
                                      350 ???
                                      900 ???
                                      What do you get ?
                                      Please see attached screen grab...
                                      Cheers
                                      Kim Frederik
                                      • JQLJ Offline
                                        JQL
                                        No difference. It still only displays the dialog's bar, and reverts the registry to a value of 25(hex) and 37(decimal)
                                        www.casca.pt
                                        • JQLJ Offline
                                          JQL
                                          I just tested it again and changed ALL reg values to 512.
                                          This made SCF change the width of the bar and still don't display anything else.
                                          Then I closed Sketchup and got back at the registry editor. Here's what I got:
                                          www.casca.pt
                                            Another possibility...
                                            Somehow the dialog's min height is getting messed with in the v2017 API [but only for some !], so I have made a test RBS that restricts the min height of that dialog to 100 - which should then be enough to give some borders and let you grab an edge and resize, and perhaps then have it remembered for next time ?
                                            Please follow these steps...
                                            Download the attached ZIP file: SCF_Dialog.rbs.zip
                                            Extract the RBS file that's in it - to somewhere like your Desktop.
                                            Open C:\Users\YourUserName\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\SketchUcation
                                            Find the file named SCF_Dialog.rbs
                                            Select it and rename it SCF_Dialog.rbsxxx so it doesn't load.
                                            Move the new file SCF_Dialog.rbs into that subfolder.
                                            Restart SketchUp 2017, test the SCF dialog and report what happens...
                                            NOTE:
                                            Because changing that RBS file then breaks the 'signing' hash you must use the Unrestricted Loading Policy.
                                            If it's unsuccessful...
                                            Reset things - delete the SCF_Dialog.rbs file and rename the SCF_Dialog.rbsxxx original as SCF_Dialog.rbs.
                                            When you restart SketchUp 2017 things will be as they were.
                                            If it's successful...
                                            I'll prepare a new v3.0.3 to include this 'hack'...
                                            Let us know...
                                            SCF_Dialog.rbs.zip
                                            • 3 / 6
