    Waiting area: final updates
    15 Posts 4 Posters 2.3k Views 4 Watching
    • Bryan KB Offline
      Another Raylectron test. Back lit patterned wall with bench seating and overhead spots. Nothing fancy. Testing different lighting set ups and material setting.
      (scroll way down for final)
        That flooring texture, which i think is a default SU texture, needs changing. And the absence is shadows makes it all hard to decipher.
        I'm sure there's more to come but at the moment it's hard to tell if it has depth.
        Get some hard shadows going and nuke that floor texture. Grab something off Episcura or Textures.com
        • Bryan KB Offline
          Yeah, the whole thing is kinda "bleh." Like I said, just a test, but those are great suggestions. Thanks.
          I'll post an update in a few days. πŸ‘
          • RichardR Offline
            Richard
            Like Rich suggests, I'd have figured the bottom section all floor, only your mention of seating nudged my eyes to pick it out.
            BUILTBRAND.COM.AU
            • Bryan KB Offline
              An update. I may add more details later. Fairly pleased with it now.
              • Bryan KB Offline
                Update. There will be more changes and updates. I'm having fun playing with this one but the set up and render times are taking hours.
                (keep scrolling down for final)
                • Bryan KB Offline
                  OK, this is getting to be fun.
                  (almost there, keep going) πŸ˜‰
                    If render times are slow it's usually a light problem
                    Does Raylectron do emitters/point lights/omni lights? Or is it IES lighting?
                    • Bryan KB Offline
                      Emitters, point lights and omni's.
                      It's mostly the wall. It's one big emitter. Plus I'm using a laptop and not a desktop workstation.
                      I have 36 lights as well and lots of shiny surfaces.
                      • ntxdaveN Offline
                        ntxdave
                        I think that showing the room at an angle helps. I think the confusion in seeing the depth is because the texture below the bench is the same as above the bench so it makes that whole wall look the same and you do not see the depth (extension of the wall below the bench). In particular from a straight view, it all looks the same. If you could lighten the wall above the bench of make the texture below the bench a little darker it would give more depth to the scene.
                        Just a though............. πŸ˜†
                        Press F1...thank me later
                        • Bryan KB Offline
                          Thanks ntxdave. Yeah, that is a problem and I'm going to change it. It's been the issue form the start. I was hoping to overcome it with other changes, but hey, that how the design process goes. πŸ˜† It didn't work so it has to be changed.
                          One problem is that I'm using the free version of Raylectron and it's limited in render size to 800x349 so the details aren't going to show as well.
                          But as I said, this is just a test and my first deep dive into Raylectron. I deliberately tried to make the lighting difficult for the render engine.
                          • Bryan KB Offline
                            Tweaked little more and sharpened in post.
                            The aliasing is due to limit of image size.
                            • RichardR Offline
                              Richard
                              That's now looking sharp mate!
                              BUILTBRAND.COM.AU
                              • ntxdaveN Offline
                                ntxdave
                                Adding the backs to the bench did a lot to add depth & perspective IMHO. IMO this is much better. Good job...
                                • Bryan KB Offline
                                  Thanks guys and thanks again for the suggestions.
