    Vray Beta Error Gui License
    renderpluginsextensions
    18 Posts 15 Posters 47.6k Views 15 Watching
      reymond
      hello everybody
      I have the vray beta for sketchup 2016 installed on my notebook.
      everything is going well. Now I wanted to install the beta also on my desktop.
      I get always the error message:
      "Failed to checkout v-ray gui license"
      What can I do?
      Sketchup & Vray Trainer
      • ithilI Offline
        ithil
        After installing this one we find a shortcut "Manage V-Ray Online License Server" and run.
        Once clicked, the page activation. Choosing online registration.
        And do not forget to check your firewall and antivirus.They can block Internet access for vray
          reymond
          yeeeah great. thank you very much ithil. it run now .-)
          • I Offline
            infomk
            I did what you given in description but i got below error.
            pls tell how to fix it
            • I Offline
              infomk
              I followed your instruction but i got this massage.
              • ebrahimesfandiaryE Offline
                ebrahimesfandiary
                hi everybody.i cant load hdri in vray 3 beta sketchup . Actually i can load this but dont show in render.please help me ๐Ÿ˜ž
                • E Offline
                  elsolo1
                  Hello, has anybody tried to solve this for the Mac OS version? I sent a support email and i'm awaiting reply
                    bluemeda
                    i got the same issue
                    • omiKronO Offline
                      omiKron
                      Go to C:\Program Files\Common Files\ChaosGroup\ and open config.json and verify if the vrolPort is set to 30304. Write it if not, then save and restart vrl service. Also add the localhost:30304/ 127.0.0.1:30304 IP as exception to your browser or remove the browser from the Firewall blocked softwares. That's it.
                      Had the same issue, but after contacting support, that's what they advised me to do and worked like a feather.
                        gcdavismarine
                        I'm having the same problems. This is how my config.json reads:
                        "local": {
                        "vrolHost": "0.0.0.0",
                        "vrolPort": 30304,
                        "dongleEnabled": true,
                        "vrlPort": 30314
                        "portal": "https://ols.chaosgroup.com",
                        "diagnostics": {
                        "level": "debug"
                        "proxy": {
                        "host": "",
                        "port": 0,
                        "type": "none",
                        "username": "",
                        "password": ""
                        Can anyone edit this for me? (I'm not sure how to add the localhost:30304/ 127.0.0.1:30304 IP as exception....I'm a 3D artist, not a programmer! ๐Ÿ˜„ )
                          gcdavismarine
                          My problem was solved after contacting vray support.
                          Here's what did it:
                          1. Make sure VRLService is running. You can check that by going to Task Manger > Services.
                            It wasn't running...so, on to step 2
                          2. Download and install V-Ray license server:
                          https://download.chaosgroup.com/downloads/289/download
                          Installed it, then ran 'Manage Vray Online License Server'
                          Good to go....now I'm having fun with the 3.0 beta. UI is gonna take some getting used to...but some real cool features so far ๐Ÿ˜„
                            Jorge Bobadilla
                            Dont know where to put the localhost:30304/ 127.0.0.1:30304 IP
                            iยดve just opened the file json. file
                              basem montaser
                              hi everybody.I followed your instruction but i got this massage.(NO LICENSES AVAILABLE)
                              • FalahiF Offline
                                Falahi
                                press ALT+cTRL+DELTE to open Task manager, go to Service tab ,find VRLservice (just enable it )
                                id u enable it then the CHAOSGROUP webpage will open immediately ,,then evry thing is ok
                                no u can render
                                  mackieto1
                                  Guys if you still have the Vray Beta error you can download the Json.file and replace it.
                                    lastessa
                                    any suggestion for mac os version?
                                      timmyd2283
                                      hi, i may have missed something out. and tried some of the steps you guys showed here. earlier i get the gui license error then downloaded the vlr service in chaosgroup and worked fine afterwards, but then when i started to use sketchup up a while ago, it said that it failed to check license, did the same thing again but its does not render. i think if the machine is offline it is not going to work.. do you guys experience the same issue? if not maybe you can guide me on how to use vray beta offline. thanks guys..
                                        griffgirl
                                        I was having this same error on Mac and was able to solve it by downloading the License Server 4.3.1 ADV. Apparently this was just posted yesterday (Feb 9th).
