    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.3k Views 172 Watching
      Anton_S
      Pixero, I'm working on that feature.
      Faust, that's a stunning piece of animation!
      SynSuka3d, like Istvan implied, you can add material to group prior to changing its color. You can also do it with script, in case the group doesn't have a material associated with it. However, if the inner faces are already colored by a different material, you must decolor them to default material, both front and back faces, so that the group's top level material is able to color them.
      Note that the object that contains the script should be part of simulation, that is not ignored; otherwise, the script of that object won't execute.
      Now, to answer your question, if the script is associated within the body you're coloring, you can have @box = this.group. Otherwise, it should be @box = simulation.find_group_by_name("box"). Note that the name is case sensitive and considers all the blank spaces. Anyway, here is the script containing it all:
      onStart{
        # Add material to the box in case the box has no material.
        if @box.material.nil?
          mat = Sketchup.active_model.materials.add("BoxMaterial")
          @box.material = mat
          mat.color = [255,255,255] # optional
        # Record starting color, just so we can reset it in the end
        @starting_color = @box.material.color
        # Utilize 'flag' variable to avoid coloring group the same color multiple times.
        # Just for optimization purpoposes...
        @flag = nil
      onUpdate{
        if key("up") == 1
          if @flag != 1
            @box.material.color = [0, 255, 0]
            @flag = 1
        elsif @flag == 1
          @box.material.color = [255, 255, 255]
          @flag = 0
      onEnd {
        # Reset color (also optional).
        @box.material.color = @starting_color
        SynSuka3D
        Thank you Anton_S
        Good !!! 💚
        manage transparency of objects ?
        alpha ? script
        Envoyé de mon PRO 5 en utilisant Tapatalk
          Anton_S
          SynSuka3D, to change opacity, you have to utilize the material's alpha function: http://www.sketchup.com/intl/en/developer/docs/ourdoc/material#alpha=. For your model it would look like this: @box.material.alpha = 0.5 or any other alpha ranging from 0.0 (transparent) to 1.0 (opaque).
          • I Offline
            ITman496
            I have a bug to report, maybe. I've noticed that if you use programmed ratios for things, such as gear reduction, if you leave objects as default (where they can sleep when still) you can cause things to sort of slip, and lose sync with each other. (example: gear teeth phase into each other)
            The only way to stop this seems to be to make them never sleep. Is this behaving as intended?
            I also have a file that causes crashes when I try to make a door work, but it seems to have stopped doing it. I will attempt to re-create the bug and post the file here.
              Anton_S
              Announcing version 0.9.5!
              This version comes with more compatibility with Mac OS X. Now keyboard input and MIDI work on Mac OS X too. Also, a few new features were added, such as another play button, along with plenty of fixes, upgrades, and improvements. Check out the ChangeLog for more information.
                count_olaf
                Hi. Hope you can help as I'm unable to get past an install error on Windows (64 bit machine). I'm using Sketchup Pro 2015 and attempting to install on a device connected to a workplace network which I think is the cause of the problem. I can install it successfully on a separate standalone (at home) laptop. I am installing with network administrator rights.
                Having installed both the ams library v3.4.0 and ms physics v0.9.5 through the sketchucation plugin store button within sketchup, they both give confirmation messages that they have successfully installed. They both appear in the window>preferences>extensions list and are checked. At this point no toolbars are available, so I restart sketchup. I then receive this message...
                Error Loading File C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
                Error: #<Exception: An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons:
                • LoadError: 161: The specified path is invalid. - C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so
                • LoadError: 161: The specified path is invalid. - C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib_no_sdl.so
                F:/Sketchup/Sketchup 2015/Tools/extensions.rb:197:in require' F:/Sketchup/Sketchup 2015/Tools/extensions.rb:197:in load'
                C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
                C:/Users/SS7U6035/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
                All the files and paths listed in the error message are present and correct in those locations. Grateful for any suggestions.
                  Anton_S
                  Thank you for your insightful report, count_olaf. I will investigate it as soon as possible.
                  • F Offline
                    faust07
                    Update from 9.3 to 9.5 did not work with installation in Extension Store. The old files ams_Lib.hash and MSPhysics.hash are not deleted and old models did not work. Installation per hand by deleting the old directories and copy the new to the plugin folder works...
                    The new selection functions are great to test parts of large models - fantastic!!!
                      Anton_S
                      Oh that explains the issue. I didn't sign the extensions due to technical issues. Why did the plugin packaging had to become more complicated? Really! That's why y'all got errors. Anyway, so, count_olaf, as faust suggested, to fix that you have to delete original versions first and then install the new ones. This process might not be necessary after the extensions will be signed, which I will so shortly.
                        Anton_S
                        Well, I just tried signing my extensions and unfortunately the extension signature tool doesn't work. So, y'all have to do it the hard way for now, that is first delete original AMS Library and MSPhysics versions and then install the new ones in place (do not overwrite).
                          SynSuka3D
                          [LOUDLY CRYING FACE]
                          http://uploads.tapatalk-cdn.com/20161101/e0540bd275bbea6603a2e67caf553448.jpg
                            You have an accent in your Windows user-name 'Lémony'.
                            This has long been taboo !
                            It breaks older versions of SketchUp's Ruby completely !!
                            However, it should be possible to encode such a string when defining the file-path to avoid these issues - somewhat straightforward with newer Ruby versions - such as yours 'v2016'...
                            Perhaps the author needs to reconsider the paths' encoding...
                              Anton_S
                              What? I thought I fixed that bug... 😕
                                Anton_S
                                Unfortunately I didn't fix the encoding issue. I thought I did but I didn't. I will work on it soon.
                                Thanks for the report, SynSuka3d.
                                TIG, thank you for remarking on the issue.
                                  cristyan
                                  Hello Anton ! It give me an error on Sketchup 2013 when presing PLAY.On Sketchup 2016 is runing ok.Thank you !
                                  • OxerO Offline
                                    Oxer
                                    With the last version MSPhysics 0.9.5 & AMS Library 3.4.0 it appears an error message in Ruby Console:
                                    Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                                    Error; #<Exception; An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons;
                                    - LoadError; dlopen(/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                                      Referenced from; /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                                      Reason; image not found - /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
                                    - LoadError; MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
                                    /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                                    /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                                    /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `register_extension'
                                    /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `<module;MSPhysics>'
                                    /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
                                    OSX 10.11.6
                                    SU 2016
                                      Anton_S
                                      SynSuka3d, I fixed the encoding error with non-ascii user names.
                                      Download version 0.9.6 to get it working.
                                      Cristian, Oscar you might be getting these errors because you overwritten original versions rather than deleting them.
                                      It is important that you delete original AMS Library and MSPhysics versions from the plugins folder prior to installing the new ones; otherwise, you'll get nonsense errors. The extension signature tool is not working right. I could not sign my extensions. That's why overwriting original versions will result with errors when using MSPhysics and AMS Library.
                                        cristyan
                                        Hello to everyone out there ! and Hello Anton ! It give me an error after program is launched... 2013 and 2016... And on version ...
                                        I manually install all the new plugins and I always delete the old ones ...
                                        Thank you !
                                        2013_MSPhysics_0.9.6_error
                                        2016_MSPhysics_0.9.6_error
                                        • OxerO Offline
                                          Oxer
                                          I obtain similar message:
                                          Error al cargar archivo /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                                          - LoadError; dlopen(/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                                            Referenced from; /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                                            Reason; image not found - /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
                                          - LoadError; MSPhysics library file, "/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
                                          OSX 10.11.6 SU2016
                                            Anton_S
                                            Alright, I'll look into this.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 46
                                            • 47
                                            • 27 / 47
