    Parts missing when importing DXF
    8 Posts 3 Posters 1.7k Views 3 Watching
      Swany
      Hi all. I am missing some parts when importing a DXF of a slide The bottom slide out pieces are missing. The parts show up in trueveiw and Autocad but wont import these parts into Sketchup.
      I have attached screen shots one of which shows some "autocad entries ignored" Can somebody shed some light on this please? πŸ˜•
        What units were used in making the DXF? What units are you using when importing? Possibly it's importing very small and the edges in that section are too short for SketchUp. How about uploading the DXF file so we can take a look.
        Your profile indicates you are using SketchUp Make. What plugin are you using to import DXF files into SketchUp?
          Swany
          Lypa cad.dxf
          Hi Dave thanks for that, would have got back sooner but was busy compensating for the issue.I need to update my profile but I use Make at home, and Pro at work. I dont know if I can attach the DXF in this way but I will find out soon enough if I got it wrong.
          If you could assist it would be appreciated.
          Cheers
            I can't open the DXF file at the moment but did you try importing the file with import units set to meters?
              Swany
              Tried that Dave, same bad result.
                slbaumgartner
                I think it may be due to proprietary elements in the DXF file. Here is what I see when I open it with eDrawings:
                  I was wondering that, Steve. I looked at it a bit but didn't have a chance to get back to it. Swany, do you have access to the source?
                    Swany
                    Thanks for the assistance guys. Yes, Dave I do have access to the source. I have requested a STEP file hopefully that will work. Will post the results in the thread.
