    [Plugin][Code]SKMtools,Material/ImageTools
    178 Posts 37 Posters 308.9k Views 37 Watching
      ssw
      I was able to use Preferences > Extensions > Install to successfully install the plugin
      For my own information, can you direct me to the tutorial on setting up admin powers?
      Before the successful install there were no skm files in the plugins folder
      Thanks for your help and quick responses
        404 Not Found
        (sketchucation.com)
        • jenujacobJ
          jenujacob
          Error; #<Errno;;ENOENT; No such file or directory - C;\Users\user\Desktop\TrimmedImages\BIMBA_6[Edges].dat>
          C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;264;in `readlines'
          C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;264;in `make_edges'
          C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;196;in `process_image'
          C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;165;in `initialize'
          C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;818;in `new'
          C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;818;in `block in <top (required)>'
          SketchUp;1;in `call'
          Hi TIG.... I am trying to use this image trimmer, but I get nothing... I opened the ruby console and I got some error...
            It's failing to make the 'Edges' dat file...
            Do you have Java installed and enabled on you PC ?
            Do you have .jar files set to open with Java - some compression tools hijack that file-type and stop it working.
            These tools rely on tiny .jar files to do some of the complex image processing etc.
            If they don't run the file's aren't made and so it breaks...
            Report back...
            • jenujacobJ
              jenujacob
              hi TIG!
              Thanks for the reply!
              I did have issues with the .jar file being opened with winrar. I associated the .jar file type to be opened with java.exe. But, i have no idea if it is working. Is there a way i can test it???
              I cant test right now. Its in my work PC. I will try to test tomorrow at work.
              Edit :
              I have tested it at office now. I downloaded and installed the latest java from their website. Associated .jar files to java.exe, but still nada. I am still getting the error.
              I am attaching a screen shot.
              • jenujacobJ
                jenujacob
                Pling! 😄
                  steve69
                  Installed it on Sk7.1 Web accessed page not working
                    steve69
                    error on photo texture startup
                    line 1123
                    https://3dwarehouse.sketchup.com/compiled_8b0304b.js
                      Perhaps you missed the widely publicized announcement that as of June 1, web-based services would no longer function in SketchUp versions earlier than SU2014. SketchUp is no longer using the Google-based servers those services point to in the old versions. The solution it to upgrade to at least SU2014.
                      • simjoubertS
                        simjoubert
                        Bonjour à tous !
                        Hello every body !
                        Sorry for my english !
                        I have trouble with the imageTrimmer
                        Each step i do :
                        • 1- I open a new .skp file
                          2- I importe a .png image with transparence part of image.
                          3- I save my .skp file
                          4- I select my image
                          5- I run ImageTrimmer plugin
                          6- I wait ( I see the progress bar ......)
                          7- Nothing change !
                        This is the report of the ruby console :
                        Error; #<Errno;;ENOENT; No such file or directory - D;\Sketchup\Modèles\TrimmedImages\forme4[Edges].dat>
                        C;/Users/simjo/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;264;in `readlines'
                        C;/Users/simjo/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;264;in `make_edges'
                        C;/Users/simjo/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;196;in `process_image'
                        C;/Users/simjo/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;165;in `initialize'
                        C;/Users/simjo/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;818;in `new'
                        C;/Users/simjo/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;818;in `block in <top (required)>'
                        If someone give me help, Thank you.
                        Simon
                        • simjoubertS
                          simjoubert
                          Bonjour à tous
                          Bonjour TIG !
                          Hello !
                          My English is not perfect so excuses me !
                          I had a ttrouble with the imagetrimmer !
                          In the ruby console, I have this message report :
                          List of step I do :
                          [1]New skp model
                          [3]Save file
                          [4]Run plugin ImageTrimmer
                          [5]Waiting
                          I read some thing like this in the forum but i had already instal and update my java
                          the .jar is already join with java
                          Can you help me !
                          Thanks you !
                          Simon
                            Your path to the model contains an accented character 'Modèles'
                            On PCs accents use to be a definite no-no with earlier SketchUp's Ruby, as it causes failures - the folder/file path is regarded as false.
                            However, since v2015 the newer Ruby is more robust and often allows accented characters.
                            I suspect that the code used in this fairly old script is somewhat antiquated and doesn't force the text into UTF-8 encoding...
                            I'll look to see if it's relatively simple to fix.
                            If so, then I'll publish an update and post something here...
                            Give we a little time...
                            • simjoubertS
                              simjoubert
                              Merci TIG
                              J'ai modifié "Modèles" en "Modeles" et ça à fonctionner pour un petit PNG.
                              Je suis en train de tester sur une jolie image d'erable du Japon !
                              Je posterai les résultats!
                              Merci encore pour ton super travail ! 😄
                                I have looked into this and the Ruby side is working fine, however the Java [jar] side is having issues with the encoded paths IF they contain an accented character.
                                I am trying to see how I sidestep this...
                                In the meanwhile when using ImageTrimmer ensure that the model SKP has a folder path that does not contain accented characters...
                                Then it will work...
                                  Still struggling to get these jar file-paths to work with accents in them !
                                  So for now use a folder-path/file-name that's accent-free !!
                                    http://sketchucation.com/pluginstore?pln=SKMtools
                                    Updated v20160621
                                    Main change is the recently reported issue, where the JAR files associated with ImageTrimmer failed to return a valid file path on some Windows systems, when the folder-path/file-name contained accented characters.
                                    This has now been resolved.
                                    But it's still best to avoid such accents in paths etc...
                                    • simjoubertS
                                      simjoubert
                                      Thanks TIG
                                        Ahmed0007
                                        what's wrong i'm doing
                                        Please see the video https://streamable.com/u3u7h
                                        please help! 😕
                                          This has been explained several times...
                                          It uses several JAR files shipped with the toolset - which are tiny applets which process certain aspects of the image files.
                                          JAR files are a special kind of renamed ZIP file.
                                          By default JAR files should be set to open [i.e. execute] in Java.
                                          Some compression-tools hijack the JAR file-type and open it themselves, as if it were a ZIP file, thereby breaking how the tool works.
                                          To fix it try the following steps...
                                          • Open your compression tool, and it will have a settings menu option, ensure that JAR file-type is NOT one of its ticked file-type options.
                                            Save the changes and close the tool.
                                          • Also ensure that you have the latest version of Java installed on your PC, and that it is set to open [execute] JAR files.
                                          • Retry an ImageTrim and see if the JAR files now work correctly...
                                            Ahmed0007
                                            i'm very happy to see your quick response
                                            Thank you soooo much!
                                            Problem solved.
                                            paypal is not available in our country is there is any other way to donate developers on sketchucation ?
                                            • 5 / 9
