    Explode and regroup script?
    extensions
    26 Posts 3 Posters 4.8k Views 3 Watching
      In this special case (flat terrain) ๐Ÿ˜„
      If you Select All Groups / Right Click / Make Component : the Ray Tracer works!
      Then just explode one time and you have your original groups on the terrain!
      But sure your groups have a special state! ๐Ÿ˜ฒ
      A little mystery! ๐Ÿ˜ฎ
        gregswk
        My terrain isnt flat ๐Ÿ˜ข
        Yeah...Maybe a big mystery!
        Pleasee find out for me! ๐Ÿ’š
          gregswk
          @pilou said:
          SmartDrop works for any terrain but maybe that is not that you want ? ๐Ÿค“ (Right Click on Selection)
          And sure that resovle not the little mystery! ๐Ÿ˜„
          So, I've done the landscape above importing all those buildings solids and doing the following steps:
          1. Transforming all groups as single components using "tt_groups2comps" plugin
          2. Transforming all components as single groups using "Make_Components" plugin
            *BUT THIS PLUGIN DOESNT MAKE ALL SELECTED COMPONENTS AS SINGLE GROUPS AT ONCE. THE "MAKE COMPONENTS TO SINGLE GROUPS" SCRIPT ONLY TRANSFORM 1 COMPONENT TO GROUP AT A TIME. SO I'VE MADE A SHORTCUT FOR THAT FUNCTION AND I KEPT REPEATING PRESSING THE SHORTCUT KEY AND THE ENTER KEY, WHICH TOOK ME A LOT OF TIME... ๐Ÿ˜
          3. I used Raytracer to drop all groups to the terrain
          I really would like to make this process as quickly as possible... For my future projects. Any idea? ๐Ÿ˜„
          Thank you
          • sdmitchS Offline
            sdmitch
            @gregswk said:
            @sdmitch said:
            Why? Is there a point to this exercise?
            Hi! The reason is that I can't use "drop to terrain" plugins like DropGC and Raytracer. I select the groups and click the plugin but nothing happens.
            BUT if I explode and regroup them (one by one), everything works normally. I really dont know why...
            I'm with you, I can't figure out why this is so. But, since these are buildings, you wouldn't want them to conform to the surface like Pilou's SmartDrop demo. So something as simple as
            mod = Sketchup.active_model
            sel = mod.selection
            sel.grep(Sketchup;;Group){|g|
             t=mod.raytest([g.bounds.min,[0,0,-1]])[0]
             g.transform!(Geom;;Transformation.new(t-g.bounds.min)) if t
            This works on your groups whether they are exploded and regrouped or not.
            Select group(s), paste code into Ruby Console, press Enter.
            http://sdmitch.blogspot.com/
              Sdmitch to the rescue! ๐Ÿ˜‰
              But that resolve not the little mystery of the 2 groups states! ๐Ÿ˜„
              What are special on them ?
              How do you create that ?
                gregswk
                > sel = mod.selection
                Hi, Sdmitch!
                Thaaaank you so muchh!! That's all what I needed!!
                ๐Ÿ˜„ ๐Ÿ‘ ๐Ÿ‘
                  gregswk
                  Hi, Pilou!
                  First of all, thank you so much for all support you are giving to me. ๐Ÿ˜„
                  Yes, the groups states remain. Mystery!
                  I've used Autocad Map 3d to generate those buildings with their proper heights attaching a shapefile. Before I export, I converted polygons to solids using -convtosolid command.
                  Then I saved as .dwg to export those buildings to Sketchup.
                    Even genious Sdmitch has find a solution for your problem ๐Ÿ‘
                    taka a look to these architect tools by Thomthom!
                    A suite of tools to help with imported DWG files aimed at Architecture
                    Maybe there there are some tricky things nside!
                    • sdmitchS Offline
                      sdmitch
                      My new project for the weekend!!!!!!!!
                        I believe that the problem comes from the export DXF from external program! ๐Ÿ˜„
                        (double vertices ?...)
                        • sdmitchS Offline
                          sdmitch
                          No the problem is that the transformation.origin is not over the "surface"
                          ` name = Group#445
                          origin = (-420.075838m, -663.573913m, 8.06m)
                          x axis = [1.0,0.0,0.0]
                          y axis = [0.0,1.0,0.0]
                          z axis = [0.0,0.0,1.0]
                          x,y,z = [-16538.41882347539,-26124.9572089176,317.32283464566945]
                          name = Group#468
                          x,y,z = [-16538.41882347539,-26124.9572089176,317.32283464566945]` which is why the "Drop" fails. By exploding and regrouping the group, the transformation.orig is reset to bounds.min which is over the "surface".
                            gregswk
                            ` name = Group#445
                            name = Group#468
                            -So that means I need to explode and regroup to reset them? Or there is another way to change their transformation.orig to bounds? Sorry, I didnt understand very well..
                            -I'm using your script to drop the groups down to terrain, but I'm having some problem... Many groups arent dropping well, they fly. ๐Ÿ˜•
                            • sdmitchS Offline
                              sdmitch
                              [attachment=0:373faxky]<!-- ia0 -->flying.JPG<!-- ia0 -->[/attachment:373faxky]
                              Could you post a sample of the one's that "fly".
                                gregswk
                                @sdmitch said:
                                [attachment=1:2366zu5c]<!-- ia1 -->flying.JPG<!-- ia1 -->[/attachment:2366zu5c]
                                badra 5 skp 8.skp
                                • sdmitchS Offline
                                  sdmitch
                                  The problem is some groups being dropped on "top" of others already moved to the surface.
                                  So to avoid that conflict, I have modified the previous code I posted.
                                  sel = mod.selection
                                  gat = []
                                   o = [g.bounds.center.x,g.bounds.center.y,g.bounds.min.z]
                                   p = mod.raytest([o,[0,0,-1]])[0];
                                   gat<<[g,Geom;;Transformation.new(p-g.bounds.min)] if p
                                  gat.each{|g| g[0].transform!(g[1])}
                                  badra 5 skp 8.skp
                                    gregswk
                                    > sel = mod.selection
                                    > gat = []
                                    Oh my God, thank you so much, sdmitch!!
                                    It is working perfectly!! ๐Ÿ˜„ ๐Ÿ‘ ๐Ÿ‘ ๐ŸŽ‰
                                      Always amazazed that few line can make! Bravo! ๐Ÿ˜Ž
                                        gregswk
                                        > sel = mod.selection
                                        > gat = []
                                        I'm sorry, Sdmitch... There is still one problem.. ๐Ÿ˜•
                                        The groups are moving by Z axis perfectly, but when it goes down to terrain, they are changing their X and Y positions. They are messing with each other.. ๐Ÿ˜•
                                        Why is it happening?
                                        • sdmitchS Offline
                                          sdmitch
                                          > > sel = mod.selection
                                          > > gat = []
                                          > >  gat<<[g,Geom;;Transformation.new(p-o)] if p
                                          [attachment=2:kcc5danh]<!-- ia2 -->Capture2.JPG<!-- ia2 -->[/attachment:kcc5danh]
                                          [attachment=1:kcc5danh]<!-- ia1 -->Capture3.JPG<!-- ia1 -->[/attachment:kcc5danh]
                                          Oops. My bad. I forgot to change the "origin" in the transformation. Code has been fixed.
                                          badra 5 skp 8.skp
                                            gregswk
                                            Wonderful, Sdmitch!
                                            Now it is perfect!!! ๐ŸŽ‰ ๐ŸŽ‰
                                            Thank you so much!!! ๐Ÿ˜„
                                            • 2 / 2
