    Explode and regroup script?
    extensions
    26 Posts 3 Posters 6.0k Views 3 Watching
    • sdmitchS Offline
      sdmitch
      @gregswk said:
      @sdmitch said:
      Why? Is there a point to this exercise?
      Hi! The reason is that I can't use "drop to terrain" plugins like DropGC and Raytracer. I select the groups and click the plugin but nothing happens.
      BUT if I explode and regroup them (one by one), everything works normally. I really dont know why...
      I'm with you, I can't figure out why this is so. But, since these are buildings, you wouldn't want them to conform to the surface like Pilou's SmartDrop demo. So something as simple as
      mod = Sketchup.active_model
      sel = mod.selection
      sel.grep(Sketchup;;Group){|g|
       t=mod.raytest([g.bounds.min,[0,0,-1]])[0]
       g.transform!(Geom;;Transformation.new(t-g.bounds.min)) if t
      This works on your groups whether they are exploded and regrouped or not.
      Select group(s), paste code into Ruby Console, press Enter.
      http://sdmitch.blogspot.com/
        Sdmitch to the rescue! πŸ˜‰
        But that resolve not the little mystery of the 2 groups states! πŸ˜„
        What are special on them ?
        How do you create that ?
          gregswk
          > sel = mod.selection
          Hi, Sdmitch!
          Thaaaank you so muchh!! That's all what I needed!!
          πŸ˜„ πŸ‘ πŸ‘
            gregswk
            Hi, Pilou!
            First of all, thank you so much for all support you are giving to me. πŸ˜„
            Yes, the groups states remain. Mystery!
            I've used Autocad Map 3d to generate those buildings with their proper heights attaching a shapefile. Before I export, I converted polygons to solids using -convtosolid command.
            Then I saved as .dwg to export those buildings to Sketchup.
              Even genious Sdmitch has find a solution for your problem πŸ‘
              taka a look to these architect tools by Thomthom!
              A suite of tools to help with imported DWG files aimed at Architecture
              Maybe there there are some tricky things nside!
              • sdmitchS Offline
                sdmitch
                My new project for the weekend!!!!!!!!
                  I believe that the problem comes from the export DXF from external program! πŸ˜„
                  (double vertices ?...)
                  • sdmitchS Offline
                    sdmitch
                    No the problem is that the transformation.origin is not over the "surface"
                    ` name = Group#445
                    origin = (-420.075838m, -663.573913m, 8.06m)
                    x axis = [1.0,0.0,0.0]
                    y axis = [0.0,1.0,0.0]
                    z axis = [0.0,0.0,1.0]
                    x,y,z = [-16538.41882347539,-26124.9572089176,317.32283464566945]
                    name = Group#468
                    x,y,z = [-16538.41882347539,-26124.9572089176,317.32283464566945]` which is why the "Drop" fails. By exploding and regrouping the group, the transformation.orig is reset to bounds.min which is over the "surface".
                      gregswk
                      ` name = Group#445
                      name = Group#468
                      -So that means I need to explode and regroup to reset them? Or there is another way to change their transformation.orig to bounds? Sorry, I didnt understand very well..
                      -I'm using your script to drop the groups down to terrain, but I'm having some problem... Many groups arent dropping well, they fly. πŸ˜•
                      • sdmitchS Offline
                        sdmitch
                        [attachment=0:373faxky]<!-- ia0 -->flying.JPG<!-- ia0 -->[/attachment:373faxky]
                        Could you post a sample of the one's that "fly".
                          gregswk
                          @sdmitch said:
                          [attachment=1:2366zu5c]<!-- ia1 -->flying.JPG<!-- ia1 -->[/attachment:2366zu5c]
                          badra 5 skp 8.skp
                          • sdmitchS Offline
                            sdmitch
                            The problem is some groups being dropped on "top" of others already moved to the surface.
                            So to avoid that conflict, I have modified the previous code I posted.
                            sel = mod.selection
                            gat = []
                             o = [g.bounds.center.x,g.bounds.center.y,g.bounds.min.z]
                             p = mod.raytest([o,[0,0,-1]])[0];
                             gat<<[g,Geom;;Transformation.new(p-g.bounds.min)] if p
                            gat.each{|g| g[0].transform!(g[1])}
                            badra 5 skp 8.skp
                              gregswk
                              > sel = mod.selection
                              > gat = []
                              Oh my God, thank you so much, sdmitch!!
                              It is working perfectly!! πŸ˜„ πŸ‘ πŸ‘ πŸŽ‰
                                Always amazazed that few line can make! Bravo! 😎
                                  gregswk
                                  > sel = mod.selection
                                  > gat = []
                                  I'm sorry, Sdmitch... There is still one problem.. πŸ˜•
                                  The groups are moving by Z axis perfectly, but when it goes down to terrain, they are changing their X and Y positions. They are messing with each other.. πŸ˜•
                                  Why is it happening?
                                  • sdmitchS Offline
                                    sdmitch
                                    > > sel = mod.selection
                                    > > gat = []
                                    > >  gat<<[g,Geom;;Transformation.new(p-o)] if p
                                    [attachment=2:kcc5danh]<!-- ia2 -->Capture2.JPG<!-- ia2 -->[/attachment:kcc5danh]
                                    [attachment=1:kcc5danh]<!-- ia1 -->Capture3.JPG<!-- ia1 -->[/attachment:kcc5danh]
                                    Oops. My bad. I forgot to change the "origin" in the transformation. Code has been fixed.
                                    badra 5 skp 8.skp
                                      gregswk
                                      Wonderful, Sdmitch!
                                      Now it is perfect!!! πŸŽ‰ πŸŽ‰
                                      Thank you so much!!! πŸ˜„
