    Explode and regroup script?
    extensions
    26 Posts 3 Posters 6.0k Views 3 Watching
      Even genious Sdmitch has find a solution for your problem πŸ‘
      taka a look to these architect tools by Thomthom!
      A suite of tools to help with imported DWG files aimed at Architecture
      Maybe there there are some tricky things nside!
      • sdmitchS Offline
        sdmitch
        @pilou said:
        But that resolve not the little mystery of the 2 groups states! πŸ˜„
        What are special on them ?
        How do you create that ?
        My new project for the weekend!!!!!!!!
        http://sdmitch.blogspot.com/
          I believe that the problem comes from the export DXF from external program! πŸ˜„
          (double vertices ?...)
          • sdmitchS Offline
            sdmitch
            No the problem is that the transformation.origin is not over the "surface"
            ` name = Group#445
            origin = (-420.075838m, -663.573913m, 8.06m)
            x axis = [1.0,0.0,0.0]
            y axis = [0.0,1.0,0.0]
            z axis = [0.0,0.0,1.0]
            x,y,z = [-16538.41882347539,-26124.9572089176,317.32283464566945]
            name = Group#468
            x,y,z = [-16538.41882347539,-26124.9572089176,317.32283464566945]` which is why the "Drop" fails. By exploding and regrouping the group, the transformation.orig is reset to bounds.min which is over the "surface".
              gregswk
              ` name = Group#445
              name = Group#468
              -So that means I need to explode and regroup to reset them? Or there is another way to change their transformation.orig to bounds? Sorry, I didnt understand very well..
              -I'm using your script to drop the groups down to terrain, but I'm having some problem... Many groups arent dropping well, they fly. πŸ˜•
              • sdmitchS Offline
                sdmitch
                [attachment=0:373faxky]<!-- ia0 -->flying.JPG<!-- ia0 -->[/attachment:373faxky]
                Could you post a sample of the one's that "fly".
                  gregswk
                  @sdmitch said:
                  [attachment=1:2366zu5c]<!-- ia1 -->flying.JPG<!-- ia1 -->[/attachment:2366zu5c]
                  badra 5 skp 8.skp
                  • sdmitchS Offline
                    sdmitch
                    The problem is some groups being dropped on "top" of others already moved to the surface.
                    So to avoid that conflict, I have modified the previous code I posted.
                    mod = Sketchup.active_model
                    sel = mod.selection
                    gat = []
                    sel.grep(Sketchup;;Group){|g|
                     o = [g.bounds.center.x,g.bounds.center.y,g.bounds.min.z]
                     p = mod.raytest([o,[0,0,-1]])[0];
                     gat<<[g,Geom;;Transformation.new(p-g.bounds.min)] if p
                    gat.each{|g| g[0].transform!(g[1])}
                    badra 5 skp 8.skp
                      gregswk
                      > sel = mod.selection
                      > gat = []
                      Oh my God, thank you so much, sdmitch!!
                      It is working perfectly!! πŸ˜„ πŸ‘ πŸ‘ πŸŽ‰
                        Always amazazed that few line can make! Bravo! 😎
                          gregswk
                          > sel = mod.selection
                          > gat = []
                          I'm sorry, Sdmitch... There is still one problem.. πŸ˜•
                          The groups are moving by Z axis perfectly, but when it goes down to terrain, they are changing their X and Y positions. They are messing with each other.. πŸ˜•
                          Why is it happening?
                          • sdmitchS Offline
                            sdmitch
                            > > sel = mod.selection
                            > > gat = []
                            > >  gat<<[g,Geom;;Transformation.new(p-o)] if p
                            [attachment=2:kcc5danh]<!-- ia2 -->Capture2.JPG<!-- ia2 -->[/attachment:kcc5danh]
                            [attachment=1:kcc5danh]<!-- ia1 -->Capture3.JPG<!-- ia1 -->[/attachment:kcc5danh]
                            Oops. My bad. I forgot to change the "origin" in the transformation. Code has been fixed.
                            badra 5 skp 8.skp
                              gregswk
                              Wonderful, Sdmitch!
                              Now it is perfect!!! πŸŽ‰ πŸŽ‰
                              Thank you so much!!! πŸ˜„
                              • 2 / 2
