    Sketchup - vray - rt render - gpu problem
    renderpluginsextensions
    12 Posts 4 Posters 3.4k Views 4 Watching
    • F Offline
      filipebonito
      i forgot to mention, i'm using sketchup 2013 on a windows 8.1 pc
        roland joseph
        The nvidia quadro k2200 is not going to be very productive. It doesn't have the horse power for GPU rendering.
        • F Offline
          filipebonito
          well that's really all i got...
          i just need to quickly render a small window in real time, i guess it would be better than use the CPU
          • andybotA Offline
            andybot
            Right now, it's best to use CPU for the RT rendering.
            • F Offline
              filipebonito
              why do you say that?
              • andybotA Offline
                andybot
                because it more or less works. I use the CPU based RT all the time for when I'm setting up my render. There's a few minor issues like translucency doesn't work properly, but overall I find it quite useful. Like others said, the GPU based RT is not functional in this version of vray.
                • F Offline
                  filipebonito
                  thanks, but can you confirm that it works? (just because i just get a black screen with gpu or cuda...)
                  • andybotA Offline
                    andybot
                    change to CPU option and try it πŸ˜„
                    (sometimes it helps to reset the options to default if some settings are screwed up, and then start over changing one thing at a time.)
                    • V Offline
                      valerostudio
                      Just tested a simple cube using RT with a Titan X GPU and it doesn't work. Like Andy said, for now use CPU and if you access to DR nodes, use them as well.
                      • F Offline
                        filipebonito
                        yes, thanks
