    Sketchup - vray - rt render - gpu problem
    renderpluginsextensions
    12 Posts 4 Posters 3.5k Views 4 Watching
    • F Offline
      filipebonito
      hello,
      does vray support GPU in RT render?
      i'm questioning because i just saw a video that uses OPEN GL an CUDA
      but in vray manual states :
      "Notes
      V-Ray RT in SketchUp does not currently support rendering on the GPU."
      301 Moved Permanently
      (docs.chaosgroup.com)
      i have a nvidia quadro k2200 and i would like to take advange of this feature, can anyone help?
      regards
      filipe bonito
      ps. sorry for my english, is not my language...
      • V Offline
        valerostudio
        I am not having any luck with it currently. When it did work, it wasn't great. Let's keep pusing for a 3.0 release!
        • F Offline
          filipebonito
          i forgot to mention, i'm using sketchup 2013 on a windows 8.1 pc
            roland joseph
            The nvidia quadro k2200 is not going to be very productive. It doesn't have the horse power for GPU rendering.
            • F Offline
              filipebonito
              well that's really all i got...
              i just need to quickly render a small window in real time, i guess it would be better than use the CPU
              • andybotA Offline
                andybot
                Right now, it's best to use CPU for the RT rendering.
                • F Offline
                  filipebonito
                  why do you say that?
                  • andybotA Offline
                    andybot
                    because it more or less works. I use the CPU based RT all the time for when I'm setting up my render. There's a few minor issues like translucency doesn't work properly, but overall I find it quite useful. Like others said, the GPU based RT is not functional in this version of vray.
                    • F Offline
                      filipebonito
                      thanks, but can you confirm that it works? (just because i just get a black screen with gpu or cuda...)
                      • andybotA Offline
                        andybot
                        change to CPU option and try it πŸ˜„
                        (sometimes it helps to reset the options to default if some settings are screwed up, and then start over changing one thing at a time.)
                        • V Offline
                          valerostudio
                          Just tested a simple cube using RT with a Titan X GPU and it doesn't work. Like Andy said, for now use CPU and if you access to DR nodes, use them as well.
                          • F Offline
                            filipebonito
                            yes, thanks
