    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      The HDU5 at the corner is primarily for the lower shearwall, the HDU4 about 24" inboard is for the the portal frame load path in the wall above, notice the straps between floors that complete the load path. I have not shown the SB5/8X24 anchor bolts that will be placed in the forms before the concrete is poured. I showed the holdowns about 1-1/2" above the sill plate, actual height will be dictated by the extension of the anchor bolts above the sill plate and is not really critical. The holdowns could just as well sit directly on the bottom plate.
      What I've shown in this window wall is a site built wood moment frame, what I have not shown is the required nailing patterns. I also forgot to add in the pad footings for the PSL posts, and possibly a few more A35 clips and straps, but overall it is mostly complete. I am still working on the lateral analysis of the total structure which may change the sizing of the straps and holdowns slightly. This is the typical work I do during my day job but its fun to throw together a 3D model to really look at how it all goes together.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • FrederikF
        Frederik
        After having updated the plugin, I now get the following error, when I open SU... 😞
        Error Loading File C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial/medeek_load.rb
        Error: #<NameError: undefined local variable or method pluginserial' for Medeek_Engineering_Inc_Extensions::MedeekTrussPluginModuleLoader:Module> C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial/medeek_load.rb:205:in module:MedeekTrussPluginModuleLoader'
        C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial/medeek_load.rb:22:in <module:Medeek_Engineering_Inc_Extensions>' C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial/medeek_load.rb:20:in <top (required)>'
        C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
        C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial.rb:39:in register_extension' C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial.rb:39:in module:MedeekTrussPluginLoader'
        C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial.rb:23:in <module:Medeek_Engineering_Inc_Extensions>' C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial.rb:22:in <top (required)>'
        Cheers
        Kim Frederik
        • medeekM
          medeek
          I forgot to remove a "#" sign when I removed some debugging code in the trial version. Re-download and install again (Version 1.6.8). Sorry for breaking it.
          design.medeek.com
          • FrederikF
            Frederik
            No problem...
            Glad you've solved the issue... πŸ‘
            Cheers
            Kim Frederik
            • FrederikF
              Frederik
              Hhhmmm... Although I've downloaded ver 1.6.8, installed it, re-started SU, I still have this issue... ❓
              Cheers
              Kim Frederik
              • medeekM
                medeek
                Manually remove the plugin folder and files and then do a clean install, let me know if that doesn't fix it.
                design.medeek.com
                • FrederikF
                  Frederik
                  I've removed the folder "medeek_truss_ext_trial" from
                  C:\Users\kim\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                  As well as the file "medeek_truss_ext_trial.rb"
                  Then I opened SU and didn't get any errors...
                  I opened the Extension Store and installed the plugin again, but after a re-start, I get the exact same issue...
                  It does say that it's ver. 1.6.8, but are you sure that it's the correct file in the Extension store...??
                  Cheers
                  Kim Frederik
                  • medeekM
                    medeek
                    Your right I may have forgotten to upload the correct version to the pluginstore, ack. Try downloading the plugin again reinstall, so sorry for the mess up.
                    design.medeek.com
                    • FrederikF
                      Frederik
                      It's working now... πŸ‘
                      Cheers
                      Kim Frederik
                      • medeekM
                        medeek
                        Again I apologize for the delay in development, first it was my new job and then I re-injured my rotator cuff (old injury from 10 years ago) which has made sitting at my desk for prolonged periods very difficult.
                        This morning I sat down and thought about hip sets since I've had some recent requests for the their addition to the plugin. What I show below is a fairly standard step down hip set with, with the midwest variant shown at one corner and the standard variant at the other corner.
                        http://design.medeek.com/resources/images/truss_su153_800.jpg
                        View model here:
                        3D Warehouse
                        (3dwarehouse.sketchup.com)
                        Note, I have not shown all of the internal webs for clarity, those will be generated automatically and not be user definable.
                        Please review carefully and let me know if anything looks amiss. I will also be adding in other variants of the hip set but I figured I would start with these two.
                        A stepdown hip set provides a girder truss, with a hip jack truss running from the corners up the ridge until they meet the hip girder.
                        The Midwest hip set also provides a girder truss, with hip trusses that step up to the peak.
                        However in a Midwest hip set, you run a rafter (dropped) up from the corner of the front wall to the hip girder.
                        All the bottom chords of the end jacks run to the hip girder, allowing for better attachment of the drywall on the ceiling.
                        design.medeek.com
                        • medeekM
                          medeek
                          This is the Northeast Hip Set variant:
                          http://design.medeek.com/resources/images/truss_su154_800.jpg
                          View model here:
                          3D Warehouse
                          In a northeast hip set, you will find a short jack truss starting at the corner and running up the hip ridge. This hip jack stops at a sub-girder. All end jack bottom chords run to the hip girder, allowing for better attachment of the drywall on the ceiling. Hip cats must be field cut and installed between the hip trusses. Works well with dual-pitched hip systems.
                          design.medeek.com
                          • medeekM
                            medeek
                            This is the California Hip Set:
                            http://design.medeek.com/resources/images/truss_su155_800.jpg
                            View model here:
                            3D Warehouse
                            The problem I am having with this variant is the conflict between the 2x6 hip rafter and the top chords of the step down hip trusses.
                            design.medeek.com
                            • medeekM
                              medeek
                              The revised california hip set with a stacked hip rafter:
                              http://design.medeek.com/resources/images/truss_su156_800.jpg
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM
                                medeek
                                A stepdown or midwest hip set with a drop-in purlin frame:
                                http://design.medeek.com/resources/images/truss_su157_800.jpg
                                View model here:
                                3D Warehouse
                                There is some minor conflicts at the top chord of the frame with the hip trusses and at the peak but I don't think it is worth worrying about.
                                I have found that for manual editing of members the "trim" function is becoming a very valuable tool, it has already saved me a lot of time when adjusting webs and chords as I adjust or drop some of the hip truss top chords. I strongly suggest that everyone upgrade to the latest version (1.6.8) to take advantage of the improved trim function. I now need to get the extend function working.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  A smaller (16' span) standard terminal hip set attached to the main roof with girder truss and valley set.
                                  http://design.medeek.com/resources/images/truss_su158_800.jpg
                                  View model here:
                                  3D Warehouse
                                  The addition of the hip sets into the plugin will allow the creation of more complex hip roofs with minimal manual intervention.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    I now just need to hunker down and get some heavy coding done to make all of these hip set variants a reality. Once I have one the rest will fall out fairly easily since the overall logic for all the variants are quite similar. I've spent the last 2-3 days reviewing some texts and shop drawings to make sure I've got things more or less correct with my models/templates. So far no one has complained to loudly about any of the configurations so I think it is now time to proceed and add the hip sets into the plugin.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.6.9 - 09.14.2016
                                      • Added some enhancements and wireframe (temporary) graphics to the valley set function.
                                      • Fixed bug in the trim function.
                                      • Fixed bug in the roof battens option.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        If its not one thing its another. I finally get myself situation so that I can get back to some daily coding and then I injure my shoulder (bursitis) and put myself out of commission. I've almost got the first truss hip set ready for release. I think everyone will be excited to see what it can do.
                                        design.medeek.com
                                        • jujuJ
                                          juju
                                          dang dude, what's the recovery time on that?
                                          • pbacotP
                                            Hope you're feeling better soon. I had shoulder joint pain (they thought it was impingement) and it took a long time to get better. Using exercise from the therapist and working out seemed to be helpful. I think computer work was the problem. I think paddling (racing) was the cure for me but I still have some soreness lower in that arm sometimes.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 76
                                            • 77
                                            • 26 / 77
