    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      The revised california hip set with a stacked hip rafter:
      http://design.medeek.com/resources/images/truss_su156_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        A stepdown or midwest hip set with a drop-in purlin frame:
        http://design.medeek.com/resources/images/truss_su157_800.jpg
        View model here:
        3D Warehouse
        There is some minor conflicts at the top chord of the frame with the hip trusses and at the peak but I don't think it is worth worrying about.
        I have found that for manual editing of members the "trim" function is becoming a very valuable tool, it has already saved me a lot of time when adjusting webs and chords as I adjust or drop some of the hip truss top chords. I strongly suggest that everyone upgrade to the latest version (1.6.8) to take advantage of the improved trim function. I now need to get the extend function working.
        design.medeek.com
        • medeekM
          medeek
          A smaller (16' span) standard terminal hip set attached to the main roof with girder truss and valley set.
          http://design.medeek.com/resources/images/truss_su158_800.jpg
          View model here:
          3D Warehouse
          The addition of the hip sets into the plugin will allow the creation of more complex hip roofs with minimal manual intervention.
          design.medeek.com
          • medeekM
            medeek
            I now just need to hunker down and get some heavy coding done to make all of these hip set variants a reality. Once I have one the rest will fall out fairly easily since the overall logic for all the variants are quite similar. I've spent the last 2-3 days reviewing some texts and shop drawings to make sure I've got things more or less correct with my models/templates. So far no one has complained to loudly about any of the configurations so I think it is now time to proceed and add the hip sets into the plugin.
            design.medeek.com
            • medeekM
              medeek
              Version 1.6.9 - 09.14.2016
              • Added some enhancements and wireframe (temporary) graphics to the valley set function.
              • Fixed bug in the trim function.
              • Fixed bug in the roof battens option.
              design.medeek.com
              • medeekM
                medeek
                If its not one thing its another. I finally get myself situation so that I can get back to some daily coding and then I injure my shoulder (bursitis) and put myself out of commission. I've almost got the first truss hip set ready for release. I think everyone will be excited to see what it can do.
                design.medeek.com
                • jujuJ
                  juju
                  dang dude, what's the recovery time on that?
                  • pbacotP
                    Hope you're feeling better soon. I had shoulder joint pain (they thought it was impingement) and it took a long time to get better. Using exercise from the therapist and working out seemed to be helpful. I think computer work was the problem. I think paddling (racing) was the cure for me but I still have some soreness lower in that arm sometimes.
                    • medeekM
                      medeek
                      I think the original injury (rotator cuff, partial tear) was somehow reinjured which has caused inflammation (bursitis) which then has lead to impingement, long story short when I sit at a computer and use a mouse or keyboard for more than about 5 minutes I'm in pain, this is ridiculous.
                      design.medeek.com
                      • medeekM
                        medeek
                        I've been flat on my back for a week in bed. Yesterday I somehow willed myself to go to work, put on a shoulder brace, medicated and endured 8 hours of pain. Came home, ate dinner, and went right to bed. Woke up this morning and the pain has all but mysteriously disappeared. You tell me?
                        Crossing my fingers that this is real, tonight I might be back in the saddle πŸ˜„.
                        design.medeek.com
                        • jujuJ
                          juju
                          πŸ‘ 😎
                          • pbacotP
                            Be well!
                            • medeekM
                              medeek
                              Still out of commission but I am slowly improving. I've been making very slow progress on the stepdown hip set maybe I can get it out by this weekend. I have a lot of people requesting it so I'm excited to actually get it released after promising everyone that it would be out 2 months ago.
                              After this experience all I can say is without your health you are pretty much nothing.
                              design.medeek.com
                              • medeekM
                                medeek
                                I've been slowly working on the stepdown hip truss set. Its been a bit more complicated than expected. I've also decided to make it auto select the common truss type by span but also allow the user to manually select the common truss type as well, yet another level of complexity. In addition I would also like to enable raised heels which again adds to the complexity of the required logic and amount of code required to make this work.
                                The user will be able to select the hip setback. This is usually 3x or 4x the truss spacing (ie. 6ft, 8ft with 24" o/c truss spacing). I could restrict this to some multiple of the truss spacing but I think I will leave it completely open ended for the user.
                                Once I have the initial module complete I will then add into the advanced options the ability to use a drop-in purlin frame.
                                Another item to consider is the depth of the top chord and bottom chord of the jack trusses, this should be independent from the main trusses. Typically all of this is determined when the trusses are engineered (ie. Mitek software) but in this case we are not engineering these trusses, merely generating the geometry so all of these values become user determined.
                                design.medeek.com
                                  MtnArch
                                  Thanks for being so thorough, Nathaniel! Looking forward to the next update of your amazing plugins!
                                  Highest Regards,
                                  Alan T. Hendry, RA
                                  Architect
                                  • medeekM
                                    medeek
                                    If I'm going to take the time and energy to program something like this I might as well do it right. Even with that attitude I still miss a few things.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Yesterday I finally had the MRI done on my neck. They found a herniated disk between my C6 and C7 vertebrae which was pinching the nerve extending into my arm (cervical radiculopathy). This explains all of my symptoms. I don't know why it took almost 2 months for them to figure this out but it did. It is very strange that I would have so much localized pain in my shoulder though but I guess it turns out it is my neck, crazy.
                                      I think it is healing itself over time but it could just be the painkiller (GABAPENTIN) is working fairly well at the moment. I'm waiting on a cervical epidural steroid injection at the injury site. If this does not work it may be surgery since the symptoms in my right arm are quite severe and debilitating, and not something I can live with long term.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Has anyone had a chance to run the plugin much within SU 2017. I loaded it up yesterday and didn't encounter any problems, so for now I'm going to assume that its compatible with 2017.
                                        On a different note I've got my injection coming up on Tuesday, fingers crossed that it works and solves my issues that I've been dealing with the last 2-3 months.
                                        design.medeek.com
                                          MtnArch
                                          I've done a little playing and all appears to work fine.
                                          Highest Regards,
                                          Alan T. Hendry, RA
                                          Architect
                                            SU 2017
                                            Bug SPlatch (Closing SU) With Draw Minor Roof / Gable Dormer (and repeatitive)
                                            But it's my fault! πŸ˜„
                                            I don't choose an inclined Plane!
                                            So you must make something about that! πŸ˜‰
                                            Where we can see that Chris is not exactly at the ground 0 ! πŸ’š
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 76
                                            • 77
                                            • 26 / 77
