    Introducing Viz - parametric modeling for SketchUp
    extensions
    85 Posts 21 Posters 36.2k Views 21 Watching
    • F Offline
      fluid
      @Pixero: added to the todo list
      @pilou: Yes, you can use a "GeometrySource" node to get geometry from SketchUp and then perform boolean operations. Keep in mind the solids need to be closed.
        French Version Updated! πŸ˜„
          Does the Boolean Viz works with SU MAKE ?
          Seems not! Even Union! (Maybe it's different than Envelopp ?
          Suggestion : a Box Selection moving for place it for see that is behind! πŸ˜„
          • F Offline
            fluid
            Did you turn off the preview on node "GeometrySource-1" and "GeometrySource-2"? Otherwise they'll probably cover the result of the boolean operation. Also, you should connect the "Out Geometry" pins to the inputs of the boolean operation, not the "Active" pins.
              OK! Better that works in SU MAKE except I must hide existing groups! πŸ˜‰
              Just something not very clear!
              How attribut easily an existing group to a specific Geometry Source Node?
              Here I create a group then create a Node Source Then click Set Geometry Source
              then I create a second group then a Second Node Source Then Click Set Geometry Source
              It's not possible to select a Node Source existing on the Screen then Click Set Geometry Source? or...
              There is a list a groups of Source objects but how to apply a specific Nodes?
              Verify if your start Viz default axes are in the same orientation than default Axes SU Screen!
              Seems there are not! πŸ˜„
              (Click for Zoom)
              • F Offline
                fluid
                Currently the to assign SketchUp geometry to a GeometrySource node in Viz you have to select the appropriate GeometrySource in the list, but probably selecting the node directly in Viz would be more practical.
                I'm adding it to the to do list, together with the axis orientation issue.
                Instead of hiding the groups in SketchUp, you can also move the GeometrySink group to a different location, so you'll be able to see both the operands of the boolean operation as well as the results.
                • genki.ttG Offline
                  genki.tt
                  I just installed v.0.5.0 on mac, but it doesn't start when I click Vz icon or select 'Start Viz' from menu ... what's wrong??
                  SketchUp PRO 2016
                  MacBookPro 15' OSX 10.11.6
                  • F Offline
                    fluid
                    Do you get any error in the ruby console?
                    • genki.ttG Offline
                      genki.tt
                      Ruby console shows ...
                      Error: #<NoMethodError: undefined method start' for VizPro:Module> /Users/architect7/Library/Application Support/SketchUp 2016/SketchUp/Plugins/VizPro/VizProCore.rb:7:in block in module:VizPro'
                      SketchUp:1:in `call'
                      • F Offline
                        fluid
                        We just released a new version of Viz, you can get it here
                        In this new version:
                        • Improved GraphEditor look
                        • Fixed Mac issue
                        • Added more primitives, such as Cone, Sphere, Teapot, Cylinder
                        • Added a node to create lines from an array of point positions
                        http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/08/MakeTeapot.png
                        • genki.ttG Offline
                          genki.tt
                          Thank you for rapid release !
                          I could open VizPro on Mac !
                          I could see the tea cup that has a big hole on bottom !
                          • F Offline
                            fluid
                            We just released a new version of Viz, you can grab it here.
                            This version highlights:
                            • Added the "Duplicate" node, to copy and instance geometry
                            • Improved node editor look
                            • Bug fixes
                              Viz getting started guide
                            [flash:36jgs09v]https://www.youtube.com/v/MjmTH2uixd4[/flash:36jgs09v]
                              Pleasures' Multiplication! 😎
                              Luckily seems the manual is not modified, so no need to update the French one! πŸ˜‰
                              Nevertheless Youtube video added and publicity made! πŸ€“
                              PS With what program do you make your tutorial ?
                              • F Offline
                                fluid
                                For the tutorial we used Camtasia Studio.
                                • F Offline
                                  fluid
                                  • Added support of instancing geometry made itself of components
                                  • Bug fixes
                                  • Added instancing sample
                                  [flash:1cisnfai]https://www.youtube.com/v/t5Zk5PWRZVs[/flash:1cisnfai]
                                    Skatter challenger! πŸ˜‰
                                    • F Offline
                                      fluid
                                      We just released Viz 1.2.0, you can grab it here.
                                      • Added new nodes for sampling arbitrary attributes (such as normal, texture coordinates, etc) on geometry surface
                                      • Added a node to filter arrays based on a boolean condition
                                      • Improved UI usability, added connection snapping
                                      • Added a new advanced instancing sample
                                      [flash:3g2bze9l]https://www.youtube.com/v/dtfgFEk-ELI[/flash:3g2bze9l]
                                        A little cup of tea with some milk? πŸ˜‰
                                        French VIZ manualUp Dated
                                        • PixeroP Offline
                                          Pixero
                                          Thanks for the update. πŸ‘
                                          Now I really got to find some time to try it out a bit more.
                                          • E Offline
                                            Evers
                                            Are there any examples showing the full potential of this plugin?
                                            It's released, but the product site is quite unconvincing.
                                            Is it possible to make a dynamic component out of the Viz definition?
                                            • 4 / 5
