    Introducing Viz - parametric modeling for SketchUp
    extensions
    85 Posts 21 Posters 38.3k Views 21 Watching
    • genki.ttG
      genki.tt
      I just installed v.0.5.0 on mac, but it doesn't start when I click Vz icon or select 'Start Viz' from menu ... what's wrong??
      SketchUp PRO 2016
      MacBookPro 15' OSX 10.11.6
      • F
        fluid
        Do you get any error in the ruby console?
        • genki.ttG
          genki.tt
          Ruby console shows ...
          Error: #<NoMethodError: undefined method start' for VizPro:Module> /Users/architect7/Library/Application Support/SketchUp 2016/SketchUp/Plugins/VizPro/VizProCore.rb:7:in block in module:VizPro'
          SketchUp:1:in `call'
          • F
            fluid
            We just released a new version of Viz, you can get it here
            In this new version:
            • Improved GraphEditor look
            • Fixed Mac issue
            • Added more primitives, such as Cone, Sphere, Teapot, Cylinder
            • Added a node to create lines from an array of point positions
            http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/08/MakeTeapot.png
            • genki.ttG
              genki.tt
              Thank you for rapid release !
              I could open VizPro on Mac !
              I could see the tea cup that has a big hole on bottom !
              • F
                fluid
                We just released a new version of Viz, you can grab it here.
                This version highlights:
                • Added the "Duplicate" node, to copy and instance geometry
                • Improved node editor look
                • Bug fixes
                  Viz getting started guide
                [flash:36jgs09v]https://www.youtube.com/v/MjmTH2uixd4[/flash:36jgs09v]
                  Pleasures' Multiplication! 😎
                  Luckily seems the manual is not modified, so no need to update the French one! πŸ˜‰
                  Nevertheless Youtube video added and publicity made! πŸ€“
                  PS With what program do you make your tutorial ?
                  • F
                    fluid
                    For the tutorial we used Camtasia Studio.
                    • F
                      fluid
                      • Added support of instancing geometry made itself of components
                      • Bug fixes
                      • Added instancing sample
                      [flash:1cisnfai]https://www.youtube.com/v/t5Zk5PWRZVs[/flash:1cisnfai]
                        Skatter challenger! πŸ˜‰
                        • F
                          fluid
                          We just released Viz 1.2.0, you can grab it here.
                          • Added new nodes for sampling arbitrary attributes (such as normal, texture coordinates, etc) on geometry surface
                          • Added a node to filter arrays based on a boolean condition
                          • Improved UI usability, added connection snapping
                          • Added a new advanced instancing sample
                          [flash:3g2bze9l]https://www.youtube.com/v/dtfgFEk-ELI[/flash:3g2bze9l]
                            A little cup of tea with some milk? πŸ˜‰
                            French VIZ manualUp Dated
                            • PixeroP
                              Pixero
                              Thanks for the update. πŸ‘
                              Now I really got to find some time to try it out a bit more.
                              • E
                                Evers
                                Are there any examples showing the full potential of this plugin?
                                It's released, but the product site is quite unconvincing.
                                Is it possible to make a dynamic component out of the Viz definition?
                                • 5 / 5
