    Introducing Viz - parametric modeling for SketchUp
    extensions
    85 Posts 21 Posters 39.8k Views 21 Watching
    • genki.ttG
      genki.tt
      Thank you for rapid release !
      I could open VizPro on Mac !
      I could see the tea cup that has a big hole on bottom !
      • F
        fluid
        We just released a new version of Viz, you can grab it here.
        This version highlights:
        • Added the "Duplicate" node, to copy and instance geometry
        • Improved node editor look
        • Bug fixes
          Viz getting started guide
        [flash:36jgs09v]https://www.youtube.com/v/MjmTH2uixd4[/flash:36jgs09v]
          Pleasures' Multiplication! 😎
          Luckily seems the manual is not modified, so no need to update the French one! πŸ˜‰
          Nevertheless Youtube video added and publicity made! πŸ€“
          PS With what program do you make your tutorial ?
          • F
            fluid
            For the tutorial we used Camtasia Studio.
            • F
              fluid
              • Added support of instancing geometry made itself of components
              • Bug fixes
              • Added instancing sample
              [flash:1cisnfai]https://www.youtube.com/v/t5Zk5PWRZVs[/flash:1cisnfai]
                Skatter challenger! πŸ˜‰
                • F
                  fluid
                  We just released Viz 1.2.0, you can grab it here.
                  • Added new nodes for sampling arbitrary attributes (such as normal, texture coordinates, etc) on geometry surface
                  • Added a node to filter arrays based on a boolean condition
                  • Improved UI usability, added connection snapping
                  • Added a new advanced instancing sample
                  [flash:3g2bze9l]https://www.youtube.com/v/dtfgFEk-ELI[/flash:3g2bze9l]
                    A little cup of tea with some milk? πŸ˜‰
                    French VIZ manualUp Dated
                    • PixeroP
                      Pixero
                      Thanks for the update. πŸ‘
                      Now I really got to find some time to try it out a bit more.
                      • E
                        Evers
                        Are there any examples showing the full potential of this plugin?
                        It's released, but the product site is quite unconvincing.
                        Is it possible to make a dynamic component out of the Viz definition?
                        • 5 / 5
