    Foundation Plugin
    451 Posts 15 Posters 614.5k Views 15 Watching
    • K
      KrisM
      My feeling about slopes is that I absolutely want to model them. There are a lot of instances where having the real slope gives you valuable information with regard to the actual construction. A case in point would be - What is the real height of a deck beam. I would rather have this information on the drawing or model rather that having the carpenter figuring it out on the jobsite.
      With respect to garage slabs, I usually have the slab 2" min below the adjacent house floor with a 2" slope from the back of the garage to the garage door.
      • pbacotP
        And where do you set the floor height from. Usually I end up working out what is best at the rear of the garage and sloping from there.
        • medeekM
          medeek
          Here is a quick study on a garage slab that slopes 3" over about 24':
          https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=56f0432b-fa0a-4b44-852c-5c5c8370351e
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          What to do with the slope at the garage door? I've flattened it out but that leaves a line in the slab.
          At the side door entrance the right side of the slab is about 3/8" higher than the left side. Entrances that are parallel to the slope will have this property (problem?).
          At the rear of the garage the slab is 6" below the top of the foundation and at the garage door it is 9" below the top. Perusing through different plan sets I've collected over the years this seems pretty typical for the slope (1/8" in 12").
          I think I should probably make the slope an option so those that want to model it can.
          Rather than make the slope a percent grade or degrees I think it would be easiest to let the users specify a total rise or drop for the entire slab.
          Nathaniel P. Wilkerson PE
          Medeek Engineering Inc
          design.medeek.com
          • medeekM
            medeek
            I was playing with the Dibac plugin a little bit today and I really like the wall creation tool or how it works when selecting the 2D wall layout. I think I can program something like this for stem wall creation (polyline) that would allow the user to select any random stem wall layout. I've pretty much got it worked out already but I'm trying to figure out how to do that little trick with the tab key which allows the user to toggle the wall justification. Any hints would be appreciated.
            design.medeek.com
            • medeekM
              medeek
              I've been investigating attributes today trying to get a better handle on this aspect of SketchUp. I've noticed that the housebuilder plugin creates a category called "einfo" and stores a number of variables one of which is the "origin". If you manually move the wall group the origin attribute will automatically reflect this change in location. This is exactly the feature I need for my various assemblies (groups) so that I can add an edit feature. Howevever, I can't seem to figure out how this attribute is automatically updating. When I create an "origin" attribute under a "einfo" category it does not update. I must be missing something.
              design.medeek.com
              • jujuJ
                juju
                Try asking those questions in the develops section, I'm sure someone there would be able to point you in the right direction. Most visitors (including me) that frequent this section (and others) would not be able to even comprehend what you're referring to.
                • medeekM
                  medeek
                  The current home designer I am working for likes to use 2x4 bearing walls versus a post and beam system in their crawl spaces:
                  http://www.callhomeinspector.com/s/cc_images/cache_2922621504.jpg?t=1336939826
                  I am wondering how common this method is and if it is something I should add into the foundation plugin as another variant.
                  design.medeek.com
                  • facerF
                    facer
                    Crawl Space - Access
                    Suggest an "access opening" in the stud spacing for any future inspection or maintenance.
                    Centre location would be logical, miss one stud and design support for floor joist.
                    • medeekM
                      medeek
                      For a stud wall your right you need access doors or openings. I will make another function that lets one place the opening after the fact, that way they can be located by the user.
                      design.medeek.com
                      • medeekM
                        medeek
                        Does anyone have any details showing the access door through a strip footing and bearing stud wall. I have one here but I would be interested in seeing what others use so I can determine the most popular way of framing this up and then implement it.
                        design.medeek.com
                          MtnArch
                          What I've done in the past (and seems to work the best) is simply frame it as a door opening (36" or 48") with a 4x4 (or 4x6) with the top flush with the double top plate.
                          Highest Regards,
                          Alan T. Hendry, RA
                          Architect
                          • medeekM
                            medeek
                            Something like this?
                            http://biotoxinjourney.com/wp-content/uploads/2016/02/Sealed-Crawl-Space.jpg
                            design.medeek.com
                            • facerF
                              facer
                              Medeek,
                              I am curious about the "white" membrane, is there to be a concrete slab poured?
                              If so what was the construction sequence?
                              If it is a moisture barrier how is it protected?
                                MtnArch
                                Nathaniel -
                                Yep, that's basically it (though I've also see the top plates lapped into the header as well).
                                Highest Regards,
                                Alan T. Hendry, RA
                                Architect
                                • medeekM
                                  medeek
                                  Version 1.0.3 - 08.28.2016
                                  • Enabled interior bearing wall(s) with strip footing.
                                  http://design.medeek.com/resources/images/foundation_su10_800.jpg
                                  View model here:
                                  3D Warehouse
                                  I still need to enable the ability to add framed openings into the interior stud walls. Interior stud/bearing walls can be created with single or double top plates and can be full span or partial spanning as shown in the image above.
                                  Also note that the studs are aligned from the right side of the stemwall foundation edge so that they line up directly under the floor joists.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    My new job has kept me away for the last few weeks so that getting anything done on the plugins has been a real challenge. Even so I've been giving some thought to stepped footings/foundations and would like some input from the designers and architects out there on what is common practice and what they would like to see available for this sort of feature within the plugin.
                                    http://design.medeek.com/resources/images/foundation_su11_800.jpg
                                    View mode here:
                                    3D Warehouse
                                    Note that I messed up on this model the exterior cripple/pony walls should have only had one top plate so that the combined top plate from the shallow sections and the single top plate would have created the typical double top plate.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      One question I've had is how much should the stemwall overshoot the step in the footing before stepping down itself? I've seen different ratios used (ie. rise/run) but I'm trying to find a consensus on what is common practice.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        A typical step in the footing might look something like this:
                                        http://design.medeek.com/images/misc2/STEPPED_FOOTING1.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          I've repackaged the .rbz file this evening so that when it installs into SU 2017 the extension will have the appropriate hash file and appear as "signed". The foundation plugin may have the same issue with hashed file as the truss plugin, however it does not in any way affect the functionality of the plugin.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.0.4 - 11.27.2016
                                            • Enabled rebar and mesh reinforcement for slab on grade foundations.
                                            http://design.medeek.com/resources/images/foundation_su13_800.jpg
                                            http://design.medeek.com/resources/images/foundation_su12_800.jpg
                                            Footing reinforcement is #3 - #8 bar.
                                            Slab reinforcement is welded wire mesh or #3 - #5 bar.
                                            European metric sizes are available in the metric mode.
                                            View model here:
                                            3D Warehouse
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 2 / 23
