    MSPhysics 1.0.3 (16 October 2017)
    928 Posts 171 Posters 1.3m Views 172 Watching
      I have that in French 2016 Make (Windows 10)
      Erreur de chargement du fichier C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
      Error: #<NoMethodError: undefined method sdl_used?' for MSPhysics:Module> C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb:475:in <top (required)>'
      C:/Program Files/SketchUp/SketchUp_Fr 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp_Fr 2016/Tools/extensions.rb:197:in load'
      C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
      C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
      Curious because works fine in French 2015 Make! (Windows 10)
        Anton_S
        TIG, yes, the error occurred while loaded main.rb, which occurs during registration, and I was able to fix it through trial and error.
        In case anyone is interested what went wrong, here it is. So, msp_lib.so, the c extension of MSPhysics, is dependent on other dlls, like newton.dll and SDL2.dll. In order to load msp_lib.so it is necessary to first load the required dlls, or specify the path where the dlls are to be found when msp_lib.so is loaded. The ENV['PATH'] variable does just that. It contains a list of paths where the required dlls are to be searched for. Instead of manually loading the required dlls, I append another path to the ENV['PATH'] variable. That way when msp_lib.so is loaded, it knows where to find newton.dll, SDL2.dll, and all the other required dlls, and loads them automatically. Now, here is where to problem came in. The ENV['PATH'] variable accepts paths formatted in Windows-1252 encoding (very similar to ASCII-8BIT encoding). The path I appended was formatted with UTF-8 encoding. It worked without concerns when non-special characters were used; however, as reported, compatibility errors arise when they are used. The fix seemed pretty straightforward, I had to force encode the appended path with ASCII-8BIT encoding. Yet, after that, the path seemed invalid; A different error displayed, saying, "The specified module could not be found," meaning the required dlls could not be found, which indicated that the appended path was corrupted. So, I tried encoding it with Windows-1252, just to see if it it will fix the error, however the path still remained invalid. The only thing that fixed it was unpacking from Unicode and repacking to Chars: path.unpack('U*').pack('C*'), which is by default encoded to ASCII-8BIT. I don't know if this is a universal fix, but it does fix the Encoding::CompatibilityError on an account named, Användaren. What's strange is that force_encoding('ASCII-8BIT') improperly converts from UTF-8 to ASCII-8BIT. Whereas ideally, it should do the same thing as the unpack(U*').pack('C*') does. Anyway, glad that didn't took forever to fix.
        I will upload it soon. Once again thanks for reporting.
        Anton
          Anton_S
          Micceo, it's fixed now. Update to 0.9.3.
          Faust, I fixed the crash that would occur when loading large replay files.
          Anton
          • F Offline
            faust07
            Anton, saving and loading large simulations works great now! Thank you so much!
            I've illustrated the Truster problem on start of a simulation with little GIF-films in the post "MSPhysics tests and questions" ...
            • I Offline
              ITman496
              This is amazing! Using it to design all sorts of mechanical systems for things I make!
              Question, though. I've messed around with the corkscrew and the curvy joints.. Is there an elegant way to simulate a threaded rod actuating a nut? Such as a lead screw? A constraint where you set the ratio of rotations to a certain unit of distance, so that if I have a gear assembly turning a bolt, it can crank a threaded rod that is linked to a piston constraint back and forth? Or vice versa? That appears to be the only thing I can't figure out how to do, other then that, this is the best plugin I've ever downloaded. Nice nice work!
              EDIT: after talking to the author!
              Simply link a joint to another joint and it is very self explanatory after that!
              • MALAISEM Offline
                MALAISE
                Hello Guys
                Does someone try to export some animation in png files, to merge them into an avi file (Makeavi) ?
                When starting the MSPhysics, animating the SKP file then using MSPhysics export to pictures, only the 60 first are generated.
                I followed step by step explanations but unsuccessfull, just an "fixed movie" AVI file is made...
                Any help appreciated.
                Pierre
                drafty (w.i.p) sketchup model
                • F Offline
                  faust07
                  @ Malaise: there is an object (with the name "echantillon") in your model on z = -5580 m. It is connected to a slider. In my tests it courses the model running out of the viewport. It could be the reason for the export problem.
                  • MALAISEM Offline
                    MALAISE
                    Hi Faust07
                    I effectively saw some strange behavior without finding the origine. Many thanks
                    having answered. For your, It's a part of an Diffractometer linked with automation process. (Echantillon means sample)
                    Cheers.
                    Pierre
                    • MALAISEM Offline
                      MALAISE
                      Hallo Guys
                      Good to know ( on SketchUp2015 or 2016 /windows 32 bit), It seems that only the 60 first
                      pictures are exported. Perhaps, it's matter of Windows Version.
                      Pierre
                      • F Offline
                        faust07
                        Here the little corrected model. Works flawlessly. The original animation comprises approximately 950 individual images.
                        cinématique D4 B_2.skp
                          SynSuka3D
                          fr: je voudrais faire pivoté un solide dans un groupe please !
                          eng: I would like to rotate a body found in a compossent !!
                            Anton_S
                            You can't rotate body inside components. You can however make the body to rotate with respect to the parent component using joints. This can be done by creating s joint inside s component. Then use the joint connection tool to connect the parent component to the other components.
                              SynSuka3D
                              thanks Anton_S. I would like to select a body which is in a group !!
                              and implement action (rotated, hide, change color ....)
                                Anton_S
                                You can do this with MSPhysics but fredoa animation tool would be a lot more suitable for your purpose.
                                  SynSuka3D
                                  I did it! Here is my model
                                    bambutec
                                    Hey Guys,
                                    just dowloaded MSPhysics. Using a model like ray_test_0.9.skp , for me any change of properties like friction coefficients resp. change of materials do not reflect in how body´s behave. What could be the reason ?
                                    My platform is a mac on OS X 10.11.4 with SketchUp Pro 2016 16.0.19913.
                                    My intend is to simulate slide configurations and other attractions in Play and Leisure applications. Close to reality behavior is essential.
                                    Would be so great if this works, it is very promising !!
                                    Regards
                                    Uli
                                      realkim0123
                                      There is the only install program for Window environments.
                                      How can I install MSPhysics in Mac OS X?
                                        cristyan
                                        Hello !! Can someone tell me if an object can change his density if touched by another object ?? as in this file from metal to wood and from wood to metal ..
                                        1.skp
                                        • andreyshellA Offline
                                          andreyshell
                                          Hi Anton!
                                          Thank you for your work! It helps me start doing things, I never did before!
                                          Testing plugin I repeat chain, like this one.
                                          https://youtu.be/AewFaqurPgc
                                          I know, it's a SkethcyPhisics, I follow an approach.
                                          But my chain brakes! I use different material, no result. Could you help me, what's wrong?
                                          Chain brakes in MSPhysics - wrong parameters (?)
                                            cristyan
                                            Hello !! andreyshell - Simulation > Update Timestep > set to x 1/6 (1/360) or more if is needed... hope that will help you .
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 46
                                            • 47
                                            • 20 / 47
