    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
      micceo
      Hi! Curious about this plugin but can't get it started.
      I'm on SketchUp 2016, 16.1.1449 64 bit, Windows 10 Version 1511 (10586. 494)
      Tried the .exe-setup and the .rbz, but it ends with the same error.
      Error Loading File C;/Users/Användaren/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
      Error; #<Exception; An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons;
      • Encoding;;CompatibilityError; incompatible character encodings; Windows-1252 and UTF-8
      C;/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb;197;in require' C;/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb;197;in load'
      C;/Users/Användaren/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in register_extension' C;/Users/Användaren/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in <module;MSPhysics>'
      C;/Users/Användaren/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
      Plugin dir
       Directory of C;\Users\Användaren\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
      2016-07-31  14;17    <DIR>          .
      2016-07-31  14;17    <DIR>          ..
      2016-07-31  14;13    <DIR>          ams_Lib
      2016-07-31  14;18             1 577 ams_Lib.rb
      2016-07-16  20;17    <DIR>          as_flatten
      2016-07-16  20;17             3 070 as_flatten.rb
      2016-07-31  14;13    <DIR>          MSPhysics
      2016-07-31  14;17             3 498 MSPhysics.rb
      2016-07-26  17;59             3 498 MSPhysics.rbx
      2016-07-31  14;05    <DIR>          SketchUcation
      2016-07-31  14;05             5 508 SketchUcation.rb
      2016-05-21  00;35    <DIR>          su_advancedcameratools
      2016-02-24  12;28             1 715 su_advancedcameratools.rb
      2016-05-21  00;35    <DIR>          su_dynamiccomponents
      2016-02-24  12;28             1 780 su_dynamiccomponents.rb
      2016-05-21  00;35    <DIR>          su_sandbox
      2016-02-24  12;28             1 706 su_sandbox.rb
      2016-05-21  00;35    <DIR>          su_trimble_connect
      2016-02-24  12;28             1 339 su_trimble_connect.rb
      2016-05-21  00;35    <DIR>          su_webtextures
      2016-02-24  12;28             1 299 su_webtextures.rb
       Directory of C;\Users\Användaren\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MSPhysics
      2016-07-31  14;13    <DIR>          .
      2016-07-31  14;13    <DIR>          ..
      2016-07-31  14;17            53 883 body.rb
      2016-07-31  14;17            16 487 body_context.rb
      2016-07-31  14;17             5 978 CHANGELOG.md
      2016-07-31  14;17            24 128 collision.rb
      2016-07-31  14;17             8 561 common_context.rb
      2016-07-31  14;17             1 269 contact.rb
      2016-07-31  14;17               230 controller_context.rb
      2016-07-31  14;17             9 154 control_panel.rb
      2016-07-31  14;13    <DIR>          css
      2016-07-31  14;17           100 030 dialog.rb
      2016-07-31  14;17             1 174 djoint_angular_gear.rb
      2016-07-31  14;17             1 166 djoint_linear_gear.rb
      2016-07-31  14;17             1 206 djoint_rack_and_pinion.rb
      2016-07-31  14;17             6 759 double_joint.rb
      2016-07-31  14;17             2 682 Examples.md
      2016-07-31  14;13    <DIR>          external
      2016-07-31  14;17             1 992 FAQ.md
      2016-07-31  14;17               613 hit.rb
      2016-07-31  14;13    <DIR>          html
      2016-07-31  14;13    <DIR>          images
      2016-07-31  14;17             6 904 joint.rb
      2016-07-31  14;17             5 022 joint_ball_and_socket.rb
      2016-07-31  14;17            48 285 joint_connection_tool.rb
      2016-07-31  14;17             5 729 joint_corkscrew.rb
      2016-07-31  14;17            10 167 joint_curvy_piston.rb
      2016-07-31  14;17             7 951 joint_curvy_slider.rb
      2016-07-31  14;17               677 joint_fixed.rb
      2016-07-31  14;17             7 489 joint_hinge.rb
      2016-07-31  14;17             4 307 joint_motor.rb
      2016-07-31  14;17             5 645 joint_piston.rb
      2016-07-31  14;17             5 645 joint_servo.rb
      2016-07-31  14;17             3 513 joint_slider.rb
      2016-07-31  14;17             5 683 joint_spring.rb
      2016-07-31  14;17             7 322 joint_tool.rb
      2016-07-31  14;17             5 900 joint_universal.rb
      2016-07-31  14;17             2 819 joint_up_vector.rb
      2016-07-31  14;13    <DIR>          js
      2016-07-31  14;17             1 107 LICENCE.txt
      2016-07-31  14;17             1 649 LICENSE.FLAC.txt
      2016-07-31  14;17            25 892 LICENSE.mikmod.txt
      2016-07-31  14;17                59 LICENSE.modplug.txt
      2016-07-31  14;17               950 LICENSE.NewtonDynamics.txt
      2016-07-31  14;17             1 625 LICENSE.ogg-vorbis.txt
      2016-07-31  14;17            25 873 LICENSE.smpeg.txt
      2016-07-31  14;17            49 927 main.rb
      2016-07-31  14;17             3 945 material.rb
      2016-07-31  14;17             1 424 materials.rb
      2016-07-31  14;13    <DIR>          models
      2016-07-31  14;17             4 881 MSPhysics.hash
      2016-07-31  14;13    <DIR>          osx32
      2016-07-31  14;13    <DIR>          osx64
      2016-07-31  14;17            15 179 Overview.md
      2016-07-31  14;17               428 README-SDL.txt
      2016-07-31  14;17             1 019 README-SDL_mixer.txt
      2016-07-31  14;17             2 948 README.md
      2016-07-31  14;17           120 465 replay.rb
      2016-07-31  14;17            10 556 scene_data.rb
      2016-07-31  14;17               753 script_exception.rb
      2016-07-31  14;17            12 618 settings.rb
      2016-07-31  14;17           135 307 simulation.rb
      2016-07-31  14;17             1 011 TODO.md
      2016-07-31  14;13    <DIR>          win32
      2016-07-31  14;13    <DIR>          win64
      2016-07-31  14;17            14 115 world.rb
        You have a non-ASCII character in your Windows user-name [Användaren]
        This is a well known and long running problem with Ruby.
        Although the newer Ruby with v2016 is more forgiving, there are still some issues...
        It's recommended you always avoid accents in your Windows user-name...
        Can you try with an alternative user-name ?
        The extension's author might be able to "force encoding" to UTF-8 for any strings it uses, like the user-path name etc - when in >=v2015...
        But that's his fix for the future...
          micceo
          I had "ä" as a suspected but didn't try another account.
          Searched the forums here, but no hit on UTF-8 or Windows-1252.
          Thank you for the swift response. I'll try out with another user account.
            Ralphxyz
            micceo, I had this problem! The solution was to use the 2015 Sketchup folder not the 2016 folder!
            re: /AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/
            Had to be: /AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/
            This was for Sketchup 15 PRO!
            Ralph
              Anton_S
              Ralph, you probably had another issue because I can reproduce this with SU2016 and Win10 on a custom-created account, named, Användaren.
              TIG, MSPhysics does have path.force_encoding('UTF-8') if RUBY_VERSION !~ /1.8/. However, it could be the case that I missed it somewhere. I'll check it out.
              Micceo, I'll look into it. Thanks for reporting.
              Anton
                Looks like the error occurs when setting up the extension.
                Try forcing the encoding of the file path you pass to the extension making code in the loader RB...
                  I have that in French 2016 Make (Windows 10)
                  Erreur de chargement du fichier C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                  Error: #<NoMethodError: undefined method sdl_used?' for MSPhysics:Module> C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb:475:in <top (required)>'
                  C:/Program Files/SketchUp/SketchUp_Fr 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp_Fr 2016/Tools/extensions.rb:197:in load'
                  C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
                  C:/Users/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
                  Curious because works fine in French 2015 Make! (Windows 10)
                    Anton_S
                    TIG, yes, the error occurred while loaded main.rb, which occurs during registration, and I was able to fix it through trial and error.
                    In case anyone is interested what went wrong, here it is. So, msp_lib.so, the c extension of MSPhysics, is dependent on other dlls, like newton.dll and SDL2.dll. In order to load msp_lib.so it is necessary to first load the required dlls, or specify the path where the dlls are to be found when msp_lib.so is loaded. The ENV['PATH'] variable does just that. It contains a list of paths where the required dlls are to be searched for. Instead of manually loading the required dlls, I append another path to the ENV['PATH'] variable. That way when msp_lib.so is loaded, it knows where to find newton.dll, SDL2.dll, and all the other required dlls, and loads them automatically. Now, here is where to problem came in. The ENV['PATH'] variable accepts paths formatted in Windows-1252 encoding (very similar to ASCII-8BIT encoding). The path I appended was formatted with UTF-8 encoding. It worked without concerns when non-special characters were used; however, as reported, compatibility errors arise when they are used. The fix seemed pretty straightforward, I had to force encode the appended path with ASCII-8BIT encoding. Yet, after that, the path seemed invalid; A different error displayed, saying, "The specified module could not be found," meaning the required dlls could not be found, which indicated that the appended path was corrupted. So, I tried encoding it with Windows-1252, just to see if it it will fix the error, however the path still remained invalid. The only thing that fixed it was unpacking from Unicode and repacking to Chars: path.unpack('U*').pack('C*'), which is by default encoded to ASCII-8BIT. I don't know if this is a universal fix, but it does fix the Encoding::CompatibilityError on an account named, Användaren. What's strange is that force_encoding('ASCII-8BIT') improperly converts from UTF-8 to ASCII-8BIT. Whereas ideally, it should do the same thing as the unpack(U*').pack('C*') does. Anyway, glad that didn't took forever to fix.
                    I will upload it soon. Once again thanks for reporting.
                    Anton
                      Anton_S
                      Micceo, it's fixed now. Update to 0.9.3.
                      Faust, I fixed the crash that would occur when loading large replay files.
                      Anton
                      • F Offline
                        faust07
                        Anton, saving and loading large simulations works great now! Thank you so much!
                        I've illustrated the Truster problem on start of a simulation with little GIF-films in the post "MSPhysics tests and questions" ...
                        • I Offline
                          ITman496
                          This is amazing! Using it to design all sorts of mechanical systems for things I make!
                          Question, though. I've messed around with the corkscrew and the curvy joints.. Is there an elegant way to simulate a threaded rod actuating a nut? Such as a lead screw? A constraint where you set the ratio of rotations to a certain unit of distance, so that if I have a gear assembly turning a bolt, it can crank a threaded rod that is linked to a piston constraint back and forth? Or vice versa? That appears to be the only thing I can't figure out how to do, other then that, this is the best plugin I've ever downloaded. Nice nice work!
                          EDIT: after talking to the author!
                          Simply link a joint to another joint and it is very self explanatory after that!
                          • MALAISEM Offline
                            MALAISE
                            Hello Guys
                            Does someone try to export some animation in png files, to merge them into an avi file (Makeavi) ?
                            When starting the MSPhysics, animating the SKP file then using MSPhysics export to pictures, only the 60 first are generated.
                            I followed step by step explanations but unsuccessfull, just an "fixed movie" AVI file is made...
                            Any help appreciated.
                            Pierre
                            drafty (w.i.p) sketchup model
                            • F Offline
                              faust07
                              @ Malaise: there is an object (with the name "echantillon") in your model on z = -5580 m. It is connected to a slider. In my tests it courses the model running out of the viewport. It could be the reason for the export problem.
                              • MALAISEM Offline
                                MALAISE
                                Hi Faust07
                                I effectively saw some strange behavior without finding the origine. Many thanks
                                having answered. For your, It's a part of an Diffractometer linked with automation process. (Echantillon means sample)
                                Cheers.
                                Pierre
                                • MALAISEM Offline
                                  MALAISE
                                  Hallo Guys
                                  Good to know ( on SketchUp2015 or 2016 /windows 32 bit), It seems that only the 60 first
                                  pictures are exported. Perhaps, it's matter of Windows Version.
                                  Pierre
                                  • F Offline
                                    faust07
                                    Here the little corrected model. Works flawlessly. The original animation comprises approximately 950 individual images.
                                    cinématique D4 B_2.skp
                                      SynSuka3D
                                      fr: je voudrais faire pivoté un solide dans un groupe please !
                                      eng: I would like to rotate a body found in a compossent !!
                                        Anton_S
                                        You can't rotate body inside components. You can however make the body to rotate with respect to the parent component using joints. This can be done by creating s joint inside s component. Then use the joint connection tool to connect the parent component to the other components.
                                          SynSuka3D
                                          thanks Anton_S. I would like to select a body which is in a group !!
                                          and implement action (rotated, hide, change color ....)
                                            Anton_S
                                            You can do this with MSPhysics but fredoa animation tool would be a lot more suitable for your purpose.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 46
                                            • 47
                                            • 20 / 47
