    [plugin]Export arcs, circles and vertex to dxf ?
    extensions
    13 Posts 2 Posters 3.1k Views 2 Watching
      circles = []
      Sketchup.active_model.selection.grep(Sketchup;;Edge).each{|e|
        c = e.curve ### it's nil if a non-curve edge
        if c && c.is_a?(Sketchup;;ArcCurve) ### might be a circle or an arc
          circ = true
          c.vertices.each{|v|
            ### vertex has at least edges, but are there at least 2 and are both in the curve
            es = 0
            v.edges.each{|ee| es += 1 if c.edges.include?(ee) }
            if es != 2 ### it's an arc
              circ = false
              break
        else ### it's not a curve, or if it is it's not a circle or an arc
          circ = false
          next
        circles << c if circ && ! circles.include?(c) ### only add it to list once
      circles.each{|c| ### get circle's properties here, e.g.
        p c.center
        p c.radius
        p c.normal
      • IltisI Offline
        Iltis
        Hello TIG,
        Thank you very much 👍 , I will try to do a first sample.
        If you have the time to answer :
        1/ Could you look the adds in your code (below), to get the arc entities. Am I right?
        2/ If circ=false, how to get the Sketchup points of the entity?
        Renaud
            circles = []
        		arcs = []
                circ = true
        				arc = false
                c.vertices.each{|v|
                  es = 0
        						arc = true
                    break
                circ = false
                next
              circles << c if circ && ! arc && ! circles.include?(c) ### only add it to list once
        			arcs << c if circ && arc && ! arcs.include?(c) ### only add it to list once
              p c.center
              p c.radius
              p c.normal
            arcs.each{|c| ### get arcs's properties here, e.g.
              p c.center
              p c.radius
              p c.normal
        			p c.start_angle
        			p c.end_angle
          I think you have an error in collecting the circles and arcs.
          if es != 2 ### it's an arc arc = true circ = false break end
          later
          circles << c if circ && ! circles.include?(c) ### only add it to list once arcs << c if arc && ! arcs.include?(c) ### only add it to list once
          • IltisI Offline
            Iltis
            OK, right.
            • IltisI Offline
              Iltis
              Hello TIG,
              When arc=false and circle=false, I wanted to store the entity in an array, could y help me? So at the end, I will use the edges of these entities for writing the polylines.
                You now have two arrays - for circles and arcs.
                Process each collected 'curve' in turn.
                e.g.
                circles.each{|c|
                  c.edges.each{|e| # the curve's edges
                    # process each edge 'e'
                Do the same for the 'arcs' array...
                As it stands, you have arrays of curves which define circles of edges.
                Those 'collections' are pointing to their 'edges' - i.e. defining their 'segments', which can be used as you want later...
                • IltisI Offline
                  Iltis
                  I misspoke, sorry. I'm OK for the arc and circle. They will be writen in the DXF file as ARC entity and CIRCLE entity.
                  What I don't see is how to collect the edges of the vertices of other entities of the selection/loop to write polylines (it's better than just lines for selection in the CAD softwares), when it's not an arc or a circle, in the "else" section of the previous code :
                      circ = false
                      arc = false
                      next
                  To write as polylines the dxf entities which are not circle or arc, I will use the following functions(*). The function dxf_write_polyline must be modified, because it's based on the loops of the faces, and the loop will be broken - or ignored - by the arcs and circles.
                  tform=Geom;;Transformation.new()
                  layername=model.active_layer.name
                  def dxf_transform_vertex(vertex, tform)
                     point = Geom;;Point3d.new(vertex.position.x, vertex.position.y, vertex.position.z)
                     point.transform! tform
                     point
                  def dxf_write_polyline(face, tform, layername)
                   face.loops.each do |aloop|
                    $dxf_file.puts("  0\nPOLYLINE\n 8\n"+layername+"\n 66\n     1")
                    $dxf_file.puts("70\n    8\n 10\n0.0\n 20\n 0.0\n 30\n0.0")
                    for j in 0..aloop.vertices.length do
                      if (j==aloop.vertices.length)
                        count = 0
                      else
                        count = j
                      point = dxf_transform_vertex(aloop.vertices[count],tform)
                      $dxf_file.puts( "  0\nVERTEX\n  8\nMY3DLAYER")
                      $dxf_file.puts("10\n"+(point.x.to_f * $unit_conv).to_s)
                      $dxf_file.puts("20\n"+(point.y.to_f * $unit_conv).to_s)
                      $dxf_file.puts("30\n"+(point.z.to_f * $unit_conv).to_s)
                      $dxf_file.puts( " 70\n     32")
                    if (aloop.vertices.length > 0)
                      $dxf_file.puts( "  0\nSEQEND")
                  Thank you very much.
                  (*)existing plugin from http://www.guitar-list.com, original authors: Nathan Bromham, Konrad Shroeder
                  • IltisI Offline
                    Iltis
                    In fact, there is the problem of the order of the vertices to make the polylines. I think I must follow the loops, like in the initial code of guitar-list, but I must test the ".curve" of each vertex and extract the arcs, circles, and the polylines with vertices in the order. A little tricky for me, I will take a paper and a pencil! 😄
                      Look at my 'Weld' tool.
                      That takes selected edges, and then welds them into a curve.
                      It has to sort the edges out in order and also get the start/end points correctly ordered.
                      However, a non-arc curve has a list of ordered vertices method, so you can get their positions as points using:
                      points = curve.vertices.collect{|v| v.position }
                      then use
                      points.each_with_index{|p, i| model.active_entities.add_text(i.to_s, p) }
                      to label the points to demonstrate to yourself that they are indeed ordered...
                      • IltisI Offline
                        Iltis
                        Thanks TIG, I will work on it.
                        • IltisI Offline
                          Iltis
                          Hello TIG,
                          Like other people, I have the following problem : with the (Sketchup::ArcCurve) entities, the arcs are always rotated, with the .start_angle value equal to 0.0 (and not equal to the angle with the X axe, the API documentation is wrong on this point in my situation - working with the entities of the loops).
                          Do you have a clean (and 3D) workaround?
                          Best regards,
                          Renaud.
                          • IltisI Offline
                            Iltis
                            I just saw that the .xaxis propery of the arcs are rotated => start_angle=0 is right, because the reference is wrong. OK, knowing that, I can see how to do this.
