    Coloring components
    9 Posts 5 Posters 958 Views 5 Watching
    • Bryan KB
      I'm not sure how to frame this question.
      I have colored individual faces in my component and would like to know if there is a way to undo this. It has created a problem when I try to color the entire component when selected as a group.
      In other words, when I select the component and try to apply an overall color or material, it will only color some faces and what seems to me, not the individual faces I colored when I was in edit mode.
      Thanks.
      • P
        pcmoor
        open the component, select all (control A) and choose the default (right side top) in the material browser and paint
          Philip has shown one way. I think a lot of folks miss the "dive flag" in Materials as the default material. Another option that might be faster is to delete the colors from the In Model library. Switch to In Model, right click on the color swatch and choose Delete. You'll be asked if you want to replace the color with the default material.
          Generally it is better to paint faces rather than component/group wrappers and, as you've discovered, materials on faces override materials on wrappers.
          • Bryan KB
            Thanks Phillip and Dave and sdmitch. That worked perfectly.
            I thought it might me something simple I was overlooking. Geez, 5 years (wait. what? 8 years?) and I'm still learning the basics.
            Thanks again.
            • BoxB
              Just to add to all that, Thomthom has an excellent Materials tool plugin that can help even after you've learned the Basics. πŸ˜‰
              • Bryan KB
                Interesting! Do you have more information on that? Thanks.
                • BoxB
                  Does this help?
                  http://sketchucation.com/pluginstore?pln=tt_material_tools
                  • Bryan KB
                    @box said:
                    Does this help?
                    Yes. Thanks! ThomThom does amazing work.
                    • sdmitchS
                      sdmitch
                      Thanks.
                      Something like this?
                      Remove Face Colors.rb
                      http://sdmitch.blogspot.com/
