    Sphere cover by cone
    10 Posts 5 Posters 1.1k Views 5 Watching
      glandu
      I search how do a sphere cover by cone.
      Make one by one are so long and copy past aren't very clean.
      Can you give me a solution to do this ?
      Thanks a lot.
      Kind regards,
      Tom
        Post an image of what you want to model.
          glandu
          I would like someone like this:
          https://img-new.cgtrader.com/items/46475/sphere_picots_3d_model_ca062d01-838f-49a8-b23d-5497786b08a5.jpg
          But with sharp cone.
          King regards,
          Tom
            First you must "spherise" a cube (if you want exactly the image above!)
            So Artisan and/or Subd is you friend!
            Or load a Special Sphere by Taffgoch β˜€
            then
            Component on face by Chris Fullmer is for you! πŸ˜‰
            http://sketchucation.com/forums/download/file.php?id=23090&t=1
            Or Suforyou S4U to Components
            (better because each component is resized! If needing for other thing!)
              glandu
              Thanks for component on face, it's an amazing plugins.
              I juste have a question, how can i choose the side of face ?
              I want avoid this:
              http://s33.postimg.org/a1brnltjj/inverse.png
              Thanks a lot.
              Kind regards,
              Tom
                You need to correct the face orientation on the sphere so the white front faces are out. Before adding the cones, select the surface of the sphere, right click and choose Reverse Faces. The cone needs to be corrected also before running the extension.
                This is another good example of why face orientation matters.
                • Z Offline
                  ZahariStoyanov
                  Also, to achieve the exact thing from the photo, you need to either use subD starting with a simple cube or manually make 1/6 of the sphere(think of the sphere as a cube) πŸ˜„
                    As said on my previous post! πŸ˜„
                    • Z Offline
                      ZahariStoyanov
                      Oh, my bad πŸ˜„
                        No problem! πŸ˜„
