    Drawing a Line Perpendicular to Another
    layout
    8 Posts 6 Posters 6.2k Views 6 Watching
      seasdes
      Is there a quick way to draw a line perpendicular to another in Layout.
      Using Sketchup Pro 2019
        seasdes
        I am referring to drawing lines here in SU 2016.
        • C
          Charlie__V
          off_Axis_perp.pngseasdes,
          Without an example of what you are trying to do, I can just say it is very much the same as in Sketchup.
          Use your cursor to "show" Layout the line segment you wish to reference.
          (let inference "see" by briefly running cursor on the line segment)
          After that your new line should highlight in purple/magenta when parallel and perpendicular.
          Charlie
          Edit:
          please see attached image.
            seasdes
            seasdes,
            Charlie
            Thank you Charlie_V.
            I think that I found the problem. The perpendicular (purple/magenta) will not show if trying to reference a SU model walls.
            However, it will show if I draw a line over one of the SU walls.
            Thanks again.
              sonder
              You can also force inferencing with the down arrow. This is very handy for both perpendicular and parallel lines.
              • pbacotP
                @seasdes said:
                seasdes,
                Charlie
                Thanks again.
                Maybe you don't have OBJECT SNAP turned on under the ARRANGE Menu as it does work fine to draw a perpendicular off the model for me (on a Mac). The indicator line is dim, but maybe because on a Mac it's too thin. Pressing the down arrow doesn't appear to make a difference for me.
                  It works on the PC, too.
                  It's easier to see with the stroke color set to a light gray.
                  • RichardR
                    Richard
                    Option to ensure you get it correct is to draw a line over the SU model and rotate it with "snap to object" on! I do this as a matter of course as it quicker than trying to find the right inference.
                    BUILTBRAND.COM.AU
