    Push Pull Tool
    5 Posts 3 Posters 560 Views 3 Watching
      reymond
      hello everybody
      the push pull tool no longer works.
      someone knows this problem?
      I can not pull up a face. and also not a numeric value Enter and confirm.
      version:
      sketchup pro 2016 (latest), windows.
      thank your for helps
      Sketchup & Vray Trainer
        It does work, so you must be doing something which interferes...
        Can you post an example SKP where this PushPull fails ?
          reymond
          if I pull a face, it works.
          when I press a surface it does not work.
          if I numerically the distance write and confirm with enter, it does not work.
          I have new installed the plugins:
          • Visu hole
          • Helix along curve
          • Auto smooth
          I uninstalled it again but the problem is still.
          with sketchup 2015 everything works.
            Garry K
            Please post an example that exhibits this issue.
              reymond
              I found the problem:
              the problem was that SubD plugin.
              under Extensions-subd-preferences ............... I have to uncheck replace push/pull tool
