    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 58.4k Views 40 Watching
    • O Offline
      optimaforever
      One more thing...
      If we could reverse the path for the assemblies like we can do for the profiles, it would be great!
      Now I have to weld the lines, and revert the spline with FredoTools... quite time consuming sometimes.
      And... πŸ˜„
      If we could access to fast presets (let's say 3-4 presets that remain loaded in RAM without having to reload them again from the browser), it would be perfect!
      • W Offline
        Whaat
        @optimaforever said:
        One more thing...
        Look for this feature in the upcoming version 2.1 πŸ˜„
        • O Offline
          optimaforever
          Great! If you need betatesters... πŸ˜‰
          • jujuJ Offline
            juju
            take my money already!
            • W Offline
              Whaat
              to be released very soon... πŸ˜„
              [flash=640,390:3u1ko8je]http://www.youtube.com/v/WTL-ykLdiAU[/flash:3u1ko8je]
              • pbacotP Offline
                I need to use this tool more. I am not up to date in all it can do. Though I am not looking for BOM much, this is really impressive!
                • O Offline
                  optimaforever
                  @rv1974 said:
                  Will v.2.1 deliver something besides reports (3D as we know it) ?
                  only thing i'm sure of: reversable path on assemblies πŸ˜‰
                    rv1974
                    Will v.2.1 deliver something besides those reports (3D as we know it) ?
                    • W Offline
                      Whaat
                      Yes, there are a few other small features added (like re-building multiple profile members with one operation). There will also be a new license system that will support volume licensing.
                      There are also a ton of bug-fixes
                        rv1974
                        Could you please post a brief gif to illustrate the feature?
                        • W Offline
                          Whaat
                          If you have PB2, you know the right-click context menu feature 'Rebuild Member'? Now you can select multiple profile members and then activate this feature instead of just one.
                          • O Offline
                            optimaforever
                            Thanks Dale,
                            One thing that could be handy is to be able to build assemblies from presets.
                            I mean, having to reencode the railings for each assemblies is really time consuming, not to mention each tweaking needs an update of the thumbnail, which is sometimes boring...
                            • W Offline
                              Whaat
                              Thanks Dale,
                              I hear you - perhaps this could be improved
                              • jujuJ Offline
                                juju
                                I see Profile Builder 2.1 has been released! When I select the download link (somehow there are two, refer to the same link) on the Extension Warehouse (from My Extensions), it comes up with an error message that the requested page could not be found?
                                • facerF Offline
                                  facer
                                  Following note on the listed website below gives expected availability:
                                  Profile Builder 2.1 Released! Free Upgrade for 2.0 Customers!
                                  Profile Builder 4 (profilebuilder4sketchup.com)
                                  For Extension Warehouse Licensed Users: Upgrading to 2.1 is FREE!
                                  Please upgrade to 2.1 using the Extension Warehouse
                                  once version 2.1 is available (expected by May 13th)
                                  Also note that version 2.1 will be available for SketchUp 2016 only.
                                  • W Offline
                                    Whaat
                                    That is really strange. I'll forward this to the EW team to get their input.
                                    • Mistro11M Offline
                                      Mistro11
                                      Hi, I'm an owner of Profile Builder and Artisan...great plugins!
                                      I want to purchase Profile Builder 2 but on the web page it says SU 2016 is required. I have SU 2015 Pro. Do I need to upgrade to 2016 in order to use this plugin? I really hope not.
                                      EDIT:
                                      I went back and read again. I see that 2.1 is in fact for 2016 only. Why??? I really want to buy this plugin. But now my workflow would be fragmented if I decided to get the make version of 2016. Is there any plans to make it 2015 compatible?
                                      EDIT2:
                                      Actually I cannot use this and go back to my 2015 pro setup for my projects as we are not allowed to save and load in previous versions. I'm a bit sad about this. The main reason I wanted 2.1 is so I can reverse the orientation of assemblies. It's a must have.
                                      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                      Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                      • W Offline
                                        Whaat
                                        EDIT:
                                        It was a difficult decision but, yes, 2.1 is for 2016 only. The reason is that 2.1 includes a new licensing system that could have been easily hacked with SU2015. SU2016 is more secure.
                                        You can still buy version 2.0.6 on the Extension Warehouse (SU2015 compatible) but not for long. It will likely be replaced by 2.1.0 (2016 only) within days.
                                        I understand that this may cause temporary frustration for some users and I am looking into potential workarounds. Thank you very much for your support of my plugins.
                                        • Mistro11M Offline
                                          Mistro11
                                          EDIT:
                                          Well, I just purchased 2.1 anyway because I'm a big fan of Profile Builder and I can't imagine not having this in my arsenal. My biggest issue is that I would have to upgrade my SU Pro which I cannot afford right now. I would really like to have all my tools in pro version alongside this plugin. So now I have to make sure I don't need any pro specific tools when using this which is very hard to swallow. Please find a way to make it 2015 compatible. OR.....does 2.0.6 have the reverse assembly orientation capability? If so I will grab that as well...or would that have to be a separate order even though I bought 2.1?
                                          • W Offline
                                            Whaat
                                            I'm afraid that 2.0.6 doesn't have the reverse assembly feature. It doesn't really make sense to purchase 2.0.6 from the Extension Warehouse after buying 2.1. Save your money and use it for upgrading to SU2016 instead πŸ˜„
                                            • 11
                                            • 4 / 11
