    [Preview] Wrap-R Video #5 - Quad Support
    extensions
    37 Posts 16 Posters 9.5k Views 16 Watching
    • OxerO Offline
      Oxer
      Incredible!! πŸ‘
      The definitive plugin to Unwrap and Mapping into SketchUp πŸŽ‰ πŸŽ‰
      Will have mac version?
        It's on the roadmap but not at release
        • OxerO Offline
          Oxer
          I'll have patiense 😞
            SketchUp challenges Blender! 😎
            • N Offline
              nlipovac
              Hi Rich, I use SketchUV and Roadkill when I need good mapping.
              If you guys need someone to test Wrap-r I am all in! πŸ˜„
                Thank you. We're not too far away from growing the testers so we'll be in touch. πŸ‘
                • cmeedC Offline
                  cmeed
                  Count me in for testing.
                  Work flow Question : so if I had modelled a radiator I'd then uvmapped it using wrap-r - I then wanted to make it rusty and bashed - I could take this model and uvmap into substance painter paint the rough edges and rusty corrosion then can this come back into sketchup? Would it be a .fbx?
                    of course. And because you now have a UV map Painter can bake out the cavity, AO etc that it needs.
                    • JQLJ Offline
                      JQL
                      It can easily be done cmeed.
                      You just have to export in a format you can import in substance (designer or painter).
                      Then you don't need to reimport, you simply replace your texture for the one generated by substance tools.
                      The replacement can be done in several ways:
                      • Export the bitmaps generated from substance;
                      • Nativelly inside sketchup you can use the paint bucket tool > Edit > Browse for a (new) texture;
                      • Choose one of the substance textures (probably base color or any other stuff. From painter you can bake lightinfo and export the map wich migh give you some cool ideas)
                      www.casca.pt
                      Visit us on facebook!
                      • N Offline
                        numerobis
                        Very nice! 😎
                        • cmeedC Offline
                          cmeed
                          Got it. Nice one
                            caecarvalho
                            I only found out about this amazing tool now...What's the progress of it? Any beta testing or release date already?I haven't found any recent posts about it...
                              It's in testing. The release candidate is getting final touches.
                              We will be looking for more PC only testers well versed in unwrapping.
                              If your interested mention it here.
                                caecarvalho
                                @rich o brien said:
                                I'm defnetely interested!Most of the unwrapping I do is in blender, and sometimes 3ds max. But it will be amazing to not have to leave SU environment.
                                  kaas
                                  @rich o brien said:
                                  If you still need a tester, count me in. Experienced in unwrapping uv's since 3ds-dos (for real-time purposes). I'm very interested to see if it can assist in the process of getting stuff from SU to Unreal without having to go through Blender (2nd uv channel).
                                  • duanekempD Offline
                                    duanekemp
                                    I know I'm coming in a bit late with the request, but... may I be considered for testing this?
                                    Duane Kemp
                                    Kemp Productions
                                    Puidoux, Switzerland
                                    Gallery:
                                    https://duanekemp.artstation.com/
                                      caecarvalho
                                      Any news on this front??
                                        Summer holidays has meant we are delaying the beta a few weeks. Expect news in early Sept.
                                          kaas
                                          early September is coming soon?
                                            Working on it...
                                            Trying to tie up the licensing part and nail down to documentation
