    [Preview] Wrap-R Video #5 - Quad Support
    extensions
    37 Posts 16 Posters 7.4k Views 16 Watching
      The latest alpha build of WrapR now supports Quads. If you use SUbD to model and obey the QuadFace convention with your mesh then WrapR will create a cleaner UV unwraps.
      There's also a few people currently testing WrapR so we hope to open up the beta testing to a larger pool of users soon.
      Enjoy the weekend!
      • JQLJ Offline
        JQL
        Brilliant!
        www.casca.pt
        Visit us on facebook!
          Did you try it out yet?
          • JQLJ Offline
            JQL
            Quads modelling? Not much! Unwrapping? Definetelly!
            www.casca.pt
            • FrederikF Offline
              Frederik
              This just gets better and better...!! πŸ‘
              I'd be honoured to join the wider beta-testing... πŸ˜‰
              Cheers
              Kim Frederik
                we'd be honoured to have you πŸ˜›
                  rv1974
                  What is the tune? Is it copy left?
                    Rite Of Passage-UPPM : Emir Isilay, Robert J Walsh
                    Some free YouTube tune i added to remove the deafening silence
                    • pbacotP Offline
                      πŸ‘ No silence. We're just gasping.
                      Kudos. Looks excellent.
                      • Z Offline
                        ZahariStoyanov
                        Wow! I'd like to get a taste of that! πŸ˜„
                        • OxerO Offline
                          Oxer
                          Incredible!! πŸ‘
                          The definitive plugin to Unwrap and Mapping into SketchUp πŸŽ‰ πŸŽ‰
                          Will have mac version?
                            It's on the roadmap but not at release
                            • OxerO Offline
                              Oxer
                              I'll have patiense 😞
                                SketchUp challenges Blender! 😎
                                • N Offline
                                  nlipovac
                                  Hi Rich, I use SketchUV and Roadkill when I need good mapping.
                                  If you guys need someone to test Wrap-r I am all in! πŸ˜„
                                    Thank you. We're not too far away from growing the testers so we'll be in touch. πŸ‘
                                    • cmeedC Offline
                                      cmeed
                                      Count me in for testing.
                                      Work flow Question : so if I had modelled a radiator I'd then uvmapped it using wrap-r - I then wanted to make it rusty and bashed - I could take this model and uvmap into substance painter paint the rough edges and rusty corrosion then can this come back into sketchup? Would it be a .fbx?
                                        of course. And because you now have a UV map Painter can bake out the cavity, AO etc that it needs.
                                        • JQLJ Offline
                                          JQL
                                          It can easily be done cmeed.
                                          You just have to export in a format you can import in substance (designer or painter).
                                          Then you don't need to reimport, you simply replace your texture for the one generated by substance tools.
                                          The replacement can be done in several ways:
                                          • Export the bitmaps generated from substance;
                                          • Nativelly inside sketchup you can use the paint bucket tool > Edit > Browse for a (new) texture;
                                          • Choose one of the substance textures (probably base color or any other stuff. From painter you can bake lightinfo and export the map wich migh give you some cool ideas)
                                          www.casca.pt
                                          • N Offline
                                            numerobis
                                            Very nice! 😎
