    3D Truss Models
    1.5k Posts 31 Posters 936.5k Views 30 Watching
    • medeekM Offline
      medeek
      More configurations:
      http://design.medeek.com/resources/images/truss_su108_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.4.9 - 04.04.2016
        • Added Tray truss type, configurations: (AUTO).
        • Metric input enabled for tray truss type.
        • Added gable end trusses for tray truss type.
        The next truss type I would like to add is the coffer truss but I don't have a lot of good examples or shop drawings of this truss type. Any examples of a coffer truss would be most welcome.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.5.0 - 04.11.2016
          • Added Mono Scissor truss type, configurations: (2/2, 3/3).
          • Metric input enabled for mono scissor truss type.
          • Added gable end trusses for mono scissor truss type.
          • Structural outlookers (vert. & horz.) enabled under advanced roof options for Mono Scissor (2/2, 3/3) truss types.
          http://design.medeek.com/resources/images/truss_su110_800.jpg
          When the raised heel option is selected the pitch of the bottom chord may equal the top chord creating a half vaulted parallel chord truss.
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          Raised heels are also enabled for this truss type, the combination of structural outlookers (vert & horz.) with the raised heel (wedge, slider, vert) makes for some interesting combinations and for some challenging logic/programming in order to get it all right.
          design.medeek.com
          • medeekM Offline
            medeek
            Updating the hip roof module so that an appropriate wireframe is displayed while using the roof positioning tool:
            http://design.medeek.com/resources/images/truss_su111_800.jpg
            I will roll a revision once I've finished updating all of the rafter roof types with updated wireframes (preview graphics).
            design.medeek.com
            • jujuJ Offline
              juju
              thanks!
              • medeekM Offline
                medeek
                Version 1.5.1 - 04.16.2016
                • Added Dutch Gable Rafter Roof (all advanced options enabled).
                • Added wireframe (temporary) graphics to the roof positioning tool for rafter roofs.
                http://design.medeek.com/resources/images/truss_su112_800.jpg
                View model here:
                3D Warehouse
                I still need to setup ceiling joists for hip and dutch gable roofs.
                design.medeek.com
                • medeekM Offline
                  medeek
                  A nested dutch gable roof created with the plugin. The roof is initially generated by creating three dutch gable primitives and then deleting and trimming certain elements. The most time consuming is the creation of the two valley rafters. I think it might be helpful to have some sort of valley rafter tool if I can figure out a good way of doing that.
                  http://design.medeek.com/resources/images/truss_su113_800.jpg
                  View model here:
                  3D Warehouse
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Looking at the half hip roof next. Fairly cut and dried but I'm a little undecided how to handle the birdsmouths cut of the hip rafter where it intersects the discontinuity of the gable wall. I will probably use the same birdsmouth cut on the half hip rafters as the other common rafters of the roof.
                    http://design.medeek.com/resources/images/truss_su114_800.jpg
                    View model here:
                    3D Warehouse
                    design.medeek.com
                      Remember this πŸ˜‰
                      https://gitejuralamoutena.files.wordpress.com/2014/11/charpente-recadre-signc3a9-copie.jpg
                      • medeekM Offline
                        medeek
                        Per user request:
                        Version 1.5.2 - 04.18.2016
                        • Added energy/raised heels for small span attic trusses (less than 24 ft.), 1 variant: vertical w/ strut.
                        • Added some additional logic to improve the triangulation of the upper attic of attic trusses.
                        http://design.medeek.com/resources/images/truss_su115_800.jpg
                        When I get some more time I will add in slider and wedge raised heel options for the attic truss type but at that moment it is low priority since most users seem to favor a fairly tall raised heel when utilizing it with attic trusses.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          I have been giving some thought to dormers and how to specify them. Below is a dormer design I framed in Solidworks a few years back for a garage design:
                          http://design.medeek.com/images/MISC/GARAGE4828-A6D-3_DORMER1.jpg
                          http://design.medeek.com/images/slideshow/GARAGE4828-A6D-3_FRAMING5_1024.jpg
                          Of course the numerous ways in which one could frame a dormer is probably beyond the scope of this discussion but I would like to consider what geometry needs to be determined in order to orient and size the dormer.
                          After some thought I think the following points, planes and lengths would define the geometry of a typical dormer:
                          1.) Main Roof Plane
                          2.) Attic Floor Plane
                          3.) Offset from exterior wall below (how far the dormer is out of plane from the ext. wall below).
                          4.) Pitch of Dormer roof
                          5.) Dormer width
                          6.) Dormer height (distance from attic floor plane to top plate of dormer wall)
                          7.) Window width, height, and header depth
                          8.) Dormer wall thickness (2x4 or 2x6)
                          9.) Dormer rafter depth
                          10.) Position of Dormer along length of building
                          Items 2,3 and 10 can be combined into a single point selection.
                          Revisiting this I think the location of the dormer can be established with the selection of two points and a plane (main roof plane), the rest of the parameters will be UI.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.5.3 - 04.20.2016
                            • Added Mono Cathedral truss type, configurations: (2/2, 4/4).
                            • Metric input enabled for mono cathedral truss type.
                            • Added gable end trusses for mono cathedral truss type.
                            • Structural outlookers (vert. & horz.) enabled under advanced roof options for Mono Cathedral (2/2, 4/4) truss types.
                            • Added Mono Scissor truss type, configuration: (4/4).
                            http://design.medeek.com/resources/images/truss_su116_800.jpg
                            View model here:
                            3D Warehouse
                            I manually modeled this truss type about two months ago and I have been meaning to add it in, finally got it done tonight.
                            Manually created model here:
                            3D Warehouse
                            design.medeek.com
                            • jujuJ Offline
                              juju
                              @juju said:
                              how's the manual coming along?
                              • medeekM Offline
                                medeek
                                The plugin is in such a state of flux it doesn't make a whole lot of sense to invest a lot of time into the manual until things stabilize a bit more. The section I originally wrote now needs a complete rewrite.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.5.4 - 04.21.2016
                                  • Added a graphical user interface (GUI) for the selection of the truss type in the "Draw Roof Truss" sub-menu.
                                  • GUI can be toggled with previous drop down menu within global settings.
                                  http://design.medeek.com/resources/images/truss_su118_800.jpg
                                  http://design.medeek.com/resources/images/truss_su117_800.jpg
                                  As you can see there is only one global setting at the moment but now that I have the interface and back end properly setup it won't take much to add in a number of other global values. At some point I will probably have enough parameters that I will need to enable some sort of tabbed html front end for the global setting menu.
                                  With html web dialog boxes I am not sure how well they work on a Mac, the whole sync vs. async issue is a real problem for web dialogs and Macs. I only test on a PC so I can't guarantee 100% compatibility on a Mac. So far I haven't had too many complaints.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    I will probably add in the Barrel Vault and Clerestory truss types sometime next week as time allows however after that I don't really have any specific truss types that need to be added unless someone has one they would like to see added. I guess I'm starting to run out of trusses... never thought I would see that day.
                                    The next area that will probably get some focus is the various hip truss sets. I'm also looking at the dormer module as and a related plugin for wall framing.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Here is a preview of the Geometry Input (GUI) menu for the upcoming gambrel attic truss.
                                      http://design.medeek.com/resources/images/truss_su119_800.jpg
                                      Notice the preview pane which gives a basic profile of the truss and attic space. I still need to add some dimensions and some other symbols (pitch, bearing walls, etc...) to the preview graphics but it is mostly there and functioning quite admirably.
                                      The GUI is html with javascript and SVG (scalable vector graphics) for the image. The nice thing is that changing any of the inputs will instantly update the dimensions and preview image allowing one to fine tune the truss geometry before proceeding further. For gambrel roofs this ability to adjust the proportions of the roof relative to each other is very important in my opinion. See my previous gambrel study here:
                                      Medeek Design Inc. - Gambrel Roof Study
                                      Medeek Design Inc. - Free House, Garage, Shop and Barn Plans - Gambrel Roof Study
                                      (design.medeek.com)
                                      Since the menu is primarily composed of html, javascript and SVG you can actually beta test it external to SketchUp here:
                                      (design.medeek.com)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Updated screenshot of the gambrel attic menu:
                                        http://design.medeek.com/resources/images/truss_su120_800.jpg
                                        This is getting pretty close to the final form that this menu will take.
                                        It's actually really amazing what can be done with SVG and javascript, definitely not my forte but after this exercise I feel like I can probably construct anything with this combo if required.
                                        design.medeek.com
                                        • facerF Offline
                                          facer
                                          Medeek,
                                          Menu works fine.
                                          Do you have a "reset" to return to original values?
                                          The "Max Truss Height" I assume is the red dashed line in the diagram.
                                          To add clarity would a small red dash line after the menu text help?
                                          Seems you are enjoying yourself, keep up the good work.
                                          • medeekM Offline
                                            medeek
                                            With the graphical menus you will notice a slight delay once the "submit" button is clicked. This is to allow for a quick display of a status message, however I'm finding this delay to be annoying and may eliminate it altogether to speed the use of the new GUI.
                                            Also note that with gambrel attic trusses the non-graphical geometry menu is still an option if you turn off the GUI flag in the global settings. For some people this may be easier but I think the new preview pane is a major design asset when it comes to this type of roof.
                                            I'm thinking it might be useful to implement this same type of preview/GUI for regular attic trusses so that one can preview the configuration before committing. Now that I've been down this road once it won't be such a struggle. Most of the other truss types are fairly simple and a preview image is probably not warranted unless the users say otherwise.
                                            I feel that the preview window goes a long way in helping explain what each term is in the input geometry menu but I may also add in some pop up windows (?) that display diagrams or other explanatory notes to help the less educated users.
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 75
                                            • 76
                                            • 10 / 76
