    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      A nested dutch gable roof created with the plugin. The roof is initially generated by creating three dutch gable primitives and then deleting and trimming certain elements. The most time consuming is the creation of the two valley rafters. I think it might be helpful to have some sort of valley rafter tool if I can figure out a good way of doing that.
      http://design.medeek.com/resources/images/truss_su113_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Looking at the half hip roof next. Fairly cut and dried but I'm a little undecided how to handle the birdsmouths cut of the hip rafter where it intersects the discontinuity of the gable wall. I will probably use the same birdsmouth cut on the half hip rafters as the other common rafters of the roof.
        http://design.medeek.com/resources/images/truss_su114_800.jpg
        View model here:
        3D Warehouse
        design.medeek.com
          Remember this 😉
          https://gitejuralamoutena.files.wordpress.com/2014/11/charpente-recadre-signc3a9-copie.jpg
          • medeekM
            medeek
            Per user request:
            Version 1.5.2 - 04.18.2016
            • Added energy/raised heels for small span attic trusses (less than 24 ft.), 1 variant: vertical w/ strut.
            • Added some additional logic to improve the triangulation of the upper attic of attic trusses.
            http://design.medeek.com/resources/images/truss_su115_800.jpg
            When I get some more time I will add in slider and wedge raised heel options for the attic truss type but at that moment it is low priority since most users seem to favor a fairly tall raised heel when utilizing it with attic trusses.
            design.medeek.com
            • medeekM
              medeek
              I have been giving some thought to dormers and how to specify them. Below is a dormer design I framed in Solidworks a few years back for a garage design:
              http://design.medeek.com/images/MISC/GARAGE4828-A6D-3_DORMER1.jpg
              http://design.medeek.com/images/slideshow/GARAGE4828-A6D-3_FRAMING5_1024.jpg
              Of course the numerous ways in which one could frame a dormer is probably beyond the scope of this discussion but I would like to consider what geometry needs to be determined in order to orient and size the dormer.
              After some thought I think the following points, planes and lengths would define the geometry of a typical dormer:
              1.) Main Roof Plane
              2.) Attic Floor Plane
              3.) Offset from exterior wall below (how far the dormer is out of plane from the ext. wall below).
              4.) Pitch of Dormer roof
              5.) Dormer width
              6.) Dormer height (distance from attic floor plane to top plate of dormer wall)
              7.) Window width, height, and header depth
              8.) Dormer wall thickness (2x4 or 2x6)
              9.) Dormer rafter depth
              10.) Position of Dormer along length of building
              Items 2,3 and 10 can be combined into a single point selection.
              Revisiting this I think the location of the dormer can be established with the selection of two points and a plane (main roof plane), the rest of the parameters will be UI.
              design.medeek.com
              • medeekM
                medeek
                Version 1.5.3 - 04.20.2016
                • Added Mono Cathedral truss type, configurations: (2/2, 4/4).
                • Metric input enabled for mono cathedral truss type.
                • Added gable end trusses for mono cathedral truss type.
                • Structural outlookers (vert. & horz.) enabled under advanced roof options for Mono Cathedral (2/2, 4/4) truss types.
                • Added Mono Scissor truss type, configuration: (4/4).
                http://design.medeek.com/resources/images/truss_su116_800.jpg
                View model here:
                3D Warehouse
                I manually modeled this truss type about two months ago and I have been meaning to add it in, finally got it done tonight.
                Manually created model here:
                3D Warehouse
                design.medeek.com
                • jujuJ
                  juju
                  @juju said:
                  how's the manual coming along?
                  • medeekM
                    medeek
                    The plugin is in such a state of flux it doesn't make a whole lot of sense to invest a lot of time into the manual until things stabilize a bit more. The section I originally wrote now needs a complete rewrite.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.5.4 - 04.21.2016
                      • Added a graphical user interface (GUI) for the selection of the truss type in the "Draw Roof Truss" sub-menu.
                      • GUI can be toggled with previous drop down menu within global settings.
                      http://design.medeek.com/resources/images/truss_su118_800.jpg
                      http://design.medeek.com/resources/images/truss_su117_800.jpg
                      As you can see there is only one global setting at the moment but now that I have the interface and back end properly setup it won't take much to add in a number of other global values. At some point I will probably have enough parameters that I will need to enable some sort of tabbed html front end for the global setting menu.
                      With html web dialog boxes I am not sure how well they work on a Mac, the whole sync vs. async issue is a real problem for web dialogs and Macs. I only test on a PC so I can't guarantee 100% compatibility on a Mac. So far I haven't had too many complaints.
                      design.medeek.com
                      • medeekM
                        medeek
                        I will probably add in the Barrel Vault and Clerestory truss types sometime next week as time allows however after that I don't really have any specific truss types that need to be added unless someone has one they would like to see added. I guess I'm starting to run out of trusses... never thought I would see that day.
                        The next area that will probably get some focus is the various hip truss sets. I'm also looking at the dormer module as and a related plugin for wall framing.
                        design.medeek.com
                        • medeekM
                          medeek
                          Here is a preview of the Geometry Input (GUI) menu for the upcoming gambrel attic truss.
                          http://design.medeek.com/resources/images/truss_su119_800.jpg
                          Notice the preview pane which gives a basic profile of the truss and attic space. I still need to add some dimensions and some other symbols (pitch, bearing walls, etc...) to the preview graphics but it is mostly there and functioning quite admirably.
                          The GUI is html with javascript and SVG (scalable vector graphics) for the image. The nice thing is that changing any of the inputs will instantly update the dimensions and preview image allowing one to fine tune the truss geometry before proceeding further. For gambrel roofs this ability to adjust the proportions of the roof relative to each other is very important in my opinion. See my previous gambrel study here:
                          404 - File or directory not found.
                          (design.medeek.com)
                          Since the menu is primarily composed of html, javascript and SVG you can actually beta test it external to SketchUp here:
                          (design.medeek.com)
                          design.medeek.com
                          • medeekM
                            medeek
                            Updated screenshot of the gambrel attic menu:
                            http://design.medeek.com/resources/images/truss_su120_800.jpg
                            This is getting pretty close to the final form that this menu will take.
                            It's actually really amazing what can be done with SVG and javascript, definitely not my forte but after this exercise I feel like I can probably construct anything with this combo if required.
                            design.medeek.com
                            • facerF
                              facer
                              Medeek,
                              Menu works fine.
                              Do you have a "reset" to return to original values?
                              The "Max Truss Height" I assume is the red dashed line in the diagram.
                              To add clarity would a small red dash line after the menu text help?
                              Seems you are enjoying yourself, keep up the good work.
                              • medeekM
                                medeek
                                With the graphical menus you will notice a slight delay once the "submit" button is clicked. This is to allow for a quick display of a status message, however I'm finding this delay to be annoying and may eliminate it altogether to speed the use of the new GUI.
                                Also note that with gambrel attic trusses the non-graphical geometry menu is still an option if you turn off the GUI flag in the global settings. For some people this may be easier but I think the new preview pane is a major design asset when it comes to this type of roof.
                                I'm thinking it might be useful to implement this same type of preview/GUI for regular attic trusses so that one can preview the configuration before committing. Now that I've been down this road once it won't be such a struggle. Most of the other truss types are fairly simple and a preview image is probably not warranted unless the users say otherwise.
                                I feel that the preview window goes a long way in helping explain what each term is in the input geometry menu but I may also add in some pop up windows (?) that display diagrams or other explanatory notes to help the less educated users.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.5.5 - 04.29.2016
                                  • Added Gambrel Attic truss type, configurations: (AUTO w/ piggyback trusses).
                                  • Added a graphical user interface (GUI) for gambrel attic geometry input.
                                  http://design.medeek.com/resources/images/truss_su121_800.jpg
                                  A reset button would be useful to return the GUI to the default values. There is still a lot of work to be done with the gambrel attic truss type:
                                  • Advanced Options
                                  • Gable Trusses
                                  • Default or Reset Button
                                  • Metric Input
                                  View models here:
                                  3D Warehouse
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    This is the level of detail I am aiming for with the advanced options for gambrel attic roofs (minus the truss plates):
                                    https://scontent-sea1-1.xx.fbcdn.net/t31.0-8/13131738_10208476408255049_4068722961615908164_o.jpg
                                    Notice the structural outlookers with gable end trusses and the prow roof (option). I've got my work cut out for me.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      The updated truss yard:
                                      Medeek Truss Yard 3
                                      Sixteen different truss profiles currently available within the Medeek Truss Plugin:
                                      • Common
                                      • Monopitch
                                      • Attic
                                      • Scissor
                                      • Tail Bearing
                                      • Dual Pitch
                                      • Bowstring
                                      • Bow Barrel
                                      • Polynesian
                                      • Cambered
                                      • Cathedral
                                      • Tray
                                      • Mono Scissor
                                      • Mono Cathedral
                                      • Gambrel Attic
                                      • Floor (System 42)
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I am wondering how many of your designers/architects/contractors/builders out there have used Open Joist products?
                                        http://www.openjoisttriforce.com/
                                        I was thinking I might add their product line to the Floor Joist/Truss module.
                                        http://www.openjoisttriforce.com/wp-content/uploads/2013/12/prod-caract-ajust-img3-eng1.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.5.6 - 05.11.2016
                                          • The plugin now automatically checks for updates.
                                          • Option added in Global Settings to adjust frequency of "check for updates" or to disable this feature entirely.
                                          I've also added in the Open Joist (TriForce) floor truss but it is not quite ready for release so I have disabled it until the next version release.
                                          design.medeek.com
                                          • JQLJ
                                            JQL
                                            Hi again medeek,
                                            I haven't used open joist yet but I will.
                                            The only problem I see with it is that it's idea is very interesting but I think fire regulations don't allow for it to be visible.
                                            I might be wrong in some cases though, so I'm waiting for them to show up in front of me.
                                            Keep up your excellent work!
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 76
                                            • 77
                                            • 19 / 77
