    [Plugin] Set Arc and Circle Defaults
    24 Posts 12 Posters 30.8k Views 12 Watching
      rustystumps
      Dito on the Not working in V15 of SU. Really would like this.
        rustystumps
        2016 and still waiting for a Ruby Script for this. The one mentioned previous is old and the required second file is not readily downloadable.
        I manufacture models and use the SU files to print on my Form1+ 3D printer to make masters for RTV Silicone molds so finished parts are then cast in resin plastic.
        I need smooth arcs and curves and most, if not all, of my models have plenty of these.
          You might want to set about writing your own script for this. The author of this plugin hasn't been active here for four years. He might have moved on to other things.
            Might be good to try to reach out to the developer and see if he'd be willing to open source it and put it out on GitHub. IMO that would be better than rewriting from scratch.
              driven
              does this work in v14 and above?
              I don't use PC's but I'm looking for code that does something similar to this...
              require 'win32ole'
              val =  48
              circle_first = UI.start_timer(1.0, true) do
              	if Sketchup.active_model.tools.active_tool_name != 'CircleTool'
              		Sketchup.send_action('selectCircleTool;')
              	else # run the script
              		WIN32OLE;;new('WScript.Shell').SendKeys("#{val}{ENTER}")
              		p "#{val}{ENTER}"
              		UI.stop_timer(circle_first)
              		arc_next = UI.start_timer(1.0, true) do
              			if Sketchup.active_model.tools.active_tool_name != 'ArcTool'
              				Sketchup.send_action('selectArcTool;')
              				WIN32OLE;;new('WScript.Shell').SendKeys("#{val/2}{ENTER}")
              				p "#{val/2}{ENTER}"
              				UI.stop_timer(arc_next)
                Here is a v8...v2016 beta RBZ... of "TIG-CircleArcDefaulter"
                It uses different methods across the various SketchUp versions...
                Note that it's for Windows only...
                I think it works OK... πŸ˜•
                The defaults.txt file contains the default [new] segment counts for circles and arcs [its shipped values are 48 and 24 respectively].
                These are used to reset those defaults as SketchUp starts...
                The Plugins/Extensions menu contains a new TIG-CircleArcDefaulter submenu...
                Its items let you:
                1. Edit the defaults.txt file to set new defaults [which are then reused thereafter].
                2. Reset the defaults to the two values currently saved in the defaults.txt file [run this after saving your edit]...
                If there is positive feedback I'll publish it as a new Extension in the PluginStore...
                TIG-CircleArcDefaulter_v1.0.rbz
                  Here's an update on my recent beta RBZ...
                  v2.0 of "TIG-CircleArcDefaulter"
                  It works on v8...v2016 and it now works on both PC and MAC πŸ€“
                  It uses different methods across the various SketchUp versions and OS...
                  As with the original PC only version...
                  The Plugins/Extensions menu contains a new "TIG-CircleArcDefaulter" submenu...
                  Its items let you:
                  If there is enough positive feedback I'll publish it as a new Extension in the PluginStore...
                  PS: I did a post a while back about 'versines' and how to consider faceting in 3d-printing etc...
                  http://sketchucation.com/forums/viewtopic.php?p=577465#p577465
                  These simple snippets [" & mm] were written to let you input the radius, versine-tolerance [typically 1/1000"] and a swept-arc - and get back a corresponding segmentation suggested for the arc - since smaller radii are different from bigger objects etc...
                  PPS: As you know, @driven is a MAC guru, and he has pointed out in a PM that users with the latest OSX [my test MAC is one OSX behind!] might have Apple trying to protect them from the sort of operations need to circumvent SketchUp's segment-defaulting as it starts up... If you do get error messages and have some system knowledge you can probably set it to be allowed, alternatively let us know because @driven probably has a work around, but that does involve using a 3rd party app that'd need shipping for MAC uses...
                  TIG-CircleArcDefaulter_v2.0.rbz
                    v3.0 of "TIG-CircleArcDefaulter"
                    It now has a trap [thanks to @driven] to ensure that the SketchUp viewport is foremost as the 'reset' is done...
                    As with the previous version...
                    Its items let you:
                    1. Edit: the "defaults.txt" file to set new defaults [which are then reused thereafter].
                    2. Reset: the defaults to the two values currently saved in the "defaults.txt" file [run this after saving your edit]...
                    I'll repeat the PSs [modifed]...
                    PPS: @driven, the MAC guru, has pointed out that users of the latest OSX might have their Apple trying to protect them from the sort of operations need to circumvent SketchUp's segment-defaulting as it starts up...
                    If it does this, then please follow this guidance to allow SketchUp.app access to your computer...
                    https://support.apple.com/kb/PH21504?locale=en_US
                    TIG-CircleArcDefaulter_v3.0.rbz
                      v4.0 of "TIG-CircleArcDefaulter"
                      It uses different methods across the various SketchUp versions and OSs...
                      It now has a MAC trap [using 'cliclick' - thanks to @driven] to ensure that your OSX doesn't try and stop its system-level resetting.
                      Its items let you:
                      I'll repeat the various earlier PSs [modifed]...
                      PPS: @driven, our bestest MAC guru, has pointed out that users of the latest OSX might have their Apple trying to protect them from the sort of operations need to circumvent SketchUp's segment-defaulting as it starts up...
                      This version should circumvent this, if it does not please let us know, in the meanwhile see this...
                      TIG-CircleArcDefaulter_v4.0.rbz
                      • Bob JamesB Offline
                        Bob James
                        My vote: πŸ‘
                          Here's another update of my recent beta RBZ files...
                          v5.0 of "TIG-CircleArcDefaulter"
                          If sidesteps a possible MAC-only issue - which could arise if someone else were using the same app in their own Extension's code.
                          But now it's been properly separated...
                          See the previous posts about its usage etc, which remains the same...
                          TIG-CircleArcDefaulter_v5.0.rbz
                            aboammar
                            I just tried your extension (TIG-CircleArcDefaulter_v5.0.rbz) on SkecthUp Pro 2021 and it is working great. The only thing that is not working in the extension is the Reset Default function. Maybe you can fix this in an update.
                            Anyway, thank you so much for this extension. But why it is not available in the Extension Whitehouse?
                              You might notice that this free extension is ~10 years old, and it hasn't been changed for >5yrs, so any updates are very unlikely...
                              Note that none of my plugins are hosted on the EWH - and like Fredo - I prefer to use the somewhat earlier original repository - SketchUcation's PluginStore - which offers advantages to developers, and which has many additional tools unavailable through the EWH...
                              • 2 / 2
