    Rotate face and keep geometrie
    12 Posts 4 Posters 754 Views 4 Watching
      razofskiki
      Hello,
      I have little problem
      When i try to rotate just the top of a polygon, its all of the polygon its affected by the rotation of the top
      I just need a tool that let me rotate and keep the geometry like blender scale rotate by edge
      wrong :
      http://img15.hostingpics.net/pics/172825rotate.png
      Thank you in advance for your help
        Not that I know of. Maybe one of Fredo's Scales tools can do this. But I'm not sure.
          Is this what you're after?
            razofskiki
            [attachment=0:6z09win8]<!-- ia0 -->Screenshot - 4_4_2016 , 6_30_05 AM.png<!-- ia0 -->[/attachment:6z09win8]
            yes but why tool is used ?
              razofskiki
              Hi Rich O brien, thank you for your quick response
              yes fredo scale work but is need to select the complete polygon just for that 😞
              i search a tool that capable of rotate by edge selection on keep geometrie in the same time
              just like blender
              its ok but need its to select the entire polygon and its not rotation its moving from fredoscale
              http://i.imgur.com/DITLJqo.png
              not other tool for this task ?
              Thank you on advance and sorry for my english
                What tool? I just approached the problem differently. Instead of rotating the top, I cut the cylinder off at an angle with a cutting plane. Draw the cutting plane at the desired angle and use Intersect Faces to create an an intersection. Then erase what you don't need.
                This method also makes it possible to make more complex cuts if you need to.
                  razofskiki
                  Ok thank you Dave
                  Its many solutions for make this but im just " slowed " compare to blender tool for this little task
                  this fonction miss me alot.
                  i dream to select the edge contour from the top and just rotate it ^^ and the geometre still in place.
                  Again thank you for your time.
                    It's time to learn a different program and approach. This method isn't complicated and it doesn't have to be slow. It gets you what you asked for, too.
                      SU doesn't use the same geometry manipulation method as Blender.
                      Blender can target pivot points and 3D cursors. Adding this to SU would make it troublesome to use for a concept modeling application.
                      • BoxB Offline
                        I must say I don't understand your reluctance to use Fredoscale for this.
                          razofskiki
                          i use it ! its freaking awesone tool !
                          its just you need to select the entierly model for that
                          in this case its easy to select your model but in a more complex model ?
                          imagine you can make this just on selecting the edge from top ?
                          But i now, su is not the same with blender.
                          thank you again
                          • BoxB Offline
                            If you build your geometry correctly and use groups and components you would only need to select the group and taper it.
