    [Plugin] 2D Tools
    791 Posts 178 Posters 807.4k Views 177 Watching
    • I
      ivreich
      Brilliant, Thanks TIG
      Cheers,
      J
      • JQLJ
        JQL
        I noticed I cannot change linetype. It says right click for options but right click shows a context menu without any 2D tool entries.
        www.casca.pt
        Visit us on facebook!
          To [re]set the Line-Style you have to right-click in 'open space', otherwise the right-click activates the default context-menu...
          • JQLJ
            JQL
            Does it count if you are inside a group/component, with hide rest of model turned on and click on empty space there.
            The first entry actually says "close group" and then I have some context menu options as you say.
            www.casca.pt
              @JQL
              You're right - after all of these years !
              There is no context-menu when right-clicking in empty space in the model entities context, but there is when inside an edit mode...
              You can of course set the 2dLineStyle when in the model entities context and that will be used in the edit context.
              Or use the default 2dLineStyle on one piece and then select it and edit its 2dLineStyle, resetting the selected's 2dLineStyle that way...
              It also occurs in the '2dHatch' tool, when trying to reset the 'PATT' !
              This is clearly quite unsatisfactory - so I'll look at how I might fix it...
              • JQLJ
                JQL
                @tig said:
                @JQL
                LOL it's all your fault! I was working inside sectioncutface group!
                After your release of the latest SectionCutFace, where XY axis are parallel to section planes (I only requested it, it's your fault you developed it πŸ˜„), I've been rethinking my workflow for doing more stuff in sketchup than in LO. This includes linework of course and your dashed lines came to mind. I knew they were there but hadn't used them before...
                As you're diving into this again, have you ever tought of drawing a sequence of lines for your dashed lines instead of faces?
                That would allow us to use styles to control thickness instead of having a fixed face width, and it would allow us a bit more control on scenes displayed at multiple scales inside LO.
                (I would personally have a hard time with it as I'm using profiles to control width but...)
                www.casca.pt
                  Here's v7.5 http://sketchucation.com/pluginstore?pln=2Dtools Unlike when used within the Model entities-context, when editing a Group/Component the "right-click_in_open_space" was failing to open the 2dLineStyle-Settings or the 2dHatching-PATT-selector dialog: this has now been addressed - so that if used within an edit situation the short context-menu that appears has an appropriate command added onto it, which will then open that particular 2dTool's dialog.
                  • JQLJ
                    JQL
                    Thanks Tig!
                    www.casca.pt
                    • F
                      function
                      newest version is messing with select tool I think. say i do control g to group something - usually it lets me select things again immediately. this plugin is conflicting and makes it so i have to hit the select tool again to select things. hope that makes sense
                        This might be because of the tool-pop/push needed to add the context-menu...
                        I've investigated...
                        Here's v7.6 http://sketchucation.com/pluginstore?pln=2Dtools The context-menu for changing the 2dLineStyle & 2dHatching settings, when opened on a right-click from inside an edit situation, are now set up so that they do not interfere with other tools...
                        • L
                          LDHall
                          2D Fillet / Chamfer tool does not work.
                            There was an issue reported with 2dFillet sometimes failing - this January - but the latest versions, since v7.4, have addressed this.
                            The Fillet tool was changed for compatibility with all versions + >= v2016.
                            This update was important when its fillets are NOT applied onto a faced area.
                            Also the 2dFillet tool now helpfully highlights the two hovered/selected lines etc [as DaveR's gif illustrated very well].
                            Please get/install the latest RBZ - now v7.6 [which also include some fixes for 2dLineStyle and 2dHatching dialogs right-click opening when inside non-model contexts]...
                            Test and report back...
                            • josephkim626J
                              josephkim626
                              Thanks for the great work TIG!
                              • Clayton49C
                                Clayton49
                                Hi all,
                                Is anyone using TIG'S-2D-TOOLS on version SU-PRO-2017, as I see it's not validated yet for this version ?
                                Thanks,
                                Over & out,
                                CJT54
                                Over & out,
                                Clayton.
                                %(#008000)[Trotman & Taylor
                                Architectural Consultants]
                                  I already replied in the other thread. This extension works just fine in SU2017. Leave the loading policy set to unrestricted.
                                  • Clayton49C
                                    Clayton49
                                    Hi Dave-R,
                                    Thanks for confirming this, it's best this was aired on this 2D-tools page for others, tenuous links & all that. I see on my very old posts about subject, DASHED-LINES, I did in fact download & install this plugin, I now remember using it, but lost & forgot all about it, it must have been around the time I had a PC HD melt down...grrrr.
                                    I wonder why it's not been badged o.k. for SU-PRO-2017 on the download page... ? it sure is a great tool from what I remember, I can't wait to plug-it-in again.
                                    SU I feel has missed out on not providing 2D-CAD type tools, not everything needs to be modeled in 3D, adding the odd extra detail with 2D lines on saved model sections for building plans/sections makes this tool invaluable. I prefer doing it this way, rather than SU-LAYOUT, as all fixed & tied into the model. Besides that, I failed miserably in measuring off the model in SU-LAYOUT when trying to place/trace extra line details off the model in the view port at precise known distances. I think measuring was influenced by the scale of the view port window, anyway seemed tedious from what I recall. Not too sure why this is, as dimensions know what scale your using ? SU-LAYOUT is great for other items.
                                    Over & out,
                                    Clayton.
                                    • facerF
                                      facer
                                      Draftsight (Free)
                                      https://www.3ds.com/products-services/draftsight-cad-software/
                                      If you are looking for 2D drafting tool to complement your Sketchup work
                                      Draftsight offers the following advantages:
                                      1. Free
                                      2. Continually upgraded, allowing reading of current Revit or Autocad drawings in dwg or dxf
                                      3. Supported by Dassault Systemes 3DS - a large French company.
                                      • jujuJ
                                        juju
                                        @facer said:
                                        Draftsight (Free)
                                        1. Free
                                        I second this suggestion, I use it for viewing and conversion purposes.
                                        • P
                                          pavelleon410
                                          Thank you so much, this simple option was so lacking for me to work! Great!
                                            MarekSk
                                            Hello,
                                            I used to use 2D tools regularly, especially 2D text. Since I have completely reinstalled PC, installed Sketchup v.17.2.555 64-bit the function "Edit text" is very slow. If change the text in the
                                            pop-up window and hit ENTER, sometimes I wait even for one minute. This happens even the project is empty. Can you help me how to solve the issue please? In the past modifying text was getting slow when the project grows but not empty. Many thanks
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 35 / 40
