    Plugins - staying installed!
    4 Posts 2 Posters 443 Views 2 Watching
    • - Offline
      -rb-
      Hi all,
      Was wondering if anyone could point me to a solution to the dreaded having to install plugins/check toolbar boxes over and over again problem - every time I boot I have to re-install Fredo's Mirror ruby, Vertex Tools, etc. - it's been happening for years, and I know there's been many discussions but are there some definitive things I could troubleshoot? Permissions problem or something? Win 8, SK Pro 2015
      Cheers,
      • Rich
      • TIGT Online
        You should not have to reset plugins like this - let alone reinstall them.
        The activated-state of an extension and its toolbar [if any] should be remembered across sessions...
        Do you really mean reinstalling or just resetting ?
        Let's assume resetting for now...
        It suggests to me a 'permissions issue'.
        When you installed SketchUp did you do so as the administrator - I suspect not, or at least not fully...
        Here are some steps that might help fix this - they certainly can't make it worse !
        Ensure that you have your SketchUp 2015 installer.exe to hand - its to be reused later.
        Close all SketchUp windows...
        Open Control Panel > Programs and Features and UNINSTALL SketchUp 2015.
        Any installed Plugins etc should be left untouched...
        When we reinstall you will initially loose settings, like extensions' statuses and toolbars' active-states etc, but once reset they should now be remembered across sessions
        When that uninstalling is completed find and select the SketchUp 2015 installer.exe.
        You MUST now right-click > context-menu > "Run as Administrator".
        This will ensure that the re-installed version of SketchUp avoids some potential permission issues.
        Installing an exe by simply running it by double-clicking it, does NOT give the same end result - even if you have full-admin-rights, it can result in a flaky installation with subtle screw-ups - so remember always to use the context-menu method...
        Restart SketchUp 2015 and test - see what happens after you make some changes and do another restart...
        Report back...
        PS: 'Mirror' is mine, not Fredo's πŸ˜‰
        • - Offline
          -rb-
          Thanks for that TIG. Oh my lord I can't remember when I actually d-loaded that plugin - seems an age ago - apologies! Ah weird when I do install Mirror a pop-up appears asking me to install Fredo's library, like when I install that it suddenly allow's Fredo's plugins to work also - arg! Must be some sort of permissions nightmare. I'll re-install when I get some jobs out of the way and report back...
          • - Offline
            -rb-
            Been using SU for about 12 years and have gotten use to weird foibles - been sitting on this for a while but had to sort it lol
