    Learning to render with Twilight Hobby
    49 Posts 11 Posters 8.6k Views 11 Watching
    • BoxB Offline
      A couple of things that might help.
      Grab the HDRI studio pack from the store and use one of those as your light source without any sun. So in the environment tab set background to Hemispherical sky and browse for a background image to one of the HDRI you downloaded. Each one will give a different result.
      Set the material of your background form to plastic satin or shiny.
      This should give you a better lighting structure to play with the other elements.
      The critical thing is to create something for the shiny metal to reflect, the Studio HDRs give you this.
      You may want your backdrop form to be larger and even a bowl shape with a flat part in the center to sit things on. Different studio layouts give different results. What is outside the opening in your backdrop and where it is will affect how your reflections work.
      Remember, The sun isn't great for product renders, you really need to create your own lighting and environment, that can include throwing in other geometry out of camera view to give you something to reflect. With a plain surround all you get is a flat reflection. Look at a flat white wall in a mirror and what do you see?
      • ntxdaveN Offline
        ntxdave
        Thanks for the feedback Box. I switched over to using the Light here is my first render.
        This is much closer to what I want. The reflection I was talking about before was being able to see the equipment reflected in the floor.
        Lot more experimenting/learning needed but I feel like I am headed in a better direction.
        Press F1...thank me later
          Would you be willing to send me that SketchUp model? I'll try rendering it to see what I can get.
          • ntxdaveN Offline
            ntxdave
            Here is the model..............
            IP Stripper-inside.skp
            Yes, I need to go read some more of the tutorials about applying lights.
            However, I had to try one more little wrinkle first..........
            Wanted to see what would happen if I added some text.
              I didn't spend much time on this and I only set up a material for the large diameter pipes and the blue thing. It could be better but I just wanted to get a quick render out. What do you think?
              • ntxdaveN Offline
                ntxdave
                Dave, I like this better. What renderer are you using? The sections above the blue blower are blue also. I like the color of the metal better as well. Maybe just a little more hint of silver but it has a better degree of shine than what I am coming up with.
                • BoxB Offline
                  Here's a quick one.
                  I've changed no materials, so there is plenty of scope to play with those.
                  As I described above I used a flat bottom bowl as the background, turned off the sun, set it to hemispheric sky and added number one hdr from the sketchucation studio pack, reduced the brightness to 3, deleted your light and your box and rendered on easy medium for less than 2 minutes.
                  If you create a good environment you have good base to start editing your materials.
                    This was done in Kerkythea.
                    Oops! Since that entire horizontal pipe is all connected geometry, I painted it all the same.
                    That metal is from a preset. I didn't bother to edit it but I could have made it look more polished. The background is the default front face color.
                      Sorry no Twillight presently under hands! 😞
                      So Simlab
                      Then Fotor
                      Then Fotosketcher + Fotor
                      • olisheaO Offline
                        olishea
                        Nice to see a clear system of feedback and real progression here! Keep it up!
                        oli
                        • ntxdaveN Offline
                          ntxdave
                          You guys are all making me feel bad. Why am I having so much trouble learning how to do this?
                          @Box, @Dave R, & @Pilou You are each showing me some really good results. I do not seem to be getting the hang of things. I am trying to learn one step at a time but seem to be going backwards. Box, in particular, I really like the reflection of the equipment in the floor. Pilou, your colors in your first render really stand out to me and I like the floor tile.
                          I have been using Twilight because it is free. I was trying to apply one of their lights but I have to admit something about the 3 click process is not going well for me. Do not fully understand where I am going wrong.
                          @box said:
                          Here's a quick one.
                          What is the sketchucation studion pack?
                          • BoxB Offline
                            • pbacotP Offline
                              Dave,
                              Did you use a edge overlay in the render? Nice job. I think the metal as he says is nice, because the other metal looks too perfectly reflective to be realistic.
                              Peter
                              • olisheaO Offline
                                olishea
                                @pilou said:
                                I never made renderings, it's not my cup of thea
                                πŸ˜„ πŸ˜„ πŸ˜„
                                oli
                                • ntxdaveN Offline
                                  ntxdave
                                  I appreciate the patience all of you are showing me. I do not understand why I am being so dense. Box, there is a download of things that can be used with Twilight on the Kerkeythea site. I used one of those in this latest renderings using the settings like you suggested. Even with my "box" background, it looks much better. I just need to keep reading and exploring/trying.
                                  This one is much better (because of your information).
                                  I did lighten up the blue cloth a little and will go back and lighten the wall a little.
                                  This is just the medium setting @ 1:06. I am sure the high setting would make it even better.
                                    @ NDave : You will be surprised, I never made renderings, it's not my cup of thea, i just make translations of Render manuals or sites of render's engine, or UI!
                                    Like these ones for TwillightRender, Visualizer, Podium, LightUp, SimLab etc... ! πŸ˜‰
                                    For the render above I just read what has said Box and voilΓ ! πŸ˜„
                                    (the only difference is the apply of a standard Wall/Floor material)
                                    So you can make the same in Twillight!
                                    All renders today make quasi all the same things, just difference is the ergonomy!
                                    Twillight is perfect! 😎
                                    You right if you are hobbyist prefer the "one Click"! Alas this one is pricey (see KeyShot)
                                      @pbacot said:
                                      Dave,
                                      Peter
                                      Peter, yes. I did use an overlay. Actually, I pasted a Hidden Line exported onto a separate layer set to Multiply. I made the Hidden Line export at 4k or 5k wide and resized it down to the size of the rendered image so that the lines would be very thin. I also adjusted the opacity of that layer so the lines would be fairly light. All very quick and easy to do.
                                      @ntxDave, I could have also made the floor reflective but as I said, I was just trying to make a quick example and didn't bother setting up all of the materials.
                                      • ntxdaveN Offline
                                        ntxdave
                                        @box said:
                                        Thanks - got it. I am experimenting with each of the backgrounds.....
                                        • soloS Offline
                                          Ugh! I just missed a 'render this' challenge. πŸ’š
                                          • ntxdaveN Offline
                                            ntxdave
                                            Welcome aboard but the real challenge is me learning how to use a rendering engine. ❗
                                            • 1 / 3
