    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 164.1k Views 79 Watching
    • ppoublanP Offline
      ppoublan
      @ijmccoy said:
      it works if i start a new sketchup file. Its the same for all trees as well not just 1 type
      Made some tests with vRay without pb. I dont know much about how vray is working. If the problem occurs only on existing SU file, there maybe an issue with cache. Found this option you could try : "Clear folder texture cache"
      • OxerO Offline
        Oxer
        @ppoublan said:
        Hi oxer,
        From what I can see I think all these components are created or loaded by LightUp for Sketchup.
        I think it adds them to the model when a tree is drawn just bucause this plugin adds model or components or materials observers and add its own component when one of this list is changed.
        They disappears because in Tree Maker and I purge unused materials and unused components.
        Yours
        pascal
        The the funny thing is that I haven't installed LightUp, for this reason I don't know why these components are created when you place a new tree, perhaps another plugin is the guilty. ❓
        EDIT: I have seen in Components Window >Edition the path for these Components --> C:/Program Files/SketchUp/SketchUp 2014/Tools/lightup/components/pointlight-v1.6.skp
        I work on Mac and this path in OS X doesn't exist.
        • ppoublanP Offline
          ppoublan
          Sketchup UFO mysteries πŸ˜„
          Maybe I left some unpurged components with some leaves components definitions. Need to load all one by one to test...
          • OxerO Offline
            Oxer
            πŸ˜„ Yes, that is the error, leaves components files unpurged πŸ‘
            • ppoublanP Offline
              ppoublan
              "never let a bug, Oxer will point it"
              Added to the todo list.
              • OxerO Offline
                Oxer
                πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ It's my problem I'm very perfectionist. πŸ˜†
                See the flower13 it has another layers too.
                  Tubeman55
                  Hi there,
                  I am looking for a talented power user of 3D Tree Maker who can support me with creating some trees and plants for professional use. I am willing to spend some dollars for your effort.
                  Please drop me a line if you are intested and give me some background information about you.
                    lema
                    Tell me how to make a dense and clipping like this:
                    http://shkolazhizni.ru/img/content/i112/112798_or.jpg
                    http://voodland.com/images/stories/virtuemart/product/acer-platanoidies-globosum1.jpg
                    Inside the leaves do not want to not load.
                    • deaneauD Offline
                      deaneau
                      hi, i have found a good site for leafes and other think.
                      (nobacks.com)
                      Maple Tree Leaves - Image Gallery
                      (www.3dmd.net)
                        garystan
                        Hi everybody :
                                   Is there a Tree Maker plugin for Sketchup 8 ?  And where do I get it ?  The ones that I DID find are for Collada.
        garystan
                          sob80sup81
                          Hello,
                          Is this plugin still actively supported by the developer? I purchased a license expecting to get a more comprehensive library of trees and grass but after keying in the license, no change of tree collection from the free version.
                          • LOAML Offline
                            LOAM
                            @sob80sup81 said:
                            Hello,
                            Would also like to know this as it doest work in SU2017
                            • Bob JamesB Offline
                              Bob James
                              • jujuJ Offline
                                juju
                                @bob james said:
                                [attachment=0:1xmppw8w]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1xmppw8w]
                                works fine here in SU2017 as well
                                • LOAML Offline
                                  LOAM
                                  @juju said:
                                  @bob james said:
                                  [attachment=0:1aq04ju1]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1aq04ju1]
                                  It loads fine as per your image but try the following;
                                  • Make a tree
                                  • Reconfigure it, using right click, reconfigure
                                  • Change tree parameters *
                                  • Redraw tree using updated parameters **
                                  • You will notice that many of the sliding bars are listed as NaN
                                    ** Redraw does nothing after changing any of the parameters 😞
                                  http://i.imgur.com/Udv6s2S.jpg
                                  • OxerO Offline
                                    Oxer
                                    Error in Ruby Console to load a tree:
                                    Error; #<NoMethodError; undefined method `treetemplatename' for nil;NilClass>
                                    /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1141;in `webtosu'
                                    /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1117;in `block in initialize'
                                    /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `call'
                                    /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `find_support_files'
                                    /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `populate'
                                    /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1137;in `webtosu'
                                    SketchUp;1;in `call'
                                    OSX 10.11.6 & SU2017
                                    • LOAML Offline
                                      LOAM
                                      I've had an email back from ppoublan to say he is hoping to get this fixed in the new year.
                                        karllarsen
                                        @loam said:
                                        @juju said:
                                        @bob james said:
                                        [attachment=0:2vnsbkfz]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:2vnsbkfz]
                                        • Make a tree
                                        I am having the exact same problem.
                                        Less is more.
                                          Jorgensen
                                          has anyone got this to work with su2017?
                                          thanks
                                          jorgensen
                                            karllarsen
                                            It sure would be nice to know if this will ever work or its just a lost-cause?
                                            Less is more.
                                            • 16
                                            • 17
                                            • 3 / 17
