    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 208.4k Views 79 Watching
    • ppoublanP Offline
      ppoublan
      @ijmccoy said:
      using vray for sketchup. if i put a single tree in a model on its own it renders with the leaves but in the model ive just added trees to, they all render without leaves
      Does this only appears with some trees ? in this case which one ? Could you post one example.
      In any case there are two issues I know with many renders :
      • incorrect handling of colorized textures
      • incorrect handling of UVs textures when material is applied to a parent group, not to the faces.
      Here is an example :
      I'm not sure if you are in this case, but if you used trees with PNG textures, due to the render error on UVs, leaves may disappear because of the transparency part of their texture is not correctly placed.
      So I made a small script to fix it for trees.
      Could you test it and let me know if it works in your case.
      3darcstudiotools.rbz
      install the extension
      before rendering : use the menu 3DArcStudio>Tools>Fix Leaves textures...
      Yours
      Pascal
      • ppoublanP Offline
        ppoublan
        @pibuz said:
        Speaking of which, I have a little request for you: I work with Indigo Renderer, and it also supports a proxy system to substitute complex models with lighter ones. You only need to apply the suffix "_dummy" to the desired proxy which will be exported and rendered as the original component (eg. "tree" and corresponding proxy "tree_dummy").
        So first thing I did was checking the components window and see what happens when I convert one of your trees to a proxy: I saw nothing happens.
        The thing I'd like to ask you is if it's possible for you to add an option to save the dummy proxy to the components list, and maybe name it automatically "name"_dummy so that Indigo Renderer can recognize and export the complex tree model without having to re-render it (and make the SU scene heavy).
        As there is no standard method defined within Sketchup to manage proxies/ghosts, each plugin and render defined its own method. So the problem is they are not designed to interoperate 😞
        By the way this is maybe a good idea for a future Sketchup version to have a standard proxy/ghost management integrated. Maybe Chriss Fullmer is listening πŸ’­ ?
        In this particular case, from what you say, this could be the way to achieve it :
        • Create a tree, displayed in full mode
        • Add a second tree of the same type
        • You will be asked by TreeMaker if you want to add copies of existing tree or create a new component : answer No to create a new component
        You now have two trees that looks the same but each has its own component definition.
        Take one of them, rename its definition name to β€œβ€¦_dummy”.
        You can now convert it to proxy (right click, change to proxy), and let the other one with full draw.
        Place some copies of the _dummy in the model
        Hide the other one in order for it not being rendered.
        Test the render.
        Let me know if it works. If yes I can see how to integrate this operation into the code to ease the process.
        Yours
        Pascal
        • OxerO Offline
          Oxer
          Hi Pascal,
          I use Thea4SU plugin and the problem with the leaves textures exists ( bad UVs leaves in renders) but I have installed the Tools Script and the problem is fixed now. πŸ‘
          Before Use Fix Textures Leaves
          After Use Fix Textures Leaves
          Another question, when I create a tree in a blank sketchup file, new components appear in the Componentes Window, see the image below:
          but when I use Fix Texture Leaves Tool those components disappear, is that correct?
          • I Offline
            ijmccoy
            @ppoublan said:
            [attachment=2:27t53w9y]<!-- ia2 -->uvfix_avant.jpg<!-- ia2 -->[/attachment:27t53w9y]
            [attachment=1:27t53w9y]<!-- ia1 -->uvfix_apres.jpg<!-- ia1 -->[/attachment:27t53w9y]
            [attachment=0:27t53w9y]<!-- ia0 -->3darcstudiotools.rbz<!-- ia0 -->[/attachment:27t53w9y]
            Yours
            Pascal
            Tried the above but still coming out the same, really dont understand it as it works if i start a new sketchup file. Its the same for all trees as well not just 1 type
              pibuz
              I tested the tool too, and I confirm that this fixed the error (rendering with Indigo Renderer). In sketchUp - like Oxer - I never had any texture issues, BTW.
              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
              • ppoublanP Offline
                ppoublan
                @oxer said:
                Hi Pascal,
                [attachment=0:2zktr2wd]<!-- ia0 -->New Components.jpg<!-- ia0 -->[/attachment:2zktr2wd]
                Hi oxer,
                From what I can see I think all these components are created or loaded by LightUp for Sketchup.
                I think it adds them to the model when a tree is drawn just bucause this plugin adds model or components or materials observers and add its own component when one of this list is changed.
                They disappears because in Tree Maker and I purge unused materials and unused components.
                Yours
                pascal
                • ppoublanP Offline
                  ppoublan
                  Did you try the proposed method to render proxies with Indigo ? Let me know if it works, so I can see how to make it "scripted automaticaly" into the plugin.
                  pascal
                  • ppoublanP Offline
                    ppoublan
                    Made some tests with vRay without pb. I dont know much about how vray is working. If the problem occurs only on existing SU file, there maybe an issue with cache. Found this option you could try : "Clear folder texture cache"
                    • OxerO Offline
                      Oxer
                      @ppoublan said:
                      Hi oxer,
                      Yours
                      pascal
                      The the funny thing is that I haven't installed LightUp, for this reason I don't know why these components are created when you place a new tree, perhaps another plugin is the guilty. ❓
                      EDIT: I have seen in Components Window >Edition the path for these Components --> C:/Program Files/SketchUp/SketchUp 2014/Tools/lightup/components/pointlight-v1.6.skp
                      I work on Mac and this path in OS X doesn't exist.
                      • ppoublanP Offline
                        ppoublan
                        Sketchup UFO mysteries πŸ˜„
                        Maybe I left some unpurged components with some leaves components definitions. Need to load all one by one to test...
                        • OxerO Offline
                          Oxer
                          πŸ˜„ Yes, that is the error, leaves components files unpurged πŸ‘
                          • ppoublanP Offline
                            ppoublan
                            "never let a bug, Oxer will point it"
                            Added to the todo list.
                            • OxerO Offline
                              Oxer
                              πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ It's my problem I'm very perfectionist. πŸ˜†
                              See the flower13 it has another layers too.
                                Tubeman55
                                Hi there,
                                I am looking for a talented power user of 3D Tree Maker who can support me with creating some trees and plants for professional use. I am willing to spend some dollars for your effort.
                                Please drop me a line if you are intested and give me some background information about you.
                                  lema
                                  Tell me how to make a dense and clipping like this:
                                  http://shkolazhizni.ru/img/content/i112/112798_or.jpg
                                  http://voodland.com/images/stories/virtuemart/product/acer-platanoidies-globosum1.jpg
                                  Inside the leaves do not want to not load.
                                  • deaneauD Offline
                                    deaneau
                                    hi, i have found a good site for leafes and other think.
                                    (nobacks.com)
                                    Maple Tree Leaves - Image Gallery
                                    (www.3dmd.net)
                                      garystan
                                      Hi everybody :
                                                 Is there a Tree Maker plugin for Sketchup 8 ?  And where do I get it ?  The ones that I DID find are for Collada.
        garystan
                                        sob80sup81
                                        Hello,
                                        Is this plugin still actively supported by the developer? I purchased a license expecting to get a more comprehensive library of trees and grass but after keying in the license, no change of tree collection from the free version.
                                        • LOAML Offline
                                          LOAM
                                          @sob80sup81 said:
                                          Hello,
                                          Would also like to know this as it doest work in SU2017
                                          • Bob JamesB Offline
                                            Bob James
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
