    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
    • I Offline
      ijmccoy
      @ppoublan said:
      @ijmccoy said:
      using vray for sketchup. if i put a single tree in a model on its own it renders with the leaves but in the model ive just added trees to, they all render without leaves
      Does this only appears with some trees ? in this case which one ? Could you post one example.
      In any case there are two issues I know with many renders :
      • incorrect handling of colorized textures
      • incorrect handling of UVs textures when material is applied to a parent group, not to the faces.
      Here is an example :
      [attachment=2:27t53w9y]<!-- ia2 -->uvfix_avant.jpg<!-- ia2 -->[/attachment:27t53w9y]
      I'm not sure if you are in this case, but if you used trees with PNG textures, due to the render error on UVs, leaves may disappear because of the transparency part of their texture is not correctly placed.
      So I made a small script to fix it for trees.
      [attachment=1:27t53w9y]<!-- ia1 -->uvfix_apres.jpg<!-- ia1 -->[/attachment:27t53w9y]
      Could you test it and let me know if it works in your case.
      [attachment=0:27t53w9y]<!-- ia0 -->3darcstudiotools.rbz<!-- ia0 -->[/attachment:27t53w9y]
      install the extension
      before rendering : use the menu 3DArcStudio>Tools>Fix Leaves textures...
      Yours
      Pascal
      Tried the above but still coming out the same, really dont understand it as it works if i start a new sketchup file. Its the same for all trees as well not just 1 type
        pibuz
        I tested the tool too, and I confirm that this fixed the error (rendering with Indigo Renderer). In sketchUp - like Oxer - I never had any texture issues, BTW.
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        • ppoublanP Offline
          ppoublan
          @oxer said:
          Hi Pascal,
          Another question, when I create a tree in a blank sketchup file, new components appear in the Componentes Window, see the image below:
          [attachment=0:2zktr2wd]<!-- ia0 -->New Components.jpg<!-- ia0 -->[/attachment:2zktr2wd]
          but when I use Fix Texture Leaves Tool those components disappear, is that correct?
          Hi oxer,
          From what I can see I think all these components are created or loaded by LightUp for Sketchup.
          I think it adds them to the model when a tree is drawn just bucause this plugin adds model or components or materials observers and add its own component when one of this list is changed.
          They disappears because in Tree Maker and I purge unused materials and unused components.
          Yours
          pascal
          • ppoublanP Offline
            ppoublan
            Did you try the proposed method to render proxies with Indigo ? Let me know if it works, so I can see how to make it "scripted automaticaly" into the plugin.
            pascal
            • ppoublanP Offline
              ppoublan
              Made some tests with vRay without pb. I dont know much about how vray is working. If the problem occurs only on existing SU file, there maybe an issue with cache. Found this option you could try : "Clear folder texture cache"
              • OxerO Offline
                Oxer
                @ppoublan said:
                Hi oxer,
                Yours
                pascal
                The the funny thing is that I haven't installed LightUp, for this reason I don't know why these components are created when you place a new tree, perhaps another plugin is the guilty. ❓
                EDIT: I have seen in Components Window >Edition the path for these Components --> C:/Program Files/SketchUp/SketchUp 2014/Tools/lightup/components/pointlight-v1.6.skp
                I work on Mac and this path in OS X doesn't exist.
                • ppoublanP Offline
                  ppoublan
                  Sketchup UFO mysteries πŸ˜„
                  Maybe I left some unpurged components with some leaves components definitions. Need to load all one by one to test...
                  • OxerO Offline
                    Oxer
                    πŸ˜„ Yes, that is the error, leaves components files unpurged πŸ‘
                    • ppoublanP Offline
                      ppoublan
                      "never let a bug, Oxer will point it"
                      Added to the todo list.
                      • OxerO Offline
                        Oxer
                        πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ It's my problem I'm very perfectionist. πŸ˜†
                        See the flower13 it has another layers too.
                          Tubeman55
                          Hi there,
                          I am looking for a talented power user of 3D Tree Maker who can support me with creating some trees and plants for professional use. I am willing to spend some dollars for your effort.
                          Please drop me a line if you are intested and give me some background information about you.
                            lema
                            Tell me how to make a dense and clipping like this:
                            http://shkolazhizni.ru/img/content/i112/112798_or.jpg
                            http://voodland.com/images/stories/virtuemart/product/acer-platanoidies-globosum1.jpg
                            Inside the leaves do not want to not load.
                            • deaneauD Offline
                              deaneau
                              hi, i have found a good site for leafes and other think.
                              http://nobacks.com/photos/nature/leaves/
                              404 Not Found
                              (www.3dmd.net)
                                garystan
                                Hi everybody :
                                           Is there a Tree Maker plugin for Sketchup 8 ?  And where do I get it ?  The ones that I DID find are for Collada.
        garystan
                                  sob80sup81
                                  Hello,
                                  Is this plugin still actively supported by the developer? I purchased a license expecting to get a more comprehensive library of trees and grass but after keying in the license, no change of tree collection from the free version.
                                  • LOAML Offline
                                    LOAM
                                    @sob80sup81 said:
                                    Hello,
                                    Would also like to know this as it doest work in SU2017
                                    • Bob JamesB Offline
                                      Bob James
                                      • jujuJ Offline
                                        juju
                                        @bob james said:
                                        [attachment=0:1xmppw8w]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1xmppw8w]
                                        works fine here in SU2017 as well
                                        • LOAML Offline
                                          LOAM
                                          @juju said:
                                          @bob james said:
                                          [attachment=0:1aq04ju1]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1aq04ju1]
                                          It loads fine as per your image but try the following;
                                          • Make a tree
                                          • Reconfigure it, using right click, reconfigure
                                          • Change tree parameters *
                                          • Redraw tree using updated parameters **
                                          • You will notice that many of the sliding bars are listed as NaN
                                            ** Redraw does nothing after changing any of the parameters 😞
                                          http://i.imgur.com/Udv6s2S.jpg
                                          • OxerO Offline
                                            Oxer
                                            Error in Ruby Console to load a tree:
                                            Error; #<NoMethodError; undefined method `treetemplatename' for nil;NilClass>
                                            /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1141;in `webtosu'
                                            /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1117;in `block in initialize'
                                            /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `call'
                                            /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `find_support_files'
                                            /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `populate'
                                            /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1137;in `webtosu'
                                            SketchUp;1;in `call'
                                            OSX 10.11.6 & SU2017
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
